23 เมษายน 2024, 21:02:23 *
ผู้เขียน หัวข้อ:  Overclock SiRF Atlas 4 & Atlas 5 CPU  (อ่าน 6963 ครั้ง)
ออนไลน์ ออนไลน์
« เมื่อ: 22 กุมภาพันธ์ 2011, 09:40:44 »
สำหรับคนอยากแรงนะครับ. แต่ต้องแบกรับความเสี่ยงกันเองครับ.  ชัยโย
ข้อมูลแปลจากภาษารัสเซีย
Not so long ago I bought myself on ebay navigator-based SIRF Atlas5. In performance, it was stated frequency of 600 MHz CPU. On arrival it was found that in fact the frequency of 500 MHz CPU. Moreover, commissioned a little later the same navigator, but with bluetooth and has a frequency of 400 MHz at all. At the forum there are people who have Atlas5 rate even lower.
All this, and even your own curiosity spodvigli me to write programmuliny to change the frequency Atlas5. On the hands there was a Datasheet on atlas4. Assuming that the management of frequencies it should differ little from him and decided to draw on. As it turns out there are differences, but not fundamental. If anyone interested, I will describe them later.
As is known to have access to external registers in CE6 kernel driver needed. That's it, and will establish us in the first place. Copy the archive file in the root ClkDrv.dll Resident Flash and add to the registry information from a file ClkDrv.reg, for example by using RegEdit. Dll-ku can be placed in another place, but then you need to edit the appropriate line in ClkDrv.reg.
Once the information is added to the registry, you can run AtlasOC.exe. Once launched, a dialog box will appear controls frequencies.
So look rate my Iphone Style Default:
And so, after increasing the frequency of
About how it works and what it means I'll write later
Still want to write about CETree_SysMetrics - a program for measuring performance. Its principle of operation is to measure the number of operations per unit time. But as a timer, use the system timer, which itself depends on the system frequency, which we change. Therefore, to measure performance, it does not fit. For example, I reduced the incidence of two. All this begins with good brakes (easily visible to the eye), programmulina works twice as long, but persistently shows 400 mips/12 mflops. But if we reduce the system frequency (increase the divisor) and leave the CPU frequency the same, programmulina generally can not count how many MIPS as much as 26 shows mflopsov
Added the ability to overclock memory (by increasing the frequency PLL2). Disclaimer: The memory is always tied to PLL2
Added ability to save settings to a file and read from a file. Added ability to run without the GUI. Line start: "AtlasOC.exe-s filename" where filename can be either an absolute path and file in the directory where the program starts.
For example AtlasOC.exe-s atlasoc.clk or AtlasOC.exe-s \ SDMMC \ atlasoc.clk
Atlas4OC.rar
Atlas5OC.rar
PS: While not quite figured it out why after running AtlasOC.exe flies off the screen calibration and screen as a band. Dividers And I originally others.
Effect clearly is, but not everywhere. CETree_SysMetrics vaobsche not responded to the acceleration factor of 2, the same 300Mips and 9.490041Mflops.
PPS: The line running to MortScript should look like this:
Run ("\ ResidentFlash \ AtlasOC.exe", "-s atlasoc.clk")
จัดไปหนัก ๆ
Clock ประมาณนี้
วิ่งประมาณนี้
เครื่องใครพังก็ตัวใครตัวมันนะครับ  กระหยิ่ม สะใจจริง ๆ
« ตอบ #1 เมื่อ: 22 กุมภาพันธ์ 2011, 09:43:18 »
ไม่น่าเชื่อ GPS ก็มี Overclock ด้วย สะใจจริง ๆ
ขอดูไปก่อน ยังไม่อยากเสี่ยง  Undecided
Donateผู้สนับสนุน
ID number: 2205
« ตอบ #2 เมื่อ: 22 กุมภาพันธ์ 2011, 09:46:25 »
 Cheesy ขอรอผู้เสี่ยงตายก่อนครับ หากมีผลดียัง อาจจะร่วมเป็นผู้ร่วมชะตากรรมด้วยคน  Embarrassed
ออนไลน์ ออนไลน์
« ตอบ #3 เมื่อ: 22 กุมภาพันธ์ 2011, 09:56:25 »
ผลดีคือแรงแบบทันตาเห็น ผลร้ายคือแบตอาจหมดไว และ CPU อาจทำงานหนักจนชะตาชีวิตสั้นกว่าปรกติครับ  กระหยิ่ม
Donateผู้สนับสนุน
ID number: 2205
« ตอบ #4 เมื่อ: 22 กุมภาพันธ์ 2011, 09:59:59 »
ผลดีคือแรงแบบทันตาเห็นผลร้ายคือแบตอาจหมดไว และ  CPU อาจทำงานหนักจนชะตาชีวิตสั้นกว่าปรกติครับ  กระหยิ่ม
ฮือ ๆ ฮือ ๆ ตรงนี้แล่ะครับที่น่ากลัว
« ตอบ #5 เมื่อ: 22 กุมภาพันธ์ 2011, 10:09:20 »
เคยใช้โปรแกรม overclock บน pda ไปประมาณ 10% แบตหมดเร็วมากครับ
ID number: 327
« ตอบ #6 เมื่อ: 22 กุมภาพันธ์ 2011, 10:16:59 »
อยู่เฉยๆอย่าเสี่ยงดีกว่ามั้ง ยกเว้นอยากเปลี่ยนเครื่องใหม่ไวๆ  Tongue
jonin
s8lt memberDonate
ID number: 582
กระทู้: 298
Send Money to jonin
-ได้ให้: 198
-ได้รับ: 476
« ตอบ #7 เมื่อ: 22 กุมภาพันธ์ 2011, 12:06:56 »
แบตหมดไวไม่เท่าไหร่ แต่ cpu ตายดีกว่า นี่สิน่ากลัว ใช้สปีดเดิมๆดีกว่าไม่เสี่ยง   อาบน้ำอุ่น ๆ
The_kop
ID number: 19015
กระทู้: 109
Send Money to The_kop
-ได้ให้: 453
-ได้รับ: 159
« ตอบ #8 เมื่อ: 23 กุมภาพันธ์ 2011, 08:16:11 »
ถ้าเกิดมัน น๊อคขึ้นมา ผบทบ. จะอณุมัติ เครื่องใหม่ไหมน้อ  ฮือ ๆ
SIRF Atlas-IV VS SIRF Star-IV
nopjinda 4 8117 กระทู้ล่าสุด 20 มีนาคม 2010, 22:12:56
โดย มด [tewbc]
+รบกวนขอรอม LEONA GPS521 SIRF Atlas V ด้วยครับ เครื่องเด้งเข้า wince เลย++
ห้องรอม
noppasit20 18 4587 กระทู้ล่าสุด 12 มิถุนายน 2018, 18:05:21
โดย noppasit20
+ รบกวน ขอ ไฟล์ Overclock SiRF Atlas 4 & Atlas 5 CPU หน่อยคับลิ้งเดิมโหลดไม่ได้+
noppasit20 2 2419 กระทู้ล่าสุด 19 มิถุนายน 2018, 13:30:50
โดย noppasit20
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.126 วินาที กับ 55 คำสั่ง
