04 มิถุนายน 2024, 02:35:17 *
ผู้เขียน หัวข้อ:  diMka WertVRV 1.1.34 Skin for igo 8.3.xx (23-02-2010)  (อ่าน 7034 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 23 กุมภาพันธ์ 2010, 21:53:10 »
What Fix What New
1.1.34 for 8.3.h (8.3.1, 8.3.2, 8.3.4)
Transformed algorithm of visual and audible warnings of cells (full transition to the lists (userlists)), thus significantly reduce the code and add the following:
   1. Separate settings visual warning (camera), regardless of the sound (before the camera could only be completely off);
   2. Separate volume settings for sound excess (relevant for situations where the volume of voice packets and sound exceeding different; earlier volume had in common with a voice warning);
   3. Ability to work with different profiles, the camera settings (for example: a separate profile for the city, highway, etc.):
      - 4 your profile (you can change the names) switchable settings;
      - Profile includes all camera settings (the settings approach, excess, visual and voice warning systems (including language), setting sensing range, etc.);
      - All settings editable in the current profile is automatically saved;
      - The possibility of sequential switching profiles in the cab (short button menu) and the intro (long press on the icon of the current chamber), followed by the name of a new indication profile.
The option of setting sensing range for the camera 4 types (Directions to the red light).
Many additional technical fixes (t.ch.para minor inaccuracies) in the Chambers.
Fixed a few pictures (thanks Andron66 and dima8389).
Very thanks Andron66 and dima8389 and WertVRV
Skin diMka for 480h234, 320x240, 240x320, 240x400, 400x240, 480x272, 400h234, 416h234, 480x800, 800x480 (only for version 8.3.h (8.3.1, 8.3.2, 8.3.4)).
Current version 1.1.34
Do not forget to say thanks:
dima8389 - author of the original skin di / \ / \ ka.
Andron66 - a huge contribution to the graphics (bmp-files) of the skin.
Important: Work with Driver Alerts and Truck Profiles (8.3.4):
Skin (version 1.1.25.2) is compatible with version 8.3.4 exe.
Two variants of the skin (version 1.1.25.4) with version 8.3.4:
1) use data.zip from version 8.3.2 (nothing in it is not changing) and use the skin (nothing in it is not changing)
Do not forget to sys.txt (unless stated in [project] name):
skin = "ui_igo8"
2) use data.zip from version 8.3.4 (nothing in it without changing) and use the skin (in the skin (inside the zip-archive) rename the folder ui_igo8 on ui_igo8_da).
skin = "ui_igo8_da"
Important: User WVGA-device (480h800, 800x480):
Skin (starting with version 1.1.25) supports two modes of operation:
- 240х400, 400h240
- 480h800, 800x480
In both modes, images of buttons, menu items, and other screen elements are the same (in the high quality display).
In the first version of the skin works with the card size 240х400 (400h240), the second - with a card size 480h800 (800x480), respectively, the second option requires more memory.
So which mode to use the skin, it is necessary to identify yourself.
For devices (480h800, 800x480) to specify the permissions in this section sys.txt enough (nothing more (resolution_dir, screen_x, screen_y) regarding the resolution and screen size, in principle, not necessary):
autoconfig = 1
highres = 1, (1 - mode 240х400, 400h240, 0 - mode 480h800, 800x480).
And, if you do not use the above (deprecated) resolution_dir, screen_x, screen_y, then in each of the modes (240х400-400h240 and 480h800-800x480), portrait-landscape switching is possible from the menu (Settings-Device orientation).
<-- Download
« แก้ไขครั้งสุดท้าย: 23 กุมภาพันธ์ 2010, 22:42:05 โดย ₪.StemCell.₪ » บันทึกการเข้า
-ได้รับ: 69260
« ตอบ #1 เมื่อ: 24 กุมภาพันธ์ 2010, 05:18:58 »
มี skin ใหม่ ๆ มาให้ลองอีกแล้ว....
ขอรับไปลองนะครับ  Roll Eyes
komturbo
ID number: 774
กระทู้: 69
Send Money to komturbo
-ได้ให้: 155
-ได้รับ: 72
« ตอบ #2 เมื่อ: 24 กุมภาพันธ์ 2010, 07:35:18 »
สวยดี น่าใช้ ต้องเก็บไปลองดู
supote
x1x1
ID number: 191
กระทู้: 595
$600.00 credits
Send Money to supote
-ได้ให้: 1669
-ได้รับ: 1682
« ตอบ #3 เมื่อ: 24 กุมภาพันธ์ 2010, 11:25:06 »
เห็นความสวยงามแล้ว  ยังไงก็ต้องขออนุญาตเก็บสะสมไว้ก่อนแล้วครับ  ขอบคุณครับ
sax
ID number: 27
กระทู้: 250
$2461.00 credits
Send Money to sax
-ได้ให้: 590
-ได้รับ: 222
« ตอบ #4 เมื่อ: 24 กุมภาพันธ์ 2010, 13:41:01 »
สวยงามจริงๆ ต้องลองเอาไปใช้กับscheme XERES ที่มีauto changer คงสวยงามมากๆ ร่าเริง
fairy
ID number: 4926
Send Money to fairy
-ได้ให้: 34
« ตอบ #5 เมื่อ: 01 พฤษภาคม 2010, 15:50:59 »
ขอบคุณมากๆครับ ขอลองเอาไปใช้ดูครับ
Warn....กรุณาอ่านกฎกติกาก่อน post ด้วยนะคะ
« แก้ไขครั้งสุดท้าย: 01 พฤษภาคม 2010, 19:05:34 โดย tin_43257 » บันทึกการเข้า
diMka WertVRV 1.1.25.5 Skin for iGo8.3x (08.10.09) « 1 2 »
₪๐StemCell๐₪ 21 16906 กระทู้ล่าสุด 20 ตุลาคม 2009, 18:51:12
โดย eak_1v
Skin diMka by WertVRV _k63_compass
tin_43257 1 3265 กระทู้ล่าสุด 02 เมษายน 2010, 13:29:45
skin for igo8 diMka by WertVRV v 1.1.36_k63_UFO 11/04/2010
tryth 0 3094 กระทู้ล่าสุด 12 เมษายน 2010, 09:31:08
โดย tryth
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.088 วินาที กับ 51 คำสั่ง
