29 พฤษภาคม 2024, 17:25:14 *
ผู้เขียน หัวข้อ:  SystemPanel App / Task Manager v1.0.9  (อ่าน 1722 ครั้ง)
-ได้รับ: 69260
« เมื่อ: 18 มีนาคม 2011, 03:57:09 »
Requirements: Android 1.5+
Overview: SystemPanel is an all-purpose utility application. It lets you monitor and manage the applications on your phone. It shows you what your phone is doing and what apps are consuming the battery.
SystemPanel integrates a task manager, app manager (installer/uninstaller with multi-version APK archival), and system monitor.
Solve your battery life problem by enabling the background monitoring service to record long-term CPU usage by individual apps.
SystemPanel includes the following features:
Task Manager: The task manager shows what applications are currently loaded into memory and/or running on a device, including current CPU and memory utilization for each. The task manager provides the ability to kill offending applications, and includes an emergency "end all" widget to handle extreme scenarios.
System Monitor: The system monitor can be enabled to record device usage history over a period of time (up to one week), such that you can determine what applications and usage patterns have the greatest impact on battery life. This feature is commonly used to help track down which applications are having major negative effects on battery life. The system monitor records CPU usage for each process, overall CPU usage, display usage, battery level, and battery charging status.
Installer: The installer enables you to install and uninstall applications quickly and conveniently. It can archive multiple versions of applications, such that you can backup your apps before an update and revert back to older versions afterward. This is useful in the not uncommon event the updated item is buggy or otherwise undesirable. Additionally, the Installer is designed to work much more efficiently than the standard Android application manager, and does not suffer the frustrating lag issues found in the default Android item when browsing through a large number of installed apps.
Device Information: The device information screens show detailed information about your Android device, including storage, capabilities, network state, and OS build information.
Recent changes:
1.0.9: Links to Android application details screens (Gingerbread and later). UI improvements for tablets / large screen devices such as Xoom. Finer-grained battery charge monitoring for second-generation Motorola Droids (X/2/Pro). Bugfixes. Now additionally tested on Gingerbread (N1, Droid1 w/CM7) and Xoom.
http://andro.../systempanel
ลิงค์ครับ  ร่าเริง ร่าเริง
มานับอายุ(ขัย)ของยางกันเถอะ โดย Manager online.com
Navthai - Motor
^SuRaYoOt^ 0 3686 กระทู้ล่าสุด 17 กันยายน 2009, 12:11:22
ช่วยด้วยครับ iGO 8.3 ค้างที่หน้า POI Manager Init
Prapan 5 4209 กระทู้ล่าสุด 30 กรกฎาคม 2010, 11:44:57
โดย chumpony
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.054 วินาที กับ 36 คำสั่ง
