18 เมษายน 2024, 07:52:05 *
หน้า: [1] 2 3 4   ลงล่าง
ผู้เขียน หัวข้อ:  Torque v1.4.88 Update Torque Pro (OBD 2 & Car) v1.8.205  (อ่าน 61539 ครั้ง)
-ได้รับ: 69257
« เมื่อ: 04 กรกฎาคม 2011, 18:18:39 »
Torque v1.4.88
Requirements: for all Android versions, supports App2SD
Overview: See what your car is doing in realtime, get fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU.
It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / fault code like a scantool.
It also has:
* Dyno / Dynomometer and Horsepower/HP & Torque
* 0-60 timings - more accurate than just using plain old GPS - see how fast your car is (or truck Smiley)
* Customisable dashboards
* Video your journey using the Track Recorder plugin with onscreen OBD data overlay - a black box for you car/truck!
* Send GPS tagged tweets directly to twitter (for example if you are going on a roadtrip)
* Massive fault code database for allowing lookup of fault codes from many different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffce
* Heads up display / HUD mode for night time driving
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP sensors
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
Recent changes:
*PLEASE NOTE!* Any reports of hanging or reboots after quitting the app is due to a bug in HTC devices and Galaxy Tab,this can be triggered by using the Pandora app. Disabling Pandoras new bluetooth settings fixes the problem, but HTC/Samsung need to release a fix.
Changes:
Gauge fixes
Unit fixes (C to F),
Graph activity (beta),
CO2 gauge/sensor
https://mark...prowl.torque
ลิงค์ครับ  Smiley
Very thank infinitely  สำนึกผิด
-ได้รับ: 69257
« ตอบ #1 เมื่อ: 13 กรกฎาคม 2011, 03:31:22 »
Update Torque v1.4.90   Roll Eyes
Changes:
ELM323 support
Screenshots to Google+ fix
Transmission temperature fix
AIDL plugin API update
Wider fault code support
Accelerometer/GPS fixes
Internal PID calculation support
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #2 เมื่อ: 25 สิงหาคม 2011, 01:17:28 »
Update Torque Pro (OBD2 & Car) v1.4.99
What's in this version:
FIx for Some Nissan and Volvo S40 ECUs
O2 sensor fixes
Trip average LPK/KPL/MPG fixes
AIDL updates for plugin API
Other bugfixes (see forums for more)
ลิงค์ครับ  Roll Eyes
-ได้รับ: 69257
« ตอบ #3 เมื่อ: 30 ตุลาคม 2011, 22:05:43 »
Update Torque Pro (OBD2 & Car) v1.5.22
Tip: Speed sensors up by enabling 'Faster Communication' in the settings! -
Small bugfixes for this update
New trip recorder/viewer
Fix for fuel trims 2x2->2x4
New file logging options
Please note*Any reports of hanging or reboots after quitting the app, then you'll need to enable the bluetooth bug 'workaround' in the General Preferences inside the app, this should workaround the hanging. Otherwise check for other bluetooth enabled apps and disable them, one may be conflicting!
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #4 เมื่อ: 11 มกราคม 2012, 22:13:24 »
Update Torque Pro (OBD2 & Car) v1.5.34
Tip: Speed sensors up by enabling 'Faster Comms' in the settings!-
MPG Units fix - You may need to update the adjustment factor
Unit conversion C/F fix (Only affects user PIDs may need updating)
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #5 เมื่อ: 23 มกราคม 2012, 19:17:28 »
Update Torque Pro (OBD2 & Car) v1.5.38
Baud Rate selector for USB
Realtime Web viewer
Mode 06 updates
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #6 เมื่อ: 20 กุมภาพันธ์ 2012, 04:56:51 »
Update  Torque Pro (OBD2 & Car) v1.5.46
ลิงค์ครับ  Smiley
toto1977
ID number: 1287
Send Money to toto1977
toto1977 toto1977 toto1977
« ตอบ #7 เมื่อ: 01 มีนาคม 2012, 16:45:09 »
ขอรับไปลองครับ
 ลองได้เลยครับ ไม่ต้องโพสต์บอกครับ
 *ลิ้งก์เชื่อมโยงถูกลบออก*
-ได้รับ: 69257
« ตอบ #8 เมื่อ: 23 พฤษภาคม 2012, 02:36:44 »
Update Torque Pro (OBD2 & Car) v1.5.62
* Tip: Turn on 'Faster Communication' in the OBD settings for faster read speeds!
* Minor update(before the next big update) to fix some minor bugs/crashes reported by users
* Translation updates (german, italian)
* If your phone goes slow when Torque quits then you have bugged bluetooth drivers - enable the 'Hang fix for HTC/Samsung' in the settings (set it to 'Yes') to work around the issue
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #9 เมื่อ: 31 กรกฎาคม 2012, 04:36:49 »
Torque Pro (OBD2 & Car) v1.6.6
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #10 เมื่อ: 04 พฤศจิกายน 2012, 16:31:50 »
Update Torque Pro (OBD 2 & Car) v1.6.22
* Tip:Turn on 'Faster Communication' in the OBD settings for faster read speeds!
* Add workaround for bugged bluetooth on Xperia U and GT-P5100 devices
* Adjustment to AFR reading for E10 vehicles
* Nissan consult support beta
* Fix for bug in map widget causing a close
* License Improvement for in-dash installs
ลิงค์ครับ  Smiley
-ได้รับ: 69257
« ตอบ #11 เมื่อ: 03 ธันวาคม 2012, 22:40:59 »
Update Torque Pro (OBD 2 & Car) v1.6.26
* Opel/Vauxhall fault code improvements (for OBD2 code reports only)
* History screen bugfix
* Workarounds for OS/Bluetooth bugs in the Sony Xperia (MT22i and others) and another US variant of the Galaxy S3
ลิงค์ครับ  Smiley
hondajazz
x1s8lt memberผู้สนับสนุน
ID number: 7
กระทู้: 834
Send Money to hondajazz
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #12 เมื่อ: 04 ธันวาคม 2012, 09:59:16 »
โปรแกรมนี้ใช้ดีมากครับ ผมใช้กับ Honda Jazz 2004 idsi
-ได้รับ: 69257
« ตอบ #13 เมื่อ: 04 ธันวาคม 2012, 10:12:45 »
ใช่ครับใช้ดีจริงๆ ครับ Confirm เลย
เหมาะสำหรับนักเดินทางจริงๆ  เก็กหล่อ
pekookja
ID number: 35403
กระทู้: 58
Send Money to pekookja
-ได้ให้: 45
-ได้รับ: 86
« ตอบ #14 เมื่อ: 04 ธันวาคม 2012, 15:36:53 »
ไม่ทราบว่าใช้งานอย่างไรครับ ต้องต่อกับ ECU ไหม
หรือว่าเชื่อมต่อกับ GPS
ไม่รู้จริงๆครับ แนะนำด้วยครับ
hondajazz
ID number: 7
กระทู้: 834
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #15 เมื่อ: 04 ธันวาคม 2012, 19:17:21 »
ต้องมีตัวนี้ก่อนครับ Bluetooth ELM327 ODB II ผมซื้อมาจาก ebay ตัวละประมาณ 15 $ ครับ หรือบ้านเราก็เห็นมีมาขายอยู่ตัวละประมาณ 700 บาท
http://www.e...&vxp=mtr
Ton_fuzzy
ID number: 51
กระทู้: 96
$5.00 credits
Send Money to Ton_fuzzy
-ได้ให้: 257
-ได้รับ: 107
« ตอบ #16 เมื่อ: 05 ธันวาคม 2012, 00:54:41 »
หน้าปัทม์สวยดีครับ ของผมไม่เห็นมีสกินแบบนี้เลย   Smiley
-ได้รับ: 69257
« ตอบ #17 เมื่อ: 21 กุมภาพันธ์ 2013, 05:42:25 »
Updaet  Torque Pro (OBD2 & Car) v1.6.34
*Tip:Turn on 'Faster Communication' in the OBD settings for faster read speeds!
* Bluetooth addresses now visible in bluetooth selector dialog
* Bugfixes for some reported bugs
* Work arounds for some cyanogen rom bluetooth driver bugs (which cyanogen need to fix properly)
ลิงค์ครับ  เก็กหล่อ
-ได้รับ: 69257
« ตอบ #18 เมื่อ: 10 มีนาคม 2013, 22:13:18 »
Update Torque Pro (OBD2 & Car) v1.6.36
* Plugin API fixes for setPIDInformation(...)
* 'ExtPID' issue fixes
* Some more bugfixes for random crashes
* Duramax injector balance rate PIDs added (beta)
* Nissan CONSULT changes + more debugging (beta)
ลิงค์ครับ  เก็กหล่อ
-ได้รับ: 69257
« ตอบ #19 เมื่อ: 20 มีนาคม 2013, 04:54:50 »
Torque Pro (OBD2 & Car) v1.6.39
ลิงค์ครับ  Smiley
หน้า: [1] 2 3 4   ขึ้นบน
แจก poi update KML ครบชุด พร้อม icon สำหรับ Amigo - มี Update แก้ไขข้อผิดพลาดครับ
Custom POI
nomneow 3 8351 กระทู้ล่าสุด 23 กรกฎาคม 2010, 01:05:30
โดย nomneow
Custom POI
nomneow 49 50669 กระทู้ล่าสุด 04 มกราคม 2012, 13:44:27
โดย pali
Custom POI
nomneow 6 10008 กระทู้ล่าสุด 21 พฤศจิกายน 2009, 02:14:59
โดย nomneow
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.466 วินาที กับ 64 คำสั่ง
