29 เมษายน 2024, 19:55:52 *
ผู้เขียน หัวข้อ:  GJA_v2.25 ออกใหม่แล้ว  (อ่าน 6421 ครั้ง)
« เมื่อ: 20 กุมภาพันธ์ 2011, 22:02:10 »
GJA skin for Primo 1.1. Version 2.25
Requirements: Primo 1.1 (Green routing) GPS system with 480x272 or 800x480 device resolution
Operating System: WM, WinCE
Overview: GJA (gurjon & arkoko) skin for Primo 1.1 Green Routing
Changelog:
v.2.25 20.02.2011
1. Favorites sort order now stored between sessions.
2. Fixed compass on map issue after returning from 2D North Up overview to the 2D navigation map.
3. Added "Add POI" to the More menu.
Fullpack contains addons and all needed files to the skin correct working (day and night skins, Utility folder, color schemes, external Mapchanger, sources for direct use without skin installation). 2 versions of night skin for 800x480 included in the Fullpack. One for arkoko data.zip and another for Vladgrand data.zip . Just unpack all to the correct places:
Skin files goes to the content/skin folder. Or if you prefer to use source - unpack _skin_source.rar (ui_igo9 folder) to the Primo root directory. In this case skin files not needed.
utility - copy to the Primo root. Utility folder contains internal mapchanger, panic and clearsave scripts. To correct work *.ini files must be edited for your system environment.
Optional:
Scheme - copy to content/scheme
bluetooth unpack to the root Primo root directory (only if you using this method of BT control).
External MapChanger - unpack to any place, if you are going to use it at all. Edit mapchanger.ini file for correct work.
ลิงค์ครับ  Roll Eyes
GJA_v2.25_480x272_FullPack
http://uploa...FullPack.rar
GJA_v2.25_800x480_FullPack.zip
External_MapChanger.zip
http://uploa...pChanger.zip
Scheme.zip
http://uploa...9/Scheme.zip
utility_v2.23.zip
http://uploa...ty_v2.23.zip
Thanks to Gurjon & Arkoko and Kimyaci   สำนึกผิด สำนึกผิด สำนึกผิด
✄PiGGer✄
ชีวิต..ฉัน..เป็น..ของฉัน
s8lt memberDonate
ID number: 3608
กระทู้: 1047
Send Money to ✄PiGGer✄
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #1 เมื่อ: 20 กุมภาพันธ์ 2011, 22:12:56 »
คุณ surayoot ครับ โหลดไปแล้ว มันเกิดปัญหาเปิดไม่ได้ ไม่รู้เป็นอะไร หรือว่าของมันแรง ช่วยแถลงไขหน่อยครับ  กำเสี่ย
« ตอบ #2 เมื่อ: 20 กุมภาพันธ์ 2011, 22:21:38 »
คุณ pigger น่าจะโหลดมาได้ไม่สมบูรณ์ครับ ยิ่งถ้าได้ขนาดเล็ก ๆ นี่แปลว่าโหลดไม่สำเร็จ
ต้องลองโหลดใหม่ดู
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #3 เมื่อ: 20 กุมภาพันธ์ 2011, 22:28:23 »
ต้องลองโหลดใหม่ดู
เหมือนเดิมครับ คุณ surayoot โหลดมากี่ครั้งก็ไม่ได้ ได้แค่ไม่กี่ MB เอง  ร้อน
« ตอบ #4 เมื่อ: 20 กุมภาพันธ์ 2011, 22:37:37 »
ไฟล์เล็กไปจริงๆ ด้วย
แบบนี้แสดงว่าโหลดไม่เสร็จ ไฟล์เลยไม่สมบูรณ์ เพราะผมโหลดมาตัว 480x272 นี่ได้ขนาด 7305 kb
งั้นใจเย็น ๆ เดี๋ยวผมอัพให้ใหม่ กระหยิ่ม
« ตอบ #5 เมื่อ: 20 กุมภาพันธ์ 2011, 22:54:46 »
อัพเสร็จแล้วนะครับ เอา 480x272 ไปก่อนนะครับ
เห็นคุณ pigger ใช้หน้าจอนี้ ส่วนอันอื่นเดียวทยอยอัพ ให้เผื่อสมาชิกท่านอื่นๆ ด้วย
480x272 ครับ
http://www.u...f7f43f9b435a
เพิ่มเติมด้วย 800x480 ครับ
http://www.u...a367510d2e1e
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #6 เมื่อ: 20 กุมภาพันธ์ 2011, 22:56:35 »
480x272 ครับ
ใจดี สุด ๆ เลยครับ คุณ surayoot ขอให้รวย ๆ ๆ ครับ  กำเสี่ย
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #7 เมื่อ: 21 กุมภาพันธ์ 2011, 07:43:10 »
ตัวนี้คงไม่ต้องโมละมั้ง เพราะตัวป้ายเตือนใช้ข้อมูลที่อยู่ในตัว data.zip เลย ยกเว้น คนที่ใช้พรีโม่ เสียงเตือนชุดใหญ่ ตัวอักษรบอกระยะเตือนจะเล็กและไม่ตรงตำแหน่งครับ แต่ถ้าเป็นพรีโม่่ตัวที่ไม่ได้ดัดแปลงก็ใช้ได้เลยครับ
« ตอบ #8 เมื่อ: 21 กุมภาพันธ์ 2011, 09:13:51 »
ผมชอบ skin GJA นี่แหล่ะ รู้สึกว่าเรียบ ๆ ง่าย ๆ ดี
ID number: 15436
« ตอบ #9 เมื่อ: 21 กุมภาพันธ์ 2011, 23:05:52 »
อยากให้สกินนี้มีฟังชั่น Trip Computer
แบบเดียวกับสกิน Dimka น่ะครับ
ต้องทำอย่างไรบ้างครับเนี่ย?
Prapan
ID number: 5076
กระทู้: 82
Send Money to Prapan
-ได้ให้: 179
-ได้รับ: 213
« ตอบ #10 เมื่อ: 21 กุมภาพันธ์ 2011, 23:10:55 »
ไม่ได้เห็น skin ใหม่ ๆ ออกมาตั้งนาน นึกว่า GJA ไม่ทำต่อแล้ว ขอบคุณมากครับที่แบ่งปัน ว่าแต่ผมใช้กับเสียงเตือนชุดใหญ่ คงต้องรอสักพักจนกว่าจะมีผู้ใจบุญ มีความสามารถแก้ไขให้ ขอบคุณมาล่วงหน้าครับ
ID number: 15436
« ตอบ #11 เมื่อ: 23 กุมภาพันธ์ 2011, 10:56:57 »
2.25 ยังไม่ทันใช้ 2.26 มาใหม่อีกแล้วครับท่าน
GJA_v2.15_320_240CsS2
jeeratda 2 2602 กระทู้ล่าสุด 20 กันยายน 2010, 17:41:08
โดย tin_43257
GJA_v2.16_CIS
^SuRaYoOt^ 2 2469 กระทู้ล่าสุด 01 ตุลาคม 2010, 10:09:03
GJA_v2.16_RED
tin_43257 0 1785 กระทู้ล่าสุด 02 ตุลาคม 2010, 03:53:25
โดย tin_43257
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.183 วินาที กับ 56 คำสั่ง
