29 พฤษภาคม 2024, 07:56:26 *
ผู้เขียน หัวข้อ:  Scheme Beanico WeatherMod-v0.9  (อ่าน 2751 ครั้ง)
-ได้รับ: 69260
« เมื่อ: 02 ธันวาคม 2010, 04:29:34 »
Thanks: gamethai  showpic
Installation
Arsiv Downloads for Hiden:
Adjusting the tilt and zoom automatically:
_________________________________________________
I propose a new novel settings.
They can keep a close view of the crossroads
They enable a more panoramic during long distances without guidance.
This allows to take maximum advantage of landscapes, skies and terrain:
Add to sys.txt these lines:
[Camera2]
minZoom = 60
maxZoom = 180
minangle = 60
maxangle = 85
defaultzoom3d = 250
defaultangle = 80
CAUTION: To benefit from these settings,
you must set the view to normal in the card settings.
Schemes Beanico WeatherMod
Schemes to be compatible with the Primo ThemeChanger
- These schemes operate under Primo and have been developed in 480x272.
- For other resolutions, it works but the skies are not always perfectly adjusted.
- There are 12 months of the year with 5 possibilities for each weather (sunny, cloudy, rain, fog, pollution).
- For soil, the main idea is to vary the elevation where there is snow in the mountains.
- For the night, only the weather is variable.
Installation:
1 - Install a skin compatible PROPERLY ThemeChanger (This includes activating Mortscript 4.2)
2 - Copy the file in the folder full Beanico Themechanger located in the directory of Primo.
3 - Start by launching themechanger.exe Primo (instead of First).
4 - Set the automatic adjustment of color in the display settings menu (Menu rapid Primo).
4 - Enable Themechanger within the parameters of skin
5 - Select the directory Beanico
6 - Well, everything works in automatic mode:
- The month changes automatically.
- The weather changes automatically if you use 2.9 of WeatherIgo Titidom
- The sun sets or rises with night falling gradually.
- It automatically switches on at night with weather taken into account.
For those who do not work with the weather: you can force the weather by going to Settings ThemeChanger.
ลิงค์ครับ  Roll Eyes
sk_Primo-Scheme-Beanico-v2.2
sk_primo_scheme_beanico_WeatherMod_v0.9
Thanks to Beanico and kimyaci  สำนึกผิด
ID number: 31
« ตอบ #1 เมื่อ: 04 ธันวาคม 2010, 07:19:32 »
แจ่มเลยเปลี่ยนได้อัตโนมัติด้วย  Smiley
mitzu
ID number: 1240
กระทู้: 300
Send Money to mitzu
-ได้ให้: 743
-ได้รับ: 362
« ตอบ #2 เมื่อ: 04 ธันวาคม 2010, 20:26:18 »
 (* _-)มีใครลองใส่ดูยังครับ  ไม่ทราบเอาไฟล์ไปที่ scheme อย่างเดียวหรือปล่าว  บอกกันมั่งศิ Huh?
จริงใจ...ไม่ลอกอ
Scheme Beanico v1.4:
^SuRaYoOt^ 5 3589 กระทู้ล่าสุด 27 สิงหาคม 2010, 18:33:59
โดย navamin90
sk Primo Scheme Beanico v2.0
tin_43257 4 5106 กระทู้ล่าสุด 09 กันยายน 2010, 10:42:30
โดย HS8EVL
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.06 วินาที กับ 42 คำสั่ง
