27 เมษายน 2024, 19:48:51 *
ผู้เขียน หัวข้อ:  Skin diMka WA P.1.5.0 for Primo 1.2 & Primo 2.0 (_-= 28-12-2011 =-_)  (อ่าน 12302 ครั้ง)
coUp..uP
ID number: 27695
« เมื่อ: 29 ธันวาคม 2011, 09:32:52 »
Skin Dimka 1.5.0 สำหรับ Primo 2.0 ออกแล้ว สนใจเชิญได้ครับ
In the archive:
diMkaWA_P150.zip - with images of buttons and icons from Andron66 (in the folder content / skin);
diMkaWA_P150_default.zip - skin with default picture buttons and icons (in the folder content / skin);
utility - a utility for folder MapChanger
font - font folder with digital (if this folder at the root of the program in the screen saver will be able to display in a digital font)
Speedcam_Example.jpg - screenshot folder contents audio for one of the languages ​​voice voice-camera warning for other languages ​​inside file names must be the same.
readme_oldchanges_version12_ru.txt - a list of features and capabilities that have been in the skin for version 1.2 and work in the skin for version 2.0.
In the setting of choice:
 - Day theme - diMka WA P.1.5.0 (or diMka WA P.1.5.0 default)
 - Night Theme - diMka WA P.1.5.0 (or diMka WA P.1.5.0 default)
 - Restart the program.
Changes:
ver. P.1.5.0:
1. Includes all the features and add-on skin for version 1.2.
2. The new principle of the "Return to the machine":
 - A single place to store a list of recorded provisions (previously beaten the story) - \ userlists \ ret2car_history.txt;
 - View the recorded provisions in the "Details" in the main search menu;
 - Ability to filter the list of events (loss of signal output, etc.);
 - The maximum size of the list - 24, reaching a maximum at the old records are deleted.
3. Changing the position (address) custom POI.
4. Setting time disappearing Information Bar "Roadside Service" (highway POI).
5. New item in menu TTSPro - "Options for the route in real-time" (the phrase "In .... m. possible alternative route to the street ......, ....... shorter feet.")
 - To listen to and enable / disable the extra distance to the point of the phrase detour phrase naming the street (the street name in the test will be only after determining the position of GPS), a phrase of comparison (shorter / longer on ...) can be directly in the menu (button to go to the screen test voice-activated in the ground and included a voice with a sound);
 - Enable / disable a menu will be available TTSPro with the support of TTS-voice such a possibility, ie the presence of \ i18n \ dictionary.voice voice file such a block transfer (for example, Russian TTS):
After% s = "A% s"
Possible alternative route = "possible alternative route"
more shortly on% s = "shorter on% s"
more long on% s = "longer on% s"
For a complete voice-phrase the name and the street due to the fact that version 2.0 allows you to get a formatted voice file name the streets, you need a voice file to use TTS-voices in the \ config \ config_transforms.lua add function format_street_name ():
for example, Russian TTS:
function format_street_name (streetname)
    if wstring.sub (streetname, 1, 9) == L "for_turns" then
        local str = smart_lower_case (wstring.sub (streetname, 10))
        local str1 = transform_and_format (str, replace_mapinfo)
        str1 = transform_and_format (str1, replace_for_turns)
        if sc_GetSysEntry ("tts", "accusative_case", 0) then
ร้านของผม
som456
ID number: 7003
กระทู้: 46
$4384.00 credits
Send Money to som456
-ได้ให้: 214
-ได้รับ: 53
« ตอบ #1 เมื่อ: 18 มกราคม 2012, 12:19:54 »
ผมใส่  [poi]
use_multi_poi_icon="0" ใน sys.txt  แล้ว
POI ที่อยู่ติดใกล้ ยังแสดงเป็น รูป บอลลูนสีฟ้าติดกัน 3 อัน
มีวิธีให้แสดงแยกเป็นแต่ละอัน ได้ไม่ครับ
Legolas
x1x1vip...
ID number: 12687
กระทู้: 532
Send Money to Legolas
-ได้ให้: 1347
-ได้รับ: 573
« ตอบ #2 เมื่อ: 19 มกราคม 2012, 08:47:12 »
ใช้โหมดการแสดงแผนที่เป็น 2D หรือ 3D ครับ
ผมใส่  [poi]
som456
ID number: 7003
กระทู้: 46
$4384.00 credits
-ได้ให้: 214
-ได้รับ: 53
« ตอบ #3 เมื่อ: 19 มกราคม 2012, 22:34:25 »
โหมดการแสดงแผนที่เป็น 3D ครับ
coUp..uP
ID number: 27695
« ตอบ #4 เมื่อ: 19 มกราคม 2012, 22:53:52 »
ผมใส่  [poi]
Igo Primo 2.0 เท่าที่ทดสอบ ใช้ คำสั่ง
use_multi_poi_icon ไม่ได้ครับ
group_poi_icons ก็ไม่ได้ครับ
ตอนนี้ในแบบ 3D  ถ้าจุดมี POI มากกว่า 2 ต้องแสดงรูป multipoi ไปก่อนครับ
ร้านของผม
[Primo] ประมวณภาพสวย ๆ ต้อนรับการมาของ iGO Primo
narong9000 5 7214 กระทู้ล่าสุด 29 พฤษภาคม 2010, 20:53:24
โดย suthep.das
กลับหน้าจอ Primo? (อยากทราบวิธีหมุนหน้าจอให้ Primo ใน HTC Diamond)
ponsaku 9 20172 กระทู้ล่าสุด 17 กันยายน 2010, 07:41:43
โดย pdadd
igo primo ลง skin dimka 1.5.3 แล้ว Failed to open file: ui_igo9\common\junctionv
daplab 1 3390 กระทู้ล่าสุด 26 กุมภาพันธ์ 2014, 10:45:45
โดย Dynax505
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.043 วินาที กับ 45 คำสั่ง
