pigsan
ออฟไลน์ID number: 55
กระทู้: 166
$2010.02 credits
Send Money to pigsan
-ได้ให้: 134
-ได้รับ: 973
« เมื่อ: 26 พฤษภาคม 2010, 22:05:27 » |
iGO primo™ - Simply Advanced Navigation Post #1363 by Sylar » Wed May 26, 2010 2:52 pm Requirements: 64 MB RAM (128 recommended), 400+ MHz ARM 9/11 CPU, WQVGA (480x272) resolution Operating System: WinCE 4.2/5.0/6.0 OS based PNA device with 480x272 screen resolution Overview: The new OEM product that combines simplicity of use with the most recent technological advances from NNG Global Services. More Info: Code: Select all http://igomyway.com/primo/index.php :Download Links/Instructions: http://deref...primo_mp.rarpass: mobilepassion.org Mirrors: http://deref..._mp.rar.htmlhttp://deref...primo_mp.rarhttp://deref.../?d=8DOQ79ADhttp://deref...ul.to/zw54i6- download, unpack the provided archive to the root of your SD Card/Resident Flash. - launch the software by executing iGO.exe NOTE: Additional SYS.TXT modifications might be needed to get your specific hardware (GPS/TMC receiver) recognized by the software. NOTE: At the moment only standard PNA resolution of 480x272 is supported. This software wont work on devices with other resolutions until a compatible skin is provided for your device specific resolution. *** IMPORTANT NOTICE *** Due to some personal differences this release is not intended for releasing at PPCWAREZ.ORG/MOBILISM.ORG forum. We ask you kindly to NOT MAKE ANY MIRRORS on that site. Mirrors on other sites will be no problem at all. Failure to comply with this simple request will result in no more public releases of any kind from our Release team. Thank you all for understanding.The MobilePassion Release Team SLR/SR
-ได้รับ: 72112
« ตอบ #21 เมื่อ: 27 พฤษภาคม 2010, 10:53:31 » |
320x240 ตอนนี้ยังไม่รองรับครับ
kkman
ออฟไลน์รางวัล: ID number: 89
กระทู้: 85
$10.02 credits
Send Money to kkman
-ได้ให้: 159
-ได้รับ: 191
« ตอบ #22 เมื่อ: 27 พฤษภาคม 2010, 10:56:20 » |
Gurjon ก็ออก skin สำหรับ Primo มาแล้วนะครับ http://www.g...p?dir=PRIMO/ยังไม่ได้ลองอะไรเลยครับ .... ต้องรอเลิกงานก่อน....
เพศ: รางวัล: ID number: 2205
« ตอบ #23 เมื่อ: 27 พฤษภาคม 2010, 10:58:50 » |
:'( ใช้ content เดิม(Amigo)ได้มั้ยครับ MAP,DEM,POI ...
ได้ครับ แล้วถ้าเป็น content เดิมของ igo 8.3 ล่ะครับพี่อั๋นใช้ได้เหมือนกันใช่มั้ยครับ
-ได้รับ: 72112
« ตอบ #24 เมื่อ: 27 พฤษภาคม 2010, 11:07:09 » |
1. Show current speed. 2. Animate over speed. 3. Change speedcam position. 4. Transparent object. 5. Panic and restore button. 6. Bottom Bar. 7. Overview - 2D and 3D (recommended 3D and ~1300 overview zoom and overview tilt ~68-70. Tested on teleatlas map.) 8. Overview speed setings. 9. GJppp menu. (Include "Ui labs") 10. Night filter. 11. Zoom and tilt. 12. Power-on reminder. 13. Start to map. 14. Press on bottom bar -> if no route - "find menu", if exists route - "route menu". Long press on/off trip record. 15. Long press on mute (short menu) -> reset tripcomp (RT). 16. 2D/3D button, long press -> overview. 17. Manual speed limit. 18. And more settings...
install:
directory "UI_IGO9" copy in to root directory "primo". directory "utility" copy in to root directory "primo". And copy color schemes "GJpp1.1_d.zip", "GJpp1.1_n.zip". http://www.g...in_Primo.rar
narong9000
เกิดมาหล่อ รวย ช่วยไม่ได้
เพศ: รางวัล: ID number: 4
กระทู้: 1053
$2600.12 credits
Send Money to narong9000
-ได้ให้: 396
-ได้รับ: 10976
« ตอบ #25 เมื่อ: 27 พฤษภาคม 2010, 11:08:45 » |
ได้ครับ แล้วถ้าเป็น content เดิมของ igo 8.3 ล่ะครับพี่อั๋นใช้ได้เหมือนกันใช่มั้ยครับ ได้เหมือนกันครับ
ออฟไลน์รางวัล: ID number: 327
« ตอบ #26 เมื่อ: 27 พฤษภาคม 2010, 11:21:44 » |
สำหรับ Resolution แบบอื่นๆลองแก้ไขใน sys.ini ดูตามนี้ จะเป็นการขยายให้จอเต็ม ได้ผลอย่างไรผมยังไม่ลองเพราะในมือตอนนี้มีแต่หน้าจอ 480x272 ไม่มี High Res
[interface] show_exit=1 resolution_dir="480_272" vga=0
[rawdisplay] highres=0 screen_x=480 screen_y=272 stretch=1
ลอง [interface] extra_settings=1
สำหรับ Extra Feature ดังนี้: Skip Navigation Menu Capture Screen Desaturated Preview Map Skip Preview Map Backlight Details Save NMEA
tyredogth
Exp : 07-08-10
เพศ: ID number: 7367
Send Money to tyredogth
-ได้ให้: 30
« ตอบ #27 เมื่อ: 27 พฤษภาคม 2010, 14:37:34 » |
มารอเวอร์ชั่น สมบูรณ์แบบครับ แบบภาษาไทยครบๆอ่ะครับ เอาใจช่วยนะครับ ขอบคุณมากครับ
hondajazz
เพศ: รางวัล: ID number: 7
กระทู้: 834
Send Money to hondajazz
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #28 เมื่อ: 27 พฤษภาคม 2010, 16:27:43 » |
ลองดูแล้ว หน้าตาเมนูสวยน่าเล่นมากเลย..แต่เครื่องจับสัญญาณไม่ได้น่ะค่ะ ว่าแต่เครื่องเราทำไมไม่เป็นภาษาไทยเหมือนที่โชว์ล่ะ เพิ่มบรรทัดนี้เข้าไป ใน system.ini ครับ port="1" baud="38400" set ตาม port ของเครื่องที่ใช้ ดูจาก amigo ก็ได้ครับ ของผมหาอุปกรณ์ GPS ไม่เจอนะครับแต่ถ้าออกมาอยู่หน้า shell ของเครื่องแล้วเรียกโปรแกรม GPS test มันล็อกตำแหน่งได้นะครับใช้เครื่อง 507AP นะครับ
poponoy
VIP เมื่อ 08-11-2009
ออฟไลน์ID number: 2114
กระทู้: 21
Send Money to poponoy
-ได้ให้: 156
« ตอบ #29 เมื่อ: 27 พฤษภาคม 2010, 17:12:21 » |
ลอง ใส่ ; หน้า device ; อีกบรรทัดนึงที่เป็นชื่อ asus อะคับ ผมก็รุ่น เดียวกันกะท่านอะ มั้ง น่าจะใช้ ที่มันเป็นกรอบโลหะอะ
« แก้ไขครั้งสุดท้าย: 27 พฤษภาคม 2010, 17:23:19 โดย poponoy »
« ตอบ #30 เมื่อ: 27 พฤษภาคม 2010, 17:17:32 » |
ลองดูแล้ว หน้าตาเมนูสวยน่าเล่นมากเลย..แต่เครื่องจับสัญญาณไม่ได้น่ะค่ะ ว่าแต่เครื่องเราทำไมไม่เป็นภาษาไทยเหมือนที่โชว์ล่ะ เพิ่มบรรทัดนี้เข้าไป ใน system.ini ครับ port="1" baud="38400" set ตาม port ของเครื่องที่ใช้ ดูจาก amigo ก็ได้ครับ ของผมหาอุปกรณ์ GPS ไม่เจอนะครับแต่ถ้าออกมาอยู่หน้า shell ของเครื่องแล้วเรียกโปรแกรม GPS test มันล็อกตำแหน่งได้นะครับใช้เครื่อง 507AP นะครับ คุณ jazz หา GPS เจอหรือยังครับ? ถ้ายังเดี๋ยวผมจะเอา sys.text ผมมาลงให้ดู ทีแรกผมก็หาไม่เจอเหมือนกัน ปล้ำอยู่นานเลย :newe1:
« ตอบ #31 เมื่อ: 27 พฤษภาคม 2010, 17:23:16 » |
[/spoiler] ได้ icon หน้าตาสวยงามของคุณ norong มาด้วย แบบนี้เอา branding or data zip มาใส่แทนหรือเปล่าคะ เอา branding.zip กับ poi_visiblities.txt มาครับ ใน branding.zip ให้เปลี่ยน ui_igo8 เป็น ui_igo9 แต่แก้ไขไม่ได้มากนะครับยังมีปัญหาอีกมากครับ [/quote] สงสัยว่า poi_visiblities.txt นี่อยู่ตรงไหนครับ? ผมยังหาไม่เจอเลย แล้วเปลี่ยน ui_igo8 เป็น ui_igo9 ทำไมผมเปลี่ยนแล้วมันค้างที่หน้าจอ ตอนเข้าโปรแกรมเลย ต้องปิดเครื่องอย่างเดียว แล้วแก้ออก กะว่าเปลี่ยน icop poi ได้ก็จะอัพมาฝากเพื่อน ๆ ใหม่ :newe4:
hondajazz
กระทู้: 834
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #32 เมื่อ: 27 พฤษภาคม 2010, 17:23:50 » |
ลองดูแล้ว หน้าตาเมนูสวยน่าเล่นมากเลย..แต่เครื่องจับสัญญาณไม่ได้น่ะค่ะ ว่าแต่เครื่องเราทำไมไม่เป็นภาษาไทยเหมือนที่โชว์ล่ะ เพิ่มบรรทัดนี้เข้าไป ใน system.ini ครับ port="1" baud="38400" set ตาม port ของเครื่องที่ใช้ ดูจาก amigo ก็ได้ครับ ของผมหาอุปกรณ์ GPS ไม่เจอนะครับแต่ถ้าออกมาอยู่หน้า shell ของเครื่องแล้วเรียกโปรแกรม GPS test มันล็อกตำแหน่งได้นะครับใช้เครื่อง 507AP นะครับ คุณ jazz หา GPS เจอหรือยังครับ? ถ้ายังเดี๋ยวผมจะเอา sys.text ผมมาลงให้ดู ทีแรกผมก็หาไม่เจอเหมือนกัน ปล้ำอยู่นานเลย :newe1: หาอุปกรณ์เจอแล้วครับเดียวคงต้องออกไปนอกบ้านก่อนว่าจะมีสัญญาณหรือเปล่า
poponoy
กระทู้: 21
-ได้ให้: 156
« ตอบ #33 เมื่อ: 27 พฤษภาคม 2010, 17:25:48 » |
ลองอีกทีท่าน ไฟล์ของผมมีแค่นี้เอง ก่อนทำก็ backup ไว้ก่อนนะคับ ;[device] ;type="asus_R700" port="1" baud="38400" ตรง baud="38400" มันก็ไม่ตรงกับในเครื่องแต่ก็ใช้ได้อะคับ ของผมรุ่นนี้อะคับ http://www.n...topic=2135.0
phakboong
เพศ: ID number: 13
กระทู้: 293
$5005.03 credits
Send Money to phakboong
-ได้รับ: 418
« ตอบ #34 เมื่อ: 27 พฤษภาคม 2010, 17:36:39 » |
device ที่อยู่ใน sys.txt จะ link ไปหา folder config ที่อยู่ใน data.zip ซึ่งใน config จะมี folder แยกย่อยออกมาเป็น device ในโปรแกรมที่ใช้กัน มี device อยู่ 7 ตัว เป็น asus 1 ตัว ที่เหลือ เป็น navcon ในแต่ละ device จะมีการกำหนดค่าต่างๆไว้ เช่น gps port , tmc port แก้ไขกันได้ตามแต่ลักษณะของอุปกรณ์แต่ละท่านครับ
เพิ่มเติมครับ สำหรับท่านๆ ที่ใช้เครื่องแบบมีหลายโปรแกรมผ่านทาง menu ถ้าจะติดตั้ง ทั้ง igo8 และ primo ต้องเปลี่ยนชื่อ igo8 เป็นอย่างอื่นนะครับ เช่น igo888 เป็นต้น เพราะ exe file ของ primo จะไปดึงเอาข้อมูลที่อยู่ใน folder igo8 มาด้วย ไม่งั้น จะเกิดอาการ memไม่พอ รันโปรแกรมไม่ได้
hondajazz
กระทู้: 834
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #35 เมื่อ: 27 พฤษภาคม 2010, 18:44:25 » |
[/spoiler] ได้ icon หน้าตาสวยงามของคุณ norong มาด้วย แบบนี้เอา branding or data zip มาใส่แทนหรือเปล่าคะ เอา branding.zip กับ poi_visiblities.txt มาครับ ใน branding.zip ให้เปลี่ยน ui_igo8 เป็น ui_igo9 แต่แก้ไขไม่ได้มากนะครับยังมีปัญหาอีกมากครับ สงสัยว่า poi_visiblities.txt นี่อยู่ตรงไหนครับ? ผมยังหาไม่เจอเลย แล้วเปลี่ยน ui_igo8 เป็น ui_igo9 ทำไมผมเปลี่ยนแล้วมันค้างที่หน้าจอ ตอนเข้าโปรแกรมเลย ต้องปิดเครื่องอย่างเดียว แล้วแก้ออก กะว่าเปลี่ยน icop poi ได้ก็จะอัพมาฝากเพื่อน ๆ ใหม่ :newe4: poi_visiblities.txt ที่อยู่ใน save นะครับจากอันเก่ามาวางในอันใหม่ได้เลยครับ ส่วน branding ก็เอามาจากอันเก่านะครับ
« แก้ไขครั้งสุดท้าย: 27 พฤษภาคม 2010, 18:48:58 โดย hondajazz »
aryupat
ออฟไลน์ID number: 6977
กระทู้: 78
$10.02 credits
Send Money to aryupat
-ได้ให้: 89
-ได้รับ: 94
« ตอบ #36 เมื่อ: 27 พฤษภาคม 2010, 20:04:05 » |
ขอโทษนะครับ สงสัยนิดนึง อย่างของผมลงหลายโปรแกรม Igo8,IgoAmigo,sygic,Primo(อันนี้แหละ) ผมสงสัยที่บอกให้ไปเปลี่ยนคือเปลี่ยนชื่อโฟลเดอร์หรือชื่อตัวโปรแกรม .exe ครับ เพราะผมเองลงเชลตัวนี้อยู่อะครับ Shell PVStyle v1.3.0 Final มิน่าผมรันแล้วมันฟ้อง memory ไม่พอแล้วค้างไปเลย ขอบคุณครับ ถ้าจะติดตั้ง ทั้ง igo8 และ primo ต้องเปลี่ยนชื่อ igo8 เป็นอย่างอื่นนะครับ เช่น igo888 เป็นต้น
Prapan
ออฟไลน์ID number: 5076
กระทู้: 82
Send Money to Prapan
-ได้ให้: 179
-ได้รับ: 213
« ตอบ #37 เมื่อ: 27 พฤษภาคม 2010, 22:41:24 » |
ของผมรันได้แต่เหมือนว่าทำให้ amigo-sk ของผมเปิดไม่ได้ มันฟ้องว่า out of memory requested: 4294967295 Cache:101319 ไม่ทราบว่าเป็นเพราะอะไรครับ แล้วแก้ยังไงครับ (iGo 8.3 อยู่ใน directory \igo, amigo อยู่ใน \amigo\ primo อยู่ใน \primo) ช่วยด้วยครับ
« แก้ไขครั้งสุดท้าย: 27 พฤษภาคม 2010, 23:18:43 โดย Prapan »
death666th
ออฟไลน์ID number: 6230
กระทู้: 36
Send Money to death666th
-ได้ให้: 149
-ได้รับ: 265
« ตอบ #38 เมื่อ: 27 พฤษภาคม 2010, 23:59:17 » |
สนใจ ฟังก์ชั่น เกี่ยวกับน้ำมันครับ การคำนวณ การสิ้นเปลืองแต่คีย์ข้อมูลเข้าไม่ถูกจริง ๆ ไม่ทราบว่าต้องใส่ลำดับขั้นตอนอย่างไร ใครดู ฟังก์ชั่นนี้แล้วพอเข้าใจ ช่วยอธิบายหน่อยครับ อ๋อ แล้วผมจะเปลี่ยน font ได้อย่างไรครับ ขอบคุณครับ
auka45
VIP เมื่อ 25-12-2009
AlphaCoustic MP-1769
เพศ: รางวัล: ID number: 3226
กระทู้: 165
$55.52 credits
Send Money to auka45
-ได้ให้: 283
-ได้รับ: 289
« ตอบ #39 เมื่อ: 28 พฤษภาคม 2010, 21:24:16 » |
ขอผมขึ้น Error message:
User interface resolution [480x234] is not supported or compatible skin can not be found. Exiting application.
ผมใช้ จอ 7 นิ้ว High Res.
