29 เมษายน 2024, 18:06:28 *
ผู้เขียน หัวข้อ:  Garmin HomePort v2.0.1  (อ่าน 5160 ครั้ง)
« เมื่อ: 27 ตุลาคม 2009, 16:46:52 »
Before heading out on the open water, plan your voyage with HomePort — marine trip-planning software¹ that lets you plan and organize routes from the convenience of your computer.
Use your existing BlueChart® preprogrammed card, or transfer the preloaded maps² directly from your chartplotter to an SD™ card. Then simply plug the card into your computer's card reader to start planning your voyage.
Navigating waters with no visible landmarks or shallow shorelines can be a daunting task for even the most experienced navigator. With your existing BlueChart data together with HomePort on your computer, you’ll have the ability to view map details such as underwater hazards and hidden obstacles and plan a route to avoid them.
HomePort also offers features such as depth profiles, distance and bearing measurements, and tidal predictions.
Manage Your Data
In addition to managing waypoints, routes and tracks, you can store information from past voyages right on your computer. HomePort will also help you create point-to-point routes, determine fuel usage and estimate your travel time for each leg of your route — saving you time and money.
View Marine Charts
It’s easy to browse and view chart detail on your computer screen and mark waypoints and other points of interest. When finished, send the data to an SD card or proprietary Garmin datacard to load into your compatible Garmin chartplotter or sounder.
HomePort is compatible with BlueChart, BlueChart g2 and BlueChart g2 Vision navigation charts. It is currently only compatible with Windows® operating systems.
¹HomePort software does not include map data, and is only available in English.
²Inland Lakes software is not compatible with HomePort. If using a device preloaded with Inland Lakes software in conjunction with BlueChart g2 and g2 Vision pre-programmed cards, only the pre-programmed cards are compatible.
« ตอบ #1 เมื่อ: 27 ตุลาคม 2009, 20:45:32 »
โปรแกรมนี้ไว้ทำอะไรครับ
ใช้อย่างไรบ้าง?รบกวนช่วยแนะนำด้วย
ผมไม่ค่อยคล่องภาษาต่างประเทศ
Pega
s4s3s2...
ID number: 5
กระทู้: 461
$5.70 credits
Send Money to Pega
-ได้ให้: 594
-ได้รับ: 883
« ตอบ #2 เมื่อ: 27 ตุลาคม 2009, 21:09:11 »
Port = ท่าเรือ
Blue Chart  เกี่ยวกับสีน้ำเงิน น่าจะเป็นน้ำทะเล  น่าจะเป็นแผนที่ทางทะเลมั้งครับ  ;)
grids
VIP เมื่อ 16-10-2009
Lifetime s8
ID number: 48
กระทู้: 58
Send Money to grids
-ได้ให้: 122
-ได้รับ: 162
« ตอบ #3 เมื่อ: 28 ตุลาคม 2009, 08:07:48 »
ไม่ถนัดเหมือนกันครับ เท่าที่ลองดูตัวนี้เป็น Bule Chart ที่ใช้วางแผนการเดินทางทางน้ำครับ โดยจะมีแผนที่ทางน้ำให้เราวางแผนการเดินเรือ ซึ่งสามารถใส่ข้อมูลอัตราการสิ้นเปลืองของเรือได้ และโปรแกรมจะบอกว่าในแต่ละ route ที่เราวางไว้จะถึงไหนเวลาไหน ใช้น้ำมันไปแล้วเท่าใดครับ และ Export ออกมาเป็น track เอาไปใช้ได้เลย แต่ตัวนี้เท่าที่ลองเมื่อเช้าจะไม่สามารถ export แผนที่ออกมาให้ด้วย แต่ถ้่าเป็น Map Sourse จะเลือกได้ครับ
ninyo
ID number: 2556
Send Money to ninyo
« ตอบ #4 เมื่อ: 21 กุมภาพันธ์ 2010, 16:08:05 »
THK ครับ
« ตอบ #5 เมื่อ: 21 กุมภาพันธ์ 2010, 16:15:07 »
THK ครับ
เป็นน้องใหม่ลองอ่านกฎกติกาง่ายๆ ของเว็บก่อน post ดีกว่ามั๊ยคะ  ที่นี่มี  redcard redcard ไว้แจกเพียบมากกว่าในสนามอีกนะคะ
มด [tewbc]
H/W & S/W Guru
ID number: 538
$2000.18 credits
Send Money to มด [tewbc]
-ได้ให้: 183
-ได้รับ: 2228
« ตอบ #6 เมื่อ: 21 กุมภาพันธ์ 2010, 22:52:00 »
โอ้....น่าสนใจดีมากพี่ แต่ผมไม่มีเรือให้จอดเทียบท่าครับกระผม  ว๊าก น่าจะมี xxx HomeGarage มั่งอ่ะ  Cheesy
phakboong
ID number: 13
กระทู้: 293
$5005.03 credits
Send Money to phakboong
-ได้รับ: 418
« ตอบ #7 เมื่อ: 11 พฤษภาคม 2010, 13:32:19 »
แล้วอันนี้ละครับ เป็นอย่างไร
offshore
VIP เมื่อ 21-10-2009 2Y
ID number: 1621
กระทู้: 61
$160.00 credits
Send Money to offshore
-ได้ให้: 355
-ได้รับ: 59
« ตอบ #8 เมื่อ: 31 กรกฎาคม 2010, 22:59:08 »
มาช้าอีกแล้วเรา d/l ไม่ได้แล้วครับ มี link ใหม่หรือเปล่า  Kiss
Garmin Nuvi กำลังจะมี AV-in รองรับต่อกล้องมองหลัง GARMIN nüvi® 2575
Garmin Discussion
siea 1 3962 กระทู้ล่าสุด 24 มิถุนายน 2011, 15:46:08
โดย trvoy
Garmin Traffic Receivers GTM? 35 แสดงข้อมูลจราจร ร่วมกับ Garmin GPS
คลองถม - Navthai
pexi747 0 5539 กระทู้ล่าสุด 03 เมษายน 2012, 19:56:47
โดย pexi747
Garmin เตรียมเปิดตัวAppบน iPhone กับ Garmin Navigation ในเวอร์ชั่นภาษาไทย « 1 2 3 4 »
GPS-News!!
^SuRaYoOt^ 72 48853 กระทู้ล่าสุด 12 เมษายน 2013, 09:18:40
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.107 วินาที กับ 59 คำสั่ง
