25 เมษายน 2024, 13:52:22 *
หน้า: 1 2 3 [4]   ลงล่าง
ผู้เขียน หัวข้อ:  Torque v1.4.88 Update Torque Pro (OBD 2 & Car) v1.8.205  (อ่าน 61564 ครั้ง)
« เมื่อ: 04 กรกฎาคม 2011, 18:18:39 »
Torque v1.4.88
Requirements: for all Android versions, supports App2SD
Overview: See what your car is doing in realtime, get fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU.
It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / fault code like a scantool.
It also has:
* Dyno / Dynomometer and Horsepower/HP & Torque
* 0-60 timings - more accurate than just using plain old GPS - see how fast your car is (or truck Smiley)
* Customisable dashboards
* Video your journey using the Track Recorder plugin with onscreen OBD data overlay - a black box for you car/truck!
* Send GPS tagged tweets directly to twitter (for example if you are going on a roadtrip)
* Massive fault code database for allowing lookup of fault codes from many different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffce
* Heads up display / HUD mode for night time driving
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP sensors
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
Recent changes:
*PLEASE NOTE!* Any reports of hanging or reboots after quitting the app is due to a bug in HTC devices and Galaxy Tab,this can be triggered by using the Pandora app. Disabling Pandoras new bluetooth settings fixes the problem, but HTC/Samsung need to release a fix.
Changes:
Gauge fixes
Unit fixes (C to F),
Graph activity (beta),
CO2 gauge/sensor
https://mark...prowl.torque
ลิงค์ครับ  Smiley
Very thank infinitely  สำนึกผิด
« ตอบ #61 เมื่อ: 02 พฤศจิกายน 2018, 21:37:57 »
ไม่ได้อัพเดทมานาน มาอัพเดทเวอร์ชั่นล่าสุดกัน
WHAT’S NEW
* Added digital compass (and improved the existing one)
* Added the ability to configure a background overlay for displays
* Update USB drivers
* When fault code scanning (in background) is enabled, and you have enabled logging, now writes into a companion ‘events’ file for new faults found (like the CSV log, but just for event-style information)
ลิงค์ครับ  Ok
kkmnsc
Exp 10-07-2011
ID number: 117
กระทู้: 113
$65.01 credits
Send Money to kkmnsc
-ได้ให้: 156
-ได้รับ: 230
« ตอบ #62 เมื่อ: 06 พฤศจิกายน 2018, 16:57:40 »
download ไม่ได้ครับ มันขึ้น เป็น text เต็มหน้าจอเลยครับ ขอบคุณครับ
olymania
ออนไลน์ ออนไลน์
lifetime memberผู้สนับสนุน
ID number: 3089
กระทู้: 210
Send Money to olymania
-ได้ให้: 511
-ได้รับ: 219
« ตอบ #63 เมื่อ: 08 พฤศจิกายน 2018, 20:18:36 »
ผมโหลดได้นะครับ
kkmnsc
Exp 10-07-2011
ID number: 117
กระทู้: 113
$65.01 credits
-ได้ให้: 156
-ได้รับ: 230
« ตอบ #64 เมื่อ: 09 พฤศจิกายน 2018, 08:35:56 »
เรียบร้อยครับไป download web นอกเรียบร้อยครับ ver เก่าของผมก้ใช้งานได้ดี scan เจอ camshaft position sensor มีปัญหาซื้อมาเปลี่ยนเอง นิ่งเลยตอนนี้ไม่มีรูปเครื่องยนต์โชว์แล้ว
หน้า: 1 2 3 [4]   ขึ้นบน
แจก poi update KML ครบชุด พร้อม icon สำหรับ Amigo - มี Update แก้ไขข้อผิดพลาดครับ
Custom POI
nomneow 3 8550 กระทู้ล่าสุด 23 กรกฎาคม 2010, 01:05:30
โดย nomneow
Custom POI
nomneow 49 50881 กระทู้ล่าสุด 04 มกราคม 2012, 13:44:27
โดย pali
Custom POI
nomneow 6 10205 กระทู้ล่าสุด 21 พฤศจิกายน 2009, 02:14:59
โดย nomneow
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.085 วินาที กับ 46 คำสั่ง
