05 มิถุนายน 2024, 05:32:24 *
ผู้เขียน หัวข้อ:  diMka WertVRV 1.1.25.5 Skin for iGo8.3x (08.10.09)  (อ่าน 16925 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 09 ตุลาคม 2009, 00:30:22 »
diMka by WertVRV
WertVRV : 1.1.25.5 : 240x320, 320x240, 240x400, 400x240, 400х234, 416х234, 480х272, 480x234, 800х480, 480х800
diMka WertVRV 1.1.25.5  for 8.3.x (8.3.1, 8.3.2, 8.3.4)
1. Changes in the fuel calculator (added choice - intermediate point / finish).
2. Improved the search (filter name) on the history list (now, after exit the list filter is set to zero).
3. Corrected list of possible values of the camera while editing / creating the camera through the menu cursor (delete the value "75" - in the scripts озвучки no such rate) (it will be necessary to reconfigure the values for the so-called "hot" buttons speed).
4. Improved the voice Event Driver Alerts (for "narrow" permits with one column displaying signs voice was the appearance marks the second "invisible" speakers + more in some cases had extra sounds).
5. Improved the display of the sign of the speed limit for the camera like "Tunnel" (not displayed).
6. Fixed shutdown "Avtopererascheta route" after the use of simulation through a brief menu button.
7. Minor corrections in alignment of the text.
Only with ver.8.3.x.(8.3.1, 8.3.2, 8.3.4)
Two variants of compatibility skin with version 8.3.4:
 - We use data.zip from version 8.3.2 (anything in it not changing) and we use skin (anything in it not changing).
Use in sys.txt:
skin="ui_igo8"
 - We use data.zip from version 8.3.4 (anything in it not changing) and we use skin (in skin (in zip-archive) necessarily we rename the folder ui_igo8 to ui_igo8_da).
Use in sys.txt:
skin="ui_igo8_da"
Download -->
Very Thank  : WertVRV , dima8389 , Andron66
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
-ได้ให้: 829
-ได้รับ: 10413
« ตอบ #21 เมื่อ: 20 ตุลาคม 2009, 18:36:31 »
หน้าจะไม่ได้ครับ
แล้วหลัง เปลี่ยนได้มั้ยครับ    Grin
แซวเล่นเฉยๆ นะคร้าบ พี่ stemcell สุดหล่อ   ^-^
ว่าแต่ว่า ทำไม พักนี้ skin for amigo  เงียบๆ ไป   เดี๋ยวต้องส่ง อีแมว ( email ) ไปกระตุ้นสักหนอ่ย    Grin
- หลังก็เปลี่ยนไม่ได้  :'( จำไว้เอกจำไว้
« ตอบ #22 เมื่อ: 20 ตุลาคม 2009, 18:51:12 »
 Cheesy โอ๋ๆๆ  เดี๋ยวจะให้ พี่อั๋น พา พี่ อรรจ ไป ลั้ลลา......................... นะครับ โย่ โย่   ^-^
diMka WertVRV 1.1.34 Skin for igo 8.3.xx (23-02-2010)
₪๐StemCell๐₪ 5 7042 กระทู้ล่าสุด 01 พฤษภาคม 2010, 15:50:59
โดย fairy
Skin diMka by WertVRV _k63_compass
tin_43257 1 3270 กระทู้ล่าสุด 02 เมษายน 2010, 13:29:45
skin for igo8 diMka by WertVRV v 1.1.36_k63_UFO 11/04/2010
tryth 0 3099 กระทู้ล่าสุด 12 เมษายน 2010, 09:31:08
โดย tryth
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.028 วินาที กับ 41 คำสั่ง
