« เมื่อ: 06 มกราคม 2011, 04:44:39 » |
Garmin StreetPilot® for iPhone® มาจนได้สำหรับการ์มิน บน iphone และ ipad น่าจะออกมาตั้งนานแล้ว แต่มาช้ายังดีกว่าไม่มา รายละเอียดครับ Garmin StreetPilot * $39.99 * Category: Navigation * Released: Jan 04, 2011 * Version: 6.5.2 * 7.5 MB * Language: English * Seller: Garmin International * © Garmin International, Inc. 2011 Rated 4+ Requirements: Compatible with iPhone 3G, iPhone 3GS, iPhone 4, and iPad Wi-Fi + 3G. Requires iOS 3.0 or later Description Download Garmin StreetPilot® and get Garmin® award-winning navigation, similar to the premium features on Garmin’s renowned nüvi® personal navigators. Designed exclusively for your iPhone® or iPad®, this application turns your device into a GPS navigator with turn-by-turn voice-prompted directions and premium features for wherever you want to go.
Features include:
-Always up-to-date maps for the U.S. and Canada -Voice-prompted, turn-by-turn directions including street names -Real-time traffic updates to avoid traffic delays -Speed limits for most major roads -Integrated Local Search -Millions of points of interest -Lane assist with junction view for complicated interchanges -Address book integration to navigate to contacts -Integrated iPod® music controls -Multi-tasking on iOS4 for navigating while calling -Current weather conditions and forecast -Place calls directly from search listing -Navigate in both portrait and landscape mode -Easy to install with quick load times
Enjoy premium navigation features from Garmin, the world leader in GPS navigation:
•GET TURN-BY-TURN DIRECTIONS. Garmin StreetPilot® is so easy to use. Its intuitive interface greets you with two simple options: "Where To?" and "View Map." Look up addresses and services and get voice-prompted, turn-by-turn directions that speak street names to your destination. It uses detailed City Navigator® NT street maps, featuring millions of POIs, 2-D or 3-D map views and speed limits for most major roads in the U.S.
•ALWAYS THE LATEST MAPS. Garmin StreetPilot® uses the same premium quality City Navigator® NT map data available for Garmin’s nüvi® product line. Map data loads directly from the Garmin servers, so your maps are always up-to-date. Due to its small file size, StreetPilot loads quickly – ready to go when you are!
•KNOW THE LANE BEFORE IT’S TOO LATE. No more guessing which lane you need to be in to make an upcoming turn. Lane assist with junction view guides you to the correct lane for an approaching turn or exit, making unfamiliar intersections and exits easy to navigate. It realistically displays road signs and junctions on your route along with arrows that indicate the proper lane for navigation.
•REAL-TIME TRAFFIC UPDATES. Steer clear of traffic with integrated traffic updates. Receive alerts about traffic delays and road construction on your route so you can avoid them.
Garmin StreetPilot® has been designed to run on iPhone 3, iPhone 3GS and iPhone 4 and works in compatibility mode on the Apple iPad as well. Higher resolution maps are available on iPhone 4 to make best use of the Retina display.
Please note that continued use of GPS running in the background can dramatically decrease battery life. ภาพตัวอย่างครับ น่าใช้จริงๆ เห็นภาพ แล้่วอยากใช้จริงๆ ทีนี้ iphone ก็น่าใช้มากขึ้นสำหรับผม ก่อนนี้ไม่สนทั้ง iphone และ ipad เพราะระบบนำทางนี่แหล่ะ แต่พอเห็นการ์มินออกมาแบบนี้ สงสัยต้องเก็บตังค์ รอสอยมาใช้บ้าง แต่คงรอเป็น iphone 5 เลย สนใจข้อมูลเพิ่มเติมเชิญนะครับ http://itune...1462555?mt=8https://buy....do?pID=94658
(^_^)
Exp 16-02-2012
เพศ: ID number: 3073
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #21 เมื่อ: 11 มกราคม 2011, 22:14:30 » |
download มาแล้วแต่หาเครื่องลงไม่ได้ เพราะว่าไม่มีตังซื้อเครื่อง
kaow
ออฟไลน์ID number: 3497
Send Money to kaow
-ได้ให้: 90
« ตอบ #22 เมื่อ: 12 มกราคม 2011, 08:17:49 » |
ลองหามาลงใน iphone 4.1 32GB ใช้ wi-fi 6 MB เปิดโปรแกรมมาก็ OK แต่ MAP ไม่มีรายละเอียด เห็นแต่รูปรถสีฟ้า หมุนได้ไปตามทิศทางที่ลองเคลื่อนที่ไป อยากถามผู้รู้ ถึงสาเหตุที่ รายละเอียด MAP ไม่ขึ้น หรือว่าต้อง set ตรงใหน ลองซูม out แล้วเห็นแต่ทะเลกับพื้นดิน รวมทั้งประเทศไทยด้วย แต่ไม่มีแผนที่ หรือว่าต้อง 3G เท่านั้น ขอบคุณครับ
เพศ: รางวัล: ID number: 2205
« ตอบ #23 เมื่อ: 12 มกราคม 2011, 14:40:13 » |
ไม่ลองอ่านตั้งแต่ต้นดูใหม่อีกรอบเหรอครับ .. มีเพื่อนสมาชิก โพสท์ไว้อยู่ว่า เมืองไทยใช้ไม่ได้ ใช้ได้แต่ อเมริกาครับ
(^_^)
Exp 16-02-2012
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #24 เมื่อ: 12 มกราคม 2011, 19:25:25 » |
สรุปเป็น online map ต้องต่อเน็ต ความเห็น ไม่น่าใช้ครับ ขาย iphone ไปซื้อ A10 ดีกว่าครับ หากต้องการ garmin
tatao2499
ออฟไลน์ID number: 5444
Send Money to tatao2499
« ตอบ #25 เมื่อ: 13 มกราคม 2011, 13:00:48 » |
หากเป้นแบบออนไลน์ ใช้กูกุ้มแมพไม่ดีกว่าหรือครับ
noi784
VIP เมื่อ 05-02-10
เพศ: ID number: 3295
กระทู้: 34
Send Money to noi784
-ได้ให้: 26
-ได้รับ: 28
« ตอบ #26 เมื่อ: 25 กุมภาพันธ์ 2011, 20:16:47 » |
download มาแล้วแต่หาเครื่องลงไม่ได้ เพราะว่าไม่มีตังซื้อเครื่อง ผมซื้อเครื่องมาแล้ว ตังค์หมด ไม่มีตังค์ซื้อ App
(^_^)
Exp 16-02-2012
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #27 เมื่อ: 25 กุมภาพันธ์ 2011, 20:38:18 » |
App map เป็น online ครับ ต้องต่อเน็ตความเร็วตลอด และแผนที่ประเทศไทยไม่มีครับ ซื้อ garmin แท้ๆ ใช้ไปเลย
noi784
VIP เมื่อ 05-02-10
กระทู้: 34
-ได้ให้: 26
-ได้รับ: 28
« ตอบ #28 เมื่อ: 27 กุมภาพันธ์ 2011, 12:38:34 » |
เบื่อพวก map online ฝากความหวังไว้ที่ เน็ต ถ้าล่มก็ไม่ต้องไปไหน กำ
NungS
ออฟไลน์ID number: 7971
Send Money to NungS
-ได้ให้: 56
-ได้รับ: 47
« ตอบ #29 เมื่อ: 28 กุมภาพันธ์ 2011, 20:50:44 » |
ยังไม่ยอมออก offline map สำหรับเมืองไทยสักที
« ตอบ #30 เมื่อ: 31 ธันวาคม 2011, 15:05:32 » |
« ตอบ #31 เมื่อ: 03 มกราคม 2012, 04:58:54 » |
T123
ออฟไลน์ID number: 334
กระทู้: 61
Send Money to T123
-ได้ให้: 140
-ได้รับ: 64
« ตอบ #32 เมื่อ: 03 มกราคม 2012, 15:11:43 » |
แผนที่ภาษาไทยได้มั้ยครับ
niceball
ออฟไลน์รางวัล: ID number: 4541
กระทู้: 127
Send Money to niceball
-ได้ให้: 203
-ได้รับ: 147
« ตอบ #33 เมื่อ: 03 มกราคม 2012, 21:31:23 » |
แผนที่ภาษาไทยได้มั้ยครับ กระทู้ก่อนคุณ น่าจะมีคำตอบให้ได้นะ
T123
กระทู้: 61
Send Money to T123
-ได้ให้: 140
-ได้รับ: 64
« ตอบ #34 เมื่อ: 03 มกราคม 2012, 23:27:34 » |
ขอบคุณครับ พอดีผมลองแล้ว แสดงแผนที่ไทยได้ แต่ชื่อถนนบนแผนที่มันเป็น ไม่รู้จะแก้ยังไงก็เลยสอบถามดู
mondam
VIP เมื่อ 03-10-2009 2Y
เพศ: ID number: 170
กระทู้: 33
Send Money to mondam
-ได้ให้: 36
-ได้รับ: 34
« ตอบ #35 เมื่อ: 09 มกราคม 2012, 19:21:32 » |
ผมลองมาหลายวันแล้ว เปิดมายังไม่เจอแผนที่เลยครับ ยิ่งไม่ค่อยฉลาดอยู่ด้วยคงต้องรอต่อไปครับ คริ คริ
mondam
เพศ: ID number: 170
กระทู้: 33
-ได้ให้: 36
-ได้รับ: 34
« ตอบ #36 เมื่อ: 09 มกราคม 2012, 22:17:24 » |
ขอโทษครับ Admin พยายามอยู่ เสียงไทยมาแล้ว เหลือแค่ภาษาไทยในแผนที่ยังเป็น ? อยู่ใครพอแนะนำได้บ้างมั๊ยครับ
n1976
ออฟไลน์ID number: 7496
กระทู้: 180
Send Money to n1976
-ได้ให้: 1277
-ได้รับ: 230
« ตอบ #37 เมื่อ: 31 มกราคม 2012, 09:49:00 » |
ืืืทำยังไงถึงจะได้ใช้เนี่ย? เจ้าของกระทู้เจ๋งจริงๆ อยากทราบว่าใช้บน iphone4s ได้หรือเปล่า?
« ตอบ #38 เมื่อ: 31 มกราคม 2012, 10:15:44 » |
แผนที่ภาษาไทยได้มั้ยครับ ต้อง patch codepage ครับ. อย่าขอผมนะ ผมก็ไม่มีเหมือนกัน อยากทราบว่าใช้บน iphone4s ได้หรือเปล่า? ได้ครับ แต่ผมไม่มี ipone ใช้ครับ เลยไม่ได้โหลดมาลอง
« ตอบ #39 เมื่อ: 01 กุมภาพันธ์ 2012, 00:16:20 » |
ืืืทำยังไงถึงจะได้ใช้เนี่ย? เจ้าของกระทู้เจ๋งจริงๆ อยากทราบว่าใช้บน iphone4s ได้หรือเปล่า? ใช้ได้แน่นอนครับบน iphone4s ครับ :newe4: แต่ต้องเจลก่อนนะครับ
T123
กระทู้: 61
Send Money to T123
-ได้ให้: 140
-ได้รับ: 64
« ตอบ #40 เมื่อ: 01 กุมภาพันธ์ 2012, 03:08:01 » |
ขอบคุณครับ ตอนนี้ได้แล้วครับ
