25 เมษายน 2024, 06:38:56 *
หน้า: 1 ... 3 4 [5]   ลงล่าง
ผู้เขียน หัวข้อ:  Titanium Backup PRO v3.8.2 UPDATE 7.3.0.2 PRO For ROOT Only  (อ่าน 72365 ครั้ง)
« เมื่อ: 26 พฤษภาคม 2011, 01:53:07 »
Titanium Backup PROv3.8.2
Requirements: Android 1.5+
Overview: EXTREMELY powerful tool. Backup ALL apps, Market links, remove bloatware & MORE!
?Over 1.5 million users, 21+ languages!
?Needs ROOT, Android 1.5-3.1+
?Problem? See matrixrewriter.com/wiki
?Net used to d/l Dropbox,BusyBox,Changelog
The ONLY tool that can backup, restore, freeze (with Pro) your apps + data + Market links!
Supports protected and system apps! 0-click Batch/scheduled backups!
The PRO version adds 0-click batch restores, Dropbox sync, conversion between user <=> system apps, Dalvik cleaner & MORE!
PRO Features:
• Multiple backups per app
• 0-click batch restore
• Batch verification
• Hypershell speed
• Market Doctor
• Apps freezer
• Convert user app <=> system app
• Encryption
• Unlimited schedules
• Sync to/from Dropbox
• Brand the app with your name
• Bloatware Melter (experimental)
More Memory:
• Dalvik cache cleaner
• Merge system app updates
What's in this version:
-Added "Move app data to SD card" (Data2SD) feature (requires an ext2/3/4 partition on SD card).
-Added support for restoring/wiping app data on SD card.
-Fixed FC in Opera Mobile (or any app with native libraries) after restore. It happened on some ROMs (eg: CM7) if the app was backed up from SD card and then restored to Internal memory. Big  to the Opera Mobile team for reporting this bug!
-Fixed issue with data-only restore of apps with native libraries.
-GUI bugfixes & cleanups.
Provided by: -Market Militia-
https://mark...taniumBackup
ลิงค์ครับ
Very thank Notion    สำนึกผิด สำนึกผิด
« ตอบ #81 เมื่อ: 18 กรกฎาคม 2015, 11:38:45 »
Update Titanium Backup ★ root 7.2.1.2
WHAT'S NEW
Fixed hang during XML backup of Wi-Fi networks (in “modified data” mode) on some Android 5.0+ devices.
ลิงค์ครับ  เก็กหล่อ
« ตอบ #82 เมื่อ: 27 สิงหาคม 2015, 04:49:53 »
Update Titanium Backup PRO ★ root v7.2.2
What's in this version :
Added shortcut to check license status from the welcome screen.
[PRO] Fixed the infamous and extremely annoying "Google Play Store is taking a long time to respond" error on some devices (finally). PRO key should work smoothly for everyone now.
[PRO] Fixed issues and improved display in case of access rights problem with the license file.
Updated translations.
ลิงค์ครับ  Ok
« ตอบ #83 เมื่อ: 09 ตุลาคม 2015, 22:17:17 »
Update  Titanium Backup Pro v7.2.3 Full
WHAT'S NEW
Added initial support for Android 6.0 Marshmallow.
[PRO] Added support for XML backup/restore of Wi-Fi networks that use EAP (identity + password) on Android 4.3+.
Fixed FC on launch if “Greenify” Xposed module is present.
ลิงค์ครับ  Ok
« ตอบ #84 เมื่อ: 17 ตุลาคม 2015, 11:51:41 »
Update Titanium Backup ★ root 7.2.4 PRO
WHAT'S NEW
Fixed inability to restore apps & encrypted backups on Android 6.0 Marshmallow, if SELinux was set to “enforcing”.
ลิงค์ครับ  เก็กหล่อ
« ตอบ #85 เมื่อ: 25 ตุลาคม 2015, 18:31:18 »
Update Titanium Backup ★ root 7.2.4.1 PRO
What's New
Fixed storage issues on some Android 6.0 Marshmallow platforms.
Note to Android 6.0 Marshmallow users: any backups in /storage/emulated/legacy/ must be manually moved to /storage/emulated/0/ for TB to detect them.
ลิงค์ครับ  Ok
« ตอบ #86 เมื่อ: 24 พฤศจิกายน 2015, 04:22:11 »
Update Titanium Backup ★ root 7.3.0
WHAT'S NEW
• Fixed storage issues on some Android 6.0 Marshmallow platforms.
• Note to Android 6.0 Marshmallow users: any backups in /storage/emulated/legacy/ must be manually moved to /storage/emulated/0/ for TB to detect them.
• Updated translations.
ลิงค์ครับ  เก็กหล่อ
« ตอบ #87 เมื่อ: 16 มกราคม 2016, 11:54:26 »
Update AppMgr Pro III (App 2 SD) v3.85
WHAT'S NEW
★ root app mover function supports Android 6
★ large cache window: add a "Clean cache" button and enable you to select apps
★ speed improved when refreshing the apps list
★ if UI is still showing in English and you'd like to help the translation, please send me an email
★ bugs fixed and optimizations
ลิงค์ครับ  เก็กหล่อ
« ตอบ #88 เมื่อ: 23 มีนาคม 2016, 10:56:45 »
Update Titanium Backup ★ root 7.3.0.2 PRO
WHAT'S NEW
Fixed FC when changing the backups folder location, if DocumentsProvider denies TB access to the previous location.
Fixed FC during app backup on some platforms.
Major translation updates.
ลิงค์ครับ  เก็กหล่อ
หน้า: 1 ... 3 4 [5]   ขึ้นบน
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.271 วินาที กับ 45 คำสั่ง
