26 เมษายน 2024, 21:59:52 *
ผู้เขียน หัวข้อ:  สุดยอด แอนดรอยด์ app อเนกประสงค์ Elixir v1.12.4 (Full) Update v2.40  (อ่าน 15638 ครั้ง)
« เมื่อ: 07 กรกฎาคม 2011, 00:23:56 »
Requirements: for all Android versions
Overview: Elixir is a system information application with highly configurable widgets. Displays information about battery, cpu usage, memory usage, internal and external storage (sd-card), display, wifi, mobile network, location services (gps), bluetooth, sync, airplane mode, sensors, etc.
* multiple widget sizes, each can be disabled at Settings
* small widget icons, up to 7*7 icons per screen.
* every widgets are configurable (Menu/Widgets)
* every icon can be customized (Menu/Tips&Tricks/Customize icons)
* export/import widget definitions
* running processes/services/tasks
* statusbar icons: battery, cpu
* generating html report
Widget icon types:
* battery
* battery current
* battery temperature
* cpu usage
* cpu frequency
* running application count
* date
* time
* next alarm time
* external storage
* internal storage
* memory
* mobile signal strength
* mobile traffic
* wifi signal strength
* wifi traffic
* airplane mode switch
* auto-rotate switch
* auto-sync switch
* sync switch
* bluetooth switch (2 or 3 state)
* gps switch (not avaible in 2.3)
* mobile data switch (APN switch, read Tips&Tricks)
* wimax (4g) switch for EVO
* wifi switch
* wifi hotspot switch
* mute switch
* ringer mode switch: normal, silent, vibrate
* speakerphone switch
* auto brightness switch
* brightness switch with configurable levels
* screen switch
* screen timeout switch with configurable levels
* lock switch
* edit widget mode switch
* application launcher
* shortcut: bookmark, contact, setting, ...
Elixir Personal Add-on:
- Gmail unread count widget for multiple accounts
- Sms unread count widget
- Missed calls widget
- Contact widgets. If you click on a contact picture, you can easily view contact, send an email, sms or make a call
Please read Menu/Tips & Tricks.
- Contact direct dial
- Contact direct message
Languages:
- english
- magyar
- pусский
You can make translation at:
http://crowd...oject/elixir
FAQ:
- "Edit" labels everywhere: turn "Edit widget mode" off at Elixir/Menu/Settings or by "Edit widget mode switch" widget icon.
- "-elixir" suffix at APN settings: read Menu/Tips&Tricks/Mobile data switch
- "Uninstall not successful": turn "Device administrator" off at Elixir/Menu/Settings
If you have any problem with the application please write
an email to bartadev@gmail.com, so I can ask if I have questions. I cannot help if you write only a comment.
You can Donate the app at Menu/About/Donate.
If you like it, like the facebook site for news: http://www.f...000368307643
Recent changes:
New info:
- System / More information / Build / ROM
- Wifi / More information / Hostname
- Battery / More information / Level and Scale
Fixes:
- mobile and phone type refreshes in the main screen
- Contact widget fix
- Wifi AP switch extra permission, it is needed on some devices
Other:
- Menu/More/Uninstall to help uninstall
Note:
No ads.
http://www.a...droid.elixir
โปรแกรม สุดแหล่ม เอนกประสงค์อีกตัวนึงครับ ครบเครื่องจริงๆ ลองโหลดไปใช้ดูนะครับ  Smiley
ลิงค์ครับ  Roll Eyes
vert thank infinitely  สำนึกผิด
« ตอบ #1 เมื่อ: 20 เมษายน 2012, 04:45:19 »
Update Elixir 2 v2.16
What's in this version:
Recent tasks: new screen; new option in running applications widget; new recent application widget
Stay awake: new stay awake toggle with wake lock feature; available for widgets, profiles and device information screen
New refresh widget toggle with the option to refresh the current widget or every widgets
Usb tethering toggle fix for ICS using the system add-on
Other small changes, bugfixes (sd mount toggle)
More: http://bartat.hu
ลิงค์ครับ  Smiley
gboygang
ID number: 20025
Send Money to gboygang
« ตอบ #2 เมื่อ: 06 พฤษภาคม 2012, 12:22:28 »
สุดยอด เก็กหล่อ
 เตือนครั้งที่ 1 กลับไปอ่านกฎกติกาเวบด่วน โพสต์มั่ว ๆ อีกจะระงับการโพสต์
« ตอบ #3 เมื่อ: 17 พฤศจิกายน 2012, 16:11:02 »
Update Elixir 2 v2.27.1
- NFC toggle (opens the settings screen)
- Lock toggle can work with pin/password protection (admin add-on is needed)
- Software info screen: new accessibility, drm and media effects rows; rows can be hidden
- Uninstall and Add-ons screens are merged
- Profiles: enable/disable application action (works only on rooted devices)
- Support of Relative humidity sensor
- Displays new information available from ICS
- Other small changes and bugfixes (gps toggle)
Check: Elixir for Android for more
ลิงค์ครับ  Smiley
yoke391
ID number: 33905
Send Money to yoke391
« ตอบ #4 เมื่อ: 08 ธันวาคม 2012, 21:29:23 »
 สะใจจริง ๆ
thank   you
 อ่านกฎของเวบด่วน อย่าโพสต์แบบนี้
« ตอบ #5 เมื่อ: 19 มกราคม 2014, 17:41:27 »
ไม่ได้อัพเดทกันซะนาน มาอัพเดทกันครับ  Grin
Update Elixir 2 Donate v2.36.1
Recent changes:
- Icon pack can be set for every widget
- Stay awake toggle is available for rooted devices from Android 4.2
- External storage usage can be displayed in statusbar icon
 - Toggle NFC directly from device information screen
- Slovenian language
- Other fixes and changes
 Visit Website
 Less description »
Note: all premium features available. no key file needed.
ลิงค์ครับ  Ok
« ตอบ #6 เมื่อ: 18 มิถุนายน 2014, 06:27:50 »
Update Elixir 2 Donate v2.37.4
What's New
- New toggle: Location mode toggle from Android 4.4
- New widget: CPU temperature if available
- Ringtone toggle: can change ringtone for streams alarm, notification and ring
- CPU information displays CPU temperature if available
- New widget serialization to fix "Tried to marshall a Parcel" error
ลิงค์ครับ  Ok
« ตอบ #7 เมื่อ: 23 สิงหาคม 2014, 03:40:09 »
Update Elixir 2 Donate v2.37.6
ลิงค์ครับ
« ตอบ #8 เมื่อ: 21 ธันวาคม 2014, 06:19:48 »
Update Elixir 2 Donate v2.38.1
What's New:
- Widgets: 3x5, 5x3 layouts
- Widgets: new option to show/hide text shadow
- Screen timeout toggle fix: "never" works again
- Running processes screen: text filter works for pid
- Android 5.0 fix: Mobile data toggle (root needed)
- Android 5.0 fix: GPS toggle
- Android 5.0 fix: Reboot toggle
- Android 5.0 fix: Flashlight toggle
- Android 5.0 fix: Running application screens and widgets
- Other fixes
* Donate/pro features are unlocked. No key needed!
ลิงค์ครับ  Ok
« ตอบ #9 เมื่อ: 10 กรกฎาคม 2015, 21:01:57 »
ไม่ได้อัพเดทมานานเลยสำหรับโปรแกรมนี้
มาอัพเดทเวอร์ชั่นล่าสุดกันเลยครับ  เก็กหล่อ
Update Elixir 2 Donate v2.38.3
What's New
- Android 5.0 fix: Running tasks screen is not available
- Contact menu: phone number type fix
- APN selector toggle: fix of not showing icon
ลิงค์ครับ  Ok
« ตอบ #10 เมื่อ: 02 ธันวาคม 2015, 04:08:36 »
Update Elixir 2 Donate v2.39.1 (+Addons & Widgets)
What's New
ิลิงค์ครับ  เก็กหล่อ
« ตอบ #11 เมื่อ: 24 มิถุนายน 2016, 15:09:24 »
ไม่ได้อัพเดทมานาน มาอัพเดทกันครับ
Elixir 2 Donate v2.40 (+Addons & Widgets)
WHAT'S NEW
- Settings: CPU temperature multiplier
- Wifi AP toggle is not available from Android 6.0
- Android 6.0: Lock toggle change; Bookmarks isn’t available
- Android 6.0 fix: Permission handling for system settings and storage
ลิงค์ครับ  เก็กหล่อ
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.313 วินาที กับ 51 คำสั่ง
