28 มีนาคม 2024, 23:13:24 *
ผู้เขียน หัวข้อ:  igo8 v8.3.4.102680 for htc hd2  (อ่าน 6022 ครั้ง)
กระทู้: 13113
-ได้รับ: 72076
« เมื่อ: 04 มีนาคม 2010, 10:19:18 »
iGO8 8.3.4.102680 (AUG 09)
Requirements: Windows Mobile, operating system 300 MHz processor, 64 MB memory, all resolutions incl 800x480 + 480x800
Overview: GPS Navigation Software for Windows Mobile based PDA/PNA devices and Smartphones
http://www.navngo.com/pages/global/eng/igo_8_description
Download Instructions:
Navigation software only - patched navigation software excluding the Content (edited sys.txt + data/branding.zip for htc hd2)
ดาวน์โหลด
Installation Instructions
stage1. Unzip the content to your SD Card, if installed download "1". skip to stage3
stage2. if downloaded, download "2" add the map, poi, building, voices, lang you want to use to the content folder on the SD card
stage3. Launch the application either from the File Explorer or create a Program Shortcut to ur startmenu
**first time boot will take bit longer than normal as of the vast speed camera/poi e.c.t....every other boot after should take less than 4second and 1~2sec to connect indoor**
"Program application database cannot be found. Please Insert original SD card."
Ok i have renamed folder to igo8 and i still get this error when trying to start the software ? i have diamond any ideas please
Ok for HTC diamond this is the solution to make it work
1/ Unzip the content to PC
2/ Locate the sys.txt file and open it in notepad it will look like this
[device]
type="HTC Touch HD T8282"
[folders]
app="%SDCARD%/iGO8"
skin="ui_igo8"
maxzoom2d=6000000
show_exit=1
3/ Edit the sys.txt to this :
type="HTC Touch Diamond P3700"
[folders]
app="Internal Storage/iGO8"
skin="ui_igo8"
maxzoom2d=6000000[device]
show_exit=1
Don't touch anything else just whats shown all  other settings are fine
4/save the sys.txt and copy it back to the iGO8 folder your all done it should now work Smiley
"ผัดสะตอกุ้งสด iGO8.3.4.102680" สำหรับ PNA\PDA « 1 2 ... 16 17 »
narong9000 320 277803 กระทู้ล่าสุด 26 พฤษภาคม 2014, 18:53:46
โดย a_kapop
Novox 11 11634 กระทู้ล่าสุด 25 กรกฎาคม 2011, 14:42:10
โดย suphawat
yut4888 7 6239 กระทู้ล่าสุด 12 มิถุนายน 2010, 15:13:43
โดย q471000
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.056 วินาที กับ 36 คำสั่ง
