19 เมษายน 2024, 06:53:24 *
หน้า: 1 [2] 3 4   ลงล่าง
ผู้เขียน หัวข้อ:  Torque v1.4.88 Update Torque Pro (OBD 2 & Car) v1.8.205  (อ่าน 61543 ครั้ง)
« เมื่อ: 04 กรกฎาคม 2011, 18:18:39 »
Torque v1.4.88
Requirements: for all Android versions, supports App2SD
Overview: See what your car is doing in realtime, get fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU.
It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / fault code like a scantool.
It also has:
* Dyno / Dynomometer and Horsepower/HP & Torque
* 0-60 timings - more accurate than just using plain old GPS - see how fast your car is (or truck Smiley)
* Customisable dashboards
* Video your journey using the Track Recorder plugin with onscreen OBD data overlay - a black box for you car/truck!
* Send GPS tagged tweets directly to twitter (for example if you are going on a roadtrip)
* Massive fault code database for allowing lookup of fault codes from many different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffce
* Heads up display / HUD mode for night time driving
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP sensors
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
Recent changes:
*PLEASE NOTE!* Any reports of hanging or reboots after quitting the app is due to a bug in HTC devices and Galaxy Tab,this can be triggered by using the Pandora app. Disabling Pandoras new bluetooth settings fixes the problem, but HTC/Samsung need to release a fix.
Changes:
Gauge fixes
Unit fixes (C to F),
Graph activity (beta),
CO2 gauge/sensor
https://mark...prowl.torque
ลิงค์ครับ  Smiley
Very thank infinitely  สำนึกผิด
« ตอบ #21 เมื่อ: 24 พฤษภาคม 2013, 20:00:39 »
Update Torque Pro (OBD2 & Car) v1.6.46
What's in this version:
*Tip:Turn on 'Faster Communication' in the OBD settings for faster read speeds!
* Fixes for problematic bluetooth drivers on some phones
* 60 to 130mph timer added
*If you are having connection problems with Cyanogen ROMs then update to the nightly builds as there is a bug in their BT drivers
*If your phone goes slow when Torque quits then you have bugged bluetooth drivers - enable the 'Hang fix for HTC/Samsung' in the settings (set it to 'Yes') to work around the issue
ลิงค์ครับ
« ตอบ #22 เมื่อ: 16 มิถุนายน 2013, 17:17:19 »
Update Torque Pro (OBD 2 & Car) v1.6.54
* Fix for missing Ca-Fi drivers that were missed in the last update
* Enhancements for 'Parrot' developers
* Floating widget support added
* Multi window support added
* 0-30 timer
* Updates for Cyanogen 4.2.2+
Notes:
Enjoy another release by PutterPlace. If you share this elsewhere, please give credit where it's due.
ลิงค์ครับ  เก็กหล่อ
« ตอบ #23 เมื่อ: 26 มิถุนายน 2013, 21:32:18 »
Update Torque Pro (OBD2 & Car) v1.6.58
**Tip:Turn on 'Faster Communication' in the OBD settings for faster read speeds!
 * Fixed the equation parser ignoring some large OBD replies
 * Fix for dashboards not saving on some devices with bugged ROMs
 * Parrot Asteroid Smart Bluetooth support
 * Minor bugfixes/tweaks/corrections
ลิงค์ครับ  เก็กหล่อ
« ตอบ #24 เมื่อ: 29 กรกฎาคม 2013, 16:15:19 »
Update Torque Pro (OBD2 & Car) v1.6.62
What's New
 * Fix for Android 4.3 issue on Nexus and Samsung devices
 * Improvement to OBD2 comms (small speedups and improvement for comms handling on some clone adapters)
ลิงค์ครับ  Smiley
« ตอบ #25 เมื่อ: 28 กันยายน 2013, 20:23:50 »
Update Torque Pro (OBD2 & Car) v1.6.72
What's New
* Bugfix for a condition that rarely happened on some devices with quad core (or more!) CPUs
* 'List tasks' permission no longer required for the Floating OBD Widget (a widget that can be put on screen in other apps like monitoring your Engine Temperatures in Google Navigation)
ลิงค์ครับ  Smiley
« ตอบ #26 เมื่อ: 14 พฤศจิกายน 2013, 06:12:08 »
Update Torque Pro (OBD2 & Car) v1.8.8
What's New
**Polite Note!** There are currently a lot of clone adapters circulating that are broken/not working on the CANBUS protocol - if your vehicle isn't working, check the adpater if it's a clone (it may work on older vehicles though)
 * Fix for web/map data not uploading on some devices
 * Fix for some USB related issues where torque could not see the adapter
 * Fix for some device specific running problems
ลิงค์ครับ  Smiley
« ตอบ #27 เมื่อ: 05 มกราคม 2014, 16:30:47 »
Update Torque Pro (OBD 2 & Car) v1.8.12
What's New
 * Move fault clear from the top action bar,to the menu
 * Fix new display orientation & resizing
 * Update fault descriptions
 * Vehicle profile can now be tapped on the main screen
ลิงค์ครับ  เก็กหล่อ
supat19
ID number: 42908
Send Money to supat19
-ได้ให้: 26
-ได้รับ: 19
« ตอบ #28 เมื่อ: 05 มกราคม 2014, 18:26:51 »
ไม่ทราบว่ามี Torque Pro Theme PACK บ้างไหมครับ ? หน้าตาที่อยู่ใน Torque มันเก่าๆทั้งนั้นเลย
« ตอบ #29 เมื่อ: 05 มกราคม 2014, 18:39:41 »
ยังไม่เคยใช้ครับ เดี๋ยวถ้ามีจะโพสต์ให้นะครับ Ok
« ตอบ #30 เมื่อ: 28 มกราคม 2014, 15:24:25 »
Update Torque Pro (OBD 2 & Car) v1.8.14
What's New
 * Added 'diagnostic' pre/post command options to pid editor
 * Added F150 workaround (for old F150 ECU's built in 2000/2001)
 * Added GPS distance ignore option in special settings
ลิงค์ครับ  เก็กหล่อ
« ตอบ #31 เมื่อ: 10 กุมภาพันธ์ 2014, 09:47:26 »
Update Torque Pro (OBD 2 & Car) v1.8.16
What's New
 *Added 'Set fuel level' push button option
 *Fixed graph scaling on hi-res devices
 *Added LOG10(...) and exponent (^) operators to equation parser
 *LePanII fixes
 *dpad screen navigation
ลิงค์ครับ  เก็กหล่อ
« ตอบ #32 เมื่อ: 15 กุมภาพันธ์ 2014, 20:09:29 »
Update Torque Pro (OBD 2 & Car) v1.8.22
What's New
 * Translation updates
 * Equation parser updates to fix bug that crept into 1.8.18
 * Updated tablet support to include correctly sized displays
ลิงค์ครับ  เก็กหล่อ
« ตอบ #33 เมื่อ: 21 พฤษภาคม 2014, 17:45:47 »
Update Torque Pro (OBD 2 & Car) v1.8.36
What's New
Changes:
* Fixed long-press options on the dashboard screens
* Speech pitch is controllable
* Alarms now send intents
* Bluetooth on/off fix
* Mass fuel PID fix
ลิงค์ครับ  Ok
« ตอบ #34 เมื่อ: 01 มิถุนายน 2014, 17:24:23 »
Update Torque Pro (OBD 2 & Car) v1.8.38
What's New
**Polite Note!** There are currently a lot of clone adapters circulating that are broken/not working on the CANBUS protocol - if your vehicle isn't working, check the adapter if it's a clone (it may work on older vehicles though)
 Changes:
 * Fix display moving issue where the menu would pop up
 * Fix for PIDs going 'deaf' on older ECUs (using the older ISO9141 protocol) whereby they would not refresh
ลิงค์ครับ
« ตอบ #35 เมื่อ: 12 ตุลาคม 2014, 12:38:46 »
Update Torque Pro (OBD 2 & Car) v1.8.41
What's New
Changes:
* USB Adapter updates and improvements
* PLX iMFD support update
* New historgram display type (beta)
* Fault code updates
ลิงค์ครับ  Ok
« ตอบ #36 เมื่อ: 24 พฤศจิกายน 2014, 14:15:48 »
Update Torque Pro (OBD 2 & Car) v1.8.46
What's New
 * Minor updates for Android 5
ลิงค์ครับ  เก็กหล่อ
« ตอบ #37 เมื่อ: 22 ธันวาคม 2014, 19:01:30 »
Update Torque Pro (OBD 2 & Car) v1.8.48
What's New
* Minor updates for a couple of issues reported by users, more support for hi-res GPS devices coming in the next update!
ลิงค์
« ตอบ #38 เมื่อ: 29 ธันวาคม 2014, 20:00:24 »
Update Torque Pro (OBD 2 & Car) v1.8.49
What's New
* Update to workaround an issue some users were having with the LVL
ลิงค์ครับ  Ok
basf
ID number: 4723
กระทู้: 18
Send Money to basf
-ได้ให้: 20
-ได้รับ: 28
« ตอบ #39 เมื่อ: 30 ธันวาคม 2014, 07:44:44 »
Update บ่อยกว่าใช้อีก
« ตอบ #40 เมื่อ: 31 ธันวาคม 2014, 14:14:18 »
จริงครับ บ่อยกว่าใช้มาก
หน้า: 1 [2] 3 4   ขึ้นบน
แจก poi update KML ครบชุด พร้อม icon สำหรับ Amigo - มี Update แก้ไขข้อผิดพลาดครับ
Custom POI
nomneow 3 8379 กระทู้ล่าสุด 23 กรกฎาคม 2010, 01:05:30
โดย nomneow
Custom POI
nomneow 49 50699 กระทู้ล่าสุด 04 มกราคม 2012, 13:44:27
โดย pali
Custom POI
nomneow 6 10035 กระทู้ล่าสุด 21 พฤศจิกายน 2009, 02:14:59
โดย nomneow
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.578 วินาที กับ 62 คำสั่ง
