27 เมษายน 2024, 06:17:14 *
หน้า: [1] 2   ลงล่าง
ผู้เขียน หัวข้อ:  โครงสร้างภายใน iGO8 PNA, PDA  (อ่าน 34463 ครั้ง)
-ได้รับ: 72122
« เมื่อ: 13 ตุลาคม 2009, 21:38:36 »
ศึกษาไว้ก็ดีครับ จะได้รู้ว่าควรเอาอะไรใส่ไว้ตรงใหน  ;)
เครดิต : .t3rr0r @ 4PNA
What should be in the folder iGO, to work properly on any navigator.
I'm tired of constantly telling everyone that should be located in folders, so I decided to write once, and with pictures ...
Let's go:
1.
Folders: content, license, custom and save (will be created for yourself, after the first run)
Files: branding.zip, data.zip, gpstmc.dll, iGO8.exe, sys.txt, tahoma.ttf, tahomabd.ttf
2.
Folder content, in it:
2.1 building
building - building, the files must be with the extension .3 dl or .3 dc
2.2 dem
dem - the landscape, the files must be with the extension. dem
2.3 lang
lang - language of the program, the files must be the. zip
2.4 map
map - maps, files should be with the extension. fbl
2.5 poi
poi - point of interest, the files must be with the extension. poi
2.6
skin - skins, files must be the. zip
2.7 speedcam
speedcam - cameras / risk files must be with the expansion. txt
2.8 voice
voice - voice files must be the. zip
3.
Folder custom - I have it is always empty, no bed there.
4.
Folder, license in it:
device.nng - navigator itself creates.
GENERIC_iGO8_WorldWide@801Product.lic - Are included with the program, additional pumping is not necessary.
LCP_43J_FEU @ 0807_ (NNG + TA_HUN_TMC). Lic - Are included with the program, additional pumping is not necessary.
5.
Folder save - will create itself, and itself will write, do not touch.
6.
branding.zip and data.zip - these files store settings screen sizes, graphics and things.
As standard data is laid out in a cap and branding files under a resolution of 320x240, 480х272 and 480h234, if you have a pda and other navigator with an unusual resolution, download files iGO data.zip v10b (see hat themes)
7.
gpstmc.dll - some sort of a library, as the name for the module TMC, I have not, so do not know, maybe it's worth it and remove
8.
iGO8.exe - the main file in the program, he'd run at update programs is sometimes missing, simply replace it and enjoy
9.
sys.txt - more about it can be read in the cap.
10.
tahoma.ttf
tahomabd.ttf
This font)) will not touch them.
Well, like everything, good luck to you  ;)
jammpoo
VIP เมื่อ 30/09/2009
ID number: 765
กระทู้: 85
Send Money to jammpoo
-ได้ให้: 95
-ได้รับ: 75
« ตอบ #1 เมื่อ: 13 ตุลาคม 2009, 23:16:39 »
สงสัย โดนถามบ่อย อิอิ
« ตอบ #2 เมื่อ: 14 ตุลาคม 2009, 05:25:09 »
ได้ความรู้อีกเยอะเลย Grin
e20wac
ID number: 138
กระทู้: 73
Send Money to e20wac
-ได้ให้: 54
-ได้รับ: 68
« ตอบ #3 เมื่อ: 14 ตุลาคม 2009, 07:39:38 »
ความรู้ทั้งนั้น มือใหม่ขอเซฟก่อนละกันครับ
kaew1995
ID number: 1546
Send Money to kaew1995
-ได้ให้: 38
« ตอบ #4 เมื่อ: 16 ตุลาคม 2009, 13:09:09 »
ขอบคุณครับ ขอศึกษาก่อนครับ
Navi743, Asus P750
aekhiggin
ขอขอบคุณบ้านหลังนี้ที่ให้ความรู้ดีๆๆเสมอมาครับ
ID number: 1644
กระทู้: 104
Send Money to aekhiggin
-ได้ให้: 90
-ได้รับ: 34
« ตอบ #5 เมื่อ: 18 ตุลาคม 2009, 09:30:01 »
สุดยอดเลย กำลังอยากศึกษา PNA พอดีเลยครับ
ขอบคุณมากๆครับ มีประโยชน์มากๆครับ
boycom
ID number: 303
กระทู้: 163
Send Money to boycom
-ได้ให้: 115
-ได้รับ: 223
« ตอบ #6 เมื่อ: 19 ตุลาคม 2009, 01:35:45 »
ดีครับ จะได้รู้มากขึ้นไปอีก
EG6NA
ID number: 1295
Send Money to EG6NA
-ได้ให้: 51
« ตอบ #7 เมื่อ: 19 ตุลาคม 2009, 10:44:57 »
มีประโยชน์ สำหรับมือใหม่ ยกให้เลย ครับ
nuwat
ID number: 1727
Send Money to nuwat
« ตอบ #8 เมื่อ: 20 ตุลาคม 2009, 15:58:31 »
ต้องขาย GPS 4.3''
ต้องขาย GPS BT 4.3''
ต้องขาย GPS BT 5"
ตั้งขายของผิดห้อง แบน 2 วันครับ ถ้ามีแบบนี้อีกครั้ง แบนถาวร  :(
lowol
VIP เมื่อ 22-10-2009
ID number: 1763
กระทู้: 21
Send Money to lowol
-ได้ให้: 18
« ตอบ #9 เมื่อ: 25 ตุลาคม 2009, 21:08:34 »
กำลังงงอยูพอดี ขอบคุณครับ
bow110
ID number: 967
กระทู้: 37
Send Money to bow110
-ได้ให้: 86
-ได้รับ: 35
« ตอบ #10 เมื่อ: 26 พฤศจิกายน 2009, 23:15:27 »
ขอบคุณสำหรับความรู้ครับ
teeratoy2002
ID number: 2581
Send Money to teeratoy2002
« ตอบ #11 เมื่อ: 29 พฤศจิกายน 2009, 17:25:05 »
มีประโยชน์มาก ๆ สำหรับมือใหม่ ที่ชอบช่วยตัวเอง (มากกว่าถามคนอื่น) อย่างผมเป็นต้น ขอขอบคุณ
 ค้นหา >:(
kiamuar
ID number: 156
กระทู้: 47
Send Money to kiamuar
-ได้ให้: 29
-ได้รับ: 53
« ตอบ #12 เมื่อ: 07 ธันวาคม 2009, 12:28:06 »
พวกแป้นพิมพ์ไทย อังกฤษ  อยู่ตรงไหนครับ
ในเครื่องไม่มีแป้นพิมพ์ไทย มีแต่อังกฤษ ฮังการี ฮิบรู สงสัยมือซน เผลอไปลบคีย์ไทยออก
ต้องใส่คีย์ไทยเพิ่มหรือว่าต้องไปปรับตั้งค่าตรงไหนครับ  ค้นหา
« แก้ไขครั้งสุดท้าย: 07 ธันวาคม 2009, 19:56:52 โดย kiamuar » บันทึกการเข้า
SimonR
GooD DaY
ID number: 2640
กระทู้: 22
Send Money to SimonR
« ตอบ #13 เมื่อ: 17 ธันวาคม 2009, 22:07:51 »
รู้เพิ่มขึ้นอีกนิสสส
wwasin
ID number: 3372
Send Money to wwasin
« ตอบ #14 เมื่อ: 24 ธันวาคม 2009, 15:34:13 »
เวลาที่ edit skin iGo กัน (แก้ไขไฟล์ gro อ่ะครับ)
ไม่ทราบว่าใช้โปรแกรมอะไรกันหรอครับ??
ลอง Google อยู่นานสองนานหาไม่เจอสักทีครับ T___T
อยากจะลองแก้ๆเอาเองดูบ้าง เอาแต่ขอคนอื่นคงไม่รุ่ง ฮีๆ
ปล.ถามอีกนิดนึงครับ
ไฟล์ poi ไฟล์ map (fbl) เราสามารถมีหลายๆอันไว้ใน folder นั้นๆได้หรือไม่ครับ?
ถ้าได้แล้วมันจะโชว์ของทุกไฟล์ขึ้นมาหมดเลยหรือเปล่าครับ
ถ้ามันโชว์ได้อย่างงั้นมันต้องทำให้เครื่องอืดขึ้นแน่ๆเลย
ไม่รู้เข้าใจถูกหรือเปล่า
ขอบคุณคร้าบบบบ >__<
ปล2. ขอแก้ไขนิดนึง
พอดีผมใช้ iPod Touch อยู่ครับ File iGo จะเป็น .gro
« แก้ไขครั้งสุดท้าย: 24 ธันวาคม 2009, 15:39:01 โดย wwasin » บันทึกการเข้า
fone
ID number: 1669
Send Money to fone
« ตอบ #15 เมื่อ: 26 ธันวาคม 2009, 14:41:50 »
ความรู้เพียบ ขอเก็บอิอิ Grin Grin Grin
NIKOM
ID number: 3872
Send Money to NIKOM
-ได้ให้: 27
« ตอบ #16 เมื่อ: 08 มกราคม 2010, 20:55:01 »
หาได้ครบแล้ว แต่ไม่ตรงตามรูป แต่มันใช้ได้ เหมือน นิ หรือว่าต้องให้ตรงตามรูป ถึง เนียนสุด หรือเปล่า คับ
« แก้ไขครั้งสุดท้าย: 12 มกราคม 2010, 16:06:31 โดย NIKOM » บันทึกการเข้า
หนุ่ม เก็บตะวัน
ID number: 3634
กระทู้: 99
Send Money to หนุ่ม เก็บตะวัน
-ได้ให้: 91
-ได้รับ: 80
« ตอบ #17 เมื่อ: 25 มกราคม 2010, 19:42:13 »
ได้ความรู้ดีๆ อย่างนี้ ต้องลองเข้าไปเล่นแล้ว
neoxc
ID number: 3859
Send Money to neoxc
-ได้ให้: 13
-ได้รับ: 15
« ตอบ #18 เมื่อ: 29 มกราคม 2010, 23:32:58 »
เอา amigo ด้วยสิกำลัง งง เรื่อง poi
Mikoshib@
ID number: 5010
Send Money to Mikoshib@
« ตอบ #19 เมื่อ: 14 กุมภาพันธ์ 2010, 23:37:27 »
ความรู้ทั้งนั้น...
หน้า: [1] 2   ขึ้นบน
คลองถม - Navthai
eak_1v 59 59698 กระทู้ล่าสุด 17 เมษายน 2012, 09:21:46
โดย tong999
watcharapol_k 8 22041 กระทู้ล่าสุด 28 มิถุนายน 2010, 23:29:25
โดย NungS
อยากได้ IGO8.3
tu3571138 5 5098 กระทู้ล่าสุด 24 มกราคม 2018, 00:31:12
โดย khigiam
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.11 วินาที กับ 92 คำสั่ง
