27 เมษายน 2024, 23:15:07 *
ผู้เขียน หัวข้อ: [ทั่วไป] มา Clean up มือถือของคุณด้วย Startup Manager (Full Version) v3.3  (อ่าน 3970 ครั้ง)
« เมื่อ: 20 มกราคม 2012, 03:34:39 »
Requirements: Android 1.6+
Overview: Startup Manager - Clean up Your Android System from System Startup
Startup Manager supports android 1.6, 2.0, 2.1, 2.2(froyo), 2.3(gingerbread) and 3.x (honeycomb) devices.
Startup Manager aims at helping disable/enable startup items from system boot for Android devices including smartphones and tablets. To disable an item from system
startup, uncheck the application from the list (recheck to restore and it will start again). For other item that do not start with system boot, please use "Customize" to add and enable it to start with system boot.
User tab shows all the user applications that have restart function. You can uncheck them all to enhance system startup speed. Long tap an app name will give you access to enable/disable, read application info about, uninstall the app and search the app in Android Market.
System tab shows all the system processes that start with system boot. Some processes may not be necessary to start due to our using habits and preferences. Please uncheck these processes only if you know well about the effects of disabling them.
If you want to add a new item that does not start with device boot, Customize is the best choice.
Besides features above, from Startup Manager Menu - settings you can also select if you want to calculate system startup time and disable system boot sound.
If you have any questions about the applications, please use the email developer link below to get in touch with us.
Note: For android 2.2 and higher OS non-rooted devices, some processes will restart themselves right after being disabled.
Product Features:
- Master of Android system's startup entry management
- Intelligently analyze and monitor all system startup entries (include user applications and system processes) in the background
- Safely disable any undesired application or process from auto-startup at device boot
- One click to view detailed properties for each startup entry
- Disabled startup entries are stored for future restoration
- Add your favorite applications (including 3rd party user apps or system apps) to system startup
https://mark...manager.full
ลองเอาไปใช้กันดูนะครับ  Roll Eyes
ลิงค์อยู่นี่ครับ  Smiley
Very thank chathu_ac   สำนึกผิด
gew_sbc
ID number: 32411
Send Money to gew_sbc
« ตอบ #1 เมื่อ: 02 กุมภาพันธ์ 2012, 14:30:09 »
ต้อง root.เครื่อง มั้ย ครับ Smiley
« ตอบ #2 เมื่อ: 02 กุมภาพันธ์ 2012, 22:00:28 »
ไม่จำเป็นครับ  Smiley
PV:: startup.raw ใช้อะไรสร้าง/แปลง ครับ
bpkgps 7 3761 กระทู้ล่าสุด 07 มกราคม 2010, 00:33:09
วิธีการทำ Startup.raw สำหรับเครื่อง PV
ที-เร็กซ์ 10 8233 กระทู้ล่าสุด 21 มกราคม 2010, 18:35:09
โดย oscar
Yamicsoft Windows 10 Manager 1.0.0 Full โปรแกรมจัดการ Win 10 ตัวใหม่
Other Software (PC)
nsukomon 3 6732 กระทู้ล่าสุด 21 ตุลาคม 2015, 09:45:54
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.085 วินาที กับ 42 คำสั่ง
