29 มีนาคม 2024, 19:15:53 *
ผู้เขียน หัวข้อ:  โครงสร้างภายใน iGO8 PNA, PDA  (อ่าน 33858 ครั้ง)
กระทู้: 13113
-ได้รับ: 72082
« เมื่อ: 13 ตุลาคม 2009, 21:38:36 »
ศึกษาไว้ก็ดีครับ จะได้รู้ว่าควรเอาอะไรใส่ไว้ตรงใหน  ;)
เครดิต : .t3rr0r @ 4PNA
What should be in the folder iGO, to work properly on any navigator.
I'm tired of constantly telling everyone that should be located in folders, so I decided to write once, and with pictures ...
Let's go:
1.
Folders: content, license, custom and save (will be created for yourself, after the first run)
Files: branding.zip, data.zip, gpstmc.dll, iGO8.exe, sys.txt, tahoma.ttf, tahomabd.ttf
2.
Folder content, in it:
2.1 building
building - building, the files must be with the extension .3 dl or .3 dc
2.2 dem
dem - the landscape, the files must be with the extension. dem
2.3 lang
lang - language of the program, the files must be the. zip
2.4 map
map - maps, files should be with the extension. fbl
2.5 poi
poi - point of interest, the files must be with the extension. poi
2.6
skin - skins, files must be the. zip
2.7 speedcam
speedcam - cameras / risk files must be with the expansion. txt
2.8 voice
voice - voice files must be the. zip
3.
Folder custom - I have it is always empty, no bed there.
4.
Folder, license in it:
device.nng - navigator itself creates.
GENERIC_iGO8_WorldWide@801Product.lic - Are included with the program, additional pumping is not necessary.
LCP_43J_FEU @ 0807_ (NNG + TA_HUN_TMC). Lic - Are included with the program, additional pumping is not necessary.
5.
Folder save - will create itself, and itself will write, do not touch.
6.
branding.zip and data.zip - these files store settings screen sizes, graphics and things.
As standard data is laid out in a cap and branding files under a resolution of 320x240, 480х272 and 480h234, if you have a pda and other navigator with an unusual resolution, download files iGO data.zip v10b (see hat themes)
7.
gpstmc.dll - some sort of a library, as the name for the module TMC, I have not, so do not know, maybe it's worth it and remove
8.
iGO8.exe - the main file in the program, he'd run at update programs is sometimes missing, simply replace it and enjoy
9.
sys.txt - more about it can be read in the cap.
10.
tahoma.ttf
tahomabd.ttf
This font)) will not touch them.
Well, like everything, good luck to you  ;)
tee_city
ID number: 673
Send Money to tee_city
« ตอบ #21 เมื่อ: 16 กุมภาพันธ์ 2010, 17:37:35 »
สอบถามครับ
สามารถ run บน PC หรือ notebook ได้ไหมครับ
ถ้ามี GPS  USB
narong9000
เกิดมาหล่อ รวย ช่วยไม่ได้
ผู้สนับสนุนคนพิเศษ
ID number: 4
กระทู้: 1053
$2600.12 credits
Send Money to narong9000
-ได้ให้: 396
-ได้รับ: 10976
« ตอบ #22 เมื่อ: 16 กุมภาพันธ์ 2010, 17:45:35 »
สอบถามครับ
ถ้ามี GPS  USB
iGO8 มีทั้ง Version ที่ Run บน PC , PDA, PNA ครับ ต้องเลือกใช้ให้ถูกตัวครับ  เก็กหล่อ
rawpas
ID number: 3846
Send Money to rawpas
-ได้ให้: 54
« ตอบ #23 เมื่อ: 22 กุมภาพันธ์ 2010, 17:34:28 »
sys.txt มีผลกับการเปลี่ยน Skin(พื้นผิว)มั้ยครับ ผมลองเปลี่ยนแล้วไม่ได้ มันขึ้นให้เลือกเป็นลางๆ กดไม่ได้ครับ เครื่องเป็น DVD 2din
ขอบคุณมากครับ
« ตอบ #24 เมื่อ: 22 กุมภาพันธ์ 2010, 20:43:26 »
ขอบคุณมากครับ
sys.txt ไม่น่าจะมีผลกับการเปลี่ยน skin นะคะ เพราะ เป็นการปรับตั้งค่าบางอย่างในโปรแกรม ไม่ทราบว่าคุณปรับเปลี่ยนอะไรใน sys.txt หรือว่าปรับเปลี่ยนส่วนอื่นเพิ่มเติมบ้างหรือเปล่าคะ
hondajazz
x1s8lt memberผู้สนับสนุน
ID number: 7
กระทู้: 834
Send Money to hondajazz
-ได้ให้: 473
-ได้รับ: 1990
« ตอบ #25 เมื่อ: 22 กุมภาพันธ์ 2010, 20:54:26 »
ขอบคุณมากครับ
ความละเอียดของ SKIN กับหน้าจอไม่ตรงกันหรือเปล่าครับ
Mr.Maxy
ID number: 6987
กระทู้: 59
Send Money to Mr.Maxy
-ได้ให้: 101
-ได้รับ: 95
« ตอบ #26 เมื่อ: 29 เมษายน 2010, 17:21:18 »
มีประโยชนืมากๆ สำหรับ มือใหม่ครับ เยี่ยม  Roll Eyes
คลองถม - Navthai
eak_1v 59 58618 กระทู้ล่าสุด 17 เมษายน 2012, 09:21:46
โดย tong999
watcharapol_k 8 22009 กระทู้ล่าสุด 28 มิถุนายน 2010, 23:29:25
โดย NungS
อยากได้ IGO8.3
tu3571138 5 5078 กระทู้ล่าสุด 24 มกราคม 2018, 00:31:12
โดย khigiam
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.059 วินาที กับ 54 คำสั่ง
