29 เมษายน 2024, 15:22:39 *
ผู้เขียน หัวข้อ: Android Android : Skin 800x480 motogis V2.4 + Keyboard T/E (data.gro)  (อ่าน 10120 ครั้ง)
« เมื่อ: 04 มกราคม 2011, 16:46:48 »
V2.4
History:
* added function to work with speedcams (search mode on the map)
* added icons for various speedsams map (adapted from Primo, and therefore must be version speedcams.txt for Primo, otherwise the wrong icons are displayed!)
* a little update
Known bugs:
* Does not return the stored data;
* Removes the stored routes if you run igo;
Backup works fine, but the Restore - not working. Please run a test, who is active S-OFF. Attention! Function "Backup Data" creates on the SD card folder "backup". If you have such a folder, it will be overwritten!
v2.3.1
History:
* Ability to move the intermediate points;
* Fixed bug off route when leaving the viewer TMC;
* Settings menu add the button "Backup Data and Restore Data" (thanks mariupol1963!). Backup works fine, but the Restore - not working. Please run a test, who is active S-OFF. Attention! Function "Backup Data" creates on the SD card folder "backup". If you have such a folder, it will be overwritten!
* A little small corrections;
* Added menu item settings TMC (please test in those countries where this lotion works);
v2.3
History:
* Completely reworked the algorithm to add / delete waypoints on the map;
* Redesigned the buttons in the search on the map;
* Added option to view / delete points (in the menu "My trip");
* Added function to save / load / delete a route;
* Search button in the coordinates are now in menu "Destination";
* Changed discrete zoom maps;
* Size data.gro still reduced to 500 KB;
* Heap visible / invisible bug fixes;
v2.2
History:
- Slightly redesigned interface in navigation mode:
* Call the menu is one click on the map;
* Switch-over to view the map - double click on the map;
* Redesigned displaying information about speed, arrival time, etc. (Click on the window at a speed you can open / close additional information);
* Displayed at the bottom of the street where we're going (by clicking on this line, we will switch to indicate the name of city);
* Right and left arrows show the number of houses, past which we currently eat;
* Each menu button performs an action with a long click on it (for example, if you hold the menu button, there will be a way out of iGO)
* In navigation mode, if you click on the time of arrival, we will switch to display the remaining time;
* Can still forgot something:)
- Redesigned the buttons in the simulation mode route;
- Yet finalized, adds intermediate keys;
- To further reduce the size of data.gro 250 KB;
- Minor bugfix;
v2.0.1b
History:
-added speedcam menu;
-changed speedcam alert;
-skin bugfix;
-slightly reduced the size of data.gro
วิธีใช้งาน
-นำ data.gro ไปไว้ที่ /data/data/com.navngo.igo.javaclient
หรือ
-นำ data.gro ไปไว้ที่ /sdcard/iGO แล้วไปลบ data.gro ที่อยู่ใน /data/data/com.navngo.igo.javaclient
ถ้าอยากแก้ branding.gro แนะนำให้ย้ายจาก /data/data/com.navngo.igo.javaclient มาไว้ที่ /sdcard/iGO จะได้สะดวกในการแก้ไข
เกี่ยวกับไฟล์ gro หาข้อมูลได้ในห้อง amigo
*** จำเป็นต้อง root เครื่องเพื่อที่จะเข้าถึงข้อมูลในส่วนของ "/data/data/com.navngo.igo.javaclient" ได้ ***
Thank : radu.vfr @ mobilepassion.org
Thank : moto.com.ua
Thank : 4PDA.ru
« ตอบ #1 เมื่อ: 10 มกราคม 2011, 19:00:36 »
อัพเป็น 2.2 แล้วนะครับ (ที่ post แรกครับ)
มีเมนูเพิ่มขึ้นมาจากเดิมตามรูปครับ
« ตอบ #2 เมื่อ: 18 มกราคม 2011, 17:56:56 »
อัพเป็น 2.4 แล้วนะครับ (ที่ post แรกครับ)  กระหยิ่ม
mrsarakun
ID number: 19979
Send Money to mrsarakun
« ตอบ #3 เมื่อ: 09 กุมภาพันธ์ 2011, 23:57:27 »
จะลองทำดูนะครับ
arm_desu
ID number: 19650
Send Money to arm_desu
« ตอบ #4 เมื่อ: 10 กุมภาพันธ์ 2011, 22:37:55 »
เยี่ยมมากมายครับ ทำให้ android ใช้งาน igo ได้ดีขึ้นกว่าเดิม ขอบคุณมากๆจร้า
illusion
ID number: 2802
กระทู้: 41
Send Money to illusion
-ได้ให้: 53
-ได้รับ: 48
« ตอบ #5 เมื่อ: 21 กุมภาพันธ์ 2011, 13:16:06 »
ถ้าจะหาปั๊ม lpg ในระแวกที่อยู่ใกล้เคียง เหมือน win ce ได้หรือเปล่าครับ ลองงมอยู่นานเจอแต่ปั๊มน้ำมันใครรู้ช่วยแนะนำหน่อยครับ
ไม่สามารถเปลี่ยนkeyboard ใน igo my way 8.4 android ครับ
sathaph 2 4855 กระทู้ล่าสุด 28 ตุลาคม 2010, 00:36:13
โดย keang-kt
Primo data 800x480 มี skin ใช้กับเขาแล้ว
keang-kt 10 8423 กระทู้ล่าสุด 23 สิงหาคม 2010, 00:27:05
โดย keang-kt
Keyboard T/E for Primo 1.1 Data 800x480 V.1.4
equinox 9 12153 กระทู้ล่าสุด 01 กันยายน 2010, 00:24:20
โดย ₪๐StemCell๐₪
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.044 วินาที กับ 48 คำสั่ง
