29 มีนาคม 2024, 23:02:26 *
ผู้เขียน หัวข้อ:  GJA skin for Primo 1.1. Version 2.2 เพิ่ม แก้ไขให้ใช้ได้กับ primo เสียงเตือนชุดใหญ่  (อ่าน 16457 ครั้ง)
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« เมื่อ: 19 พฤศจิกายน 2010, 11:30:46 »
--gja v.2.20
1. Changed cockpit menu selection (primary/secondary Gurjon or Arkoko).
   Primary cockpit menu - tap, secondary - long tap to the statusbar.
   Restored Screenshot button if Gurjon cockpit menu selected as primary.
   One change in Dictionary.lang: Cockpit menu -> Primary Cockpit Menu.
2. Added button "Restart" to the skin selection screen.
3. Mapchanger is now able to detect automatically which map provider is active.
   For this please place to each  map folder one small file
   (may be empty, only the name is relevant):
   !map_ta.txt - for the TA maps
   !map_nt.txt - for the Navteq maps
   !map_ot.txt - for other provider's maps
   In this case the skin will set the provider correctly during program
   start and prevent displaying wrong provider that can be caused by possible
   Mapchanger's fault.
4. Added possibility to switch building, histspeed and phoneme
   files with Mapchanger. For more information please read the
   file !README_mapchanger.txt
5. Added "!button" sound for pressing speedlimit sign for the speedcam.
6. Added possibility for audible indicator of finished backup by adding
   line to the backup.ini file:
   Sound=set.wav
NB! Utility package must be updated with skin too!
--gja v.2.19.1
1. Added setting for select Gurjon or Arkoko cockpit menu.
--gja v.2.19
1. Added ability to set fixed overspeed tolerance (Megaduck99).
2. Added fast menu for easy access to the some program's features.
   Access to the fast menu - short tap to the status bar.
   Available buttons:
   1  - track recording. Long tap: Trip Monitor.
   2  - mute/unmute sound. Long tap: Sound settings.
   3  - screen capture (old capture button removed from the main screen)
   or if 'Screen Capture' disabled:
   3  - POI visibility Setup. Long tap: Map Settings.
   4  - fast Viewpoint change (low/normal/high).
   or if 'Manual Zoom & Tilt' enabled:
   4  - Day and Night Colour Setup. Long tap: Map Settings.
   5  - Screen backlight setting.
3. Reworked backup creation scripts for better performance
   (utility package must be updated).
4. Small technical repairs
โหลดได้ที่
GJA_v2.2_480x272 ต้นฉบับ ไม่มีการแก้ไข
เพิ่มลิ้งค์ แบบแก้ไขให้ใช้ได้กับ primo เสียงเตือนชุดใหญ่ครับ (แก้ไขตำแหน่ง ขนาดตัวอักษรบอกระยะทางป้ายเตือน เพิ่มคีย์บอร์สกินกลางคืน)
มีพาสเวิร์ด คือ navthai.com
ขอขอบคุณ
wcspp แห่งเสียงเตือนชุดใหญ่
พี่ ∞EqUiNoX∞ ให้ความรู้เกี่ยวกับคีย์บอร์ดสกินกลางคืน
GJA_v2.2_800x480
ที่มา  http://www.igo8navigation.com
Thanks to Gurjon & Arkoko & kimyaci
« แก้ไขครั้งสุดท้าย: 23 พฤศจิกายน 2010, 11:26:38 โดย tryth » บันทึกการเข้า
kmathee
ID number: 6245
กระทู้: 29
Send Money to kmathee
-ได้ให้: 85
-ได้รับ: 40
« ตอบ #1 เมื่อ: 19 พฤศจิกายน 2010, 19:18:31 »
Full pack นี่ ตัวอื่นๆที่ใส่มาที่ไม่ใช่skin เอาไว้ทำอะไรบ้างครับ Huh? ขอบคุณครับ
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #2 เมื่อ: 20 พฤศจิกายน 2010, 07:34:29 »
เป็น Utility ของสกินครับ แล้วก็ตัวติดตั้งแบบไม่ใช้สกิน กลางวันกลางคืนครับ
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #3 เมื่อ: 20 พฤศจิกายน 2010, 14:12:42 »
 (แก้ไขตำแหน่ง ขนาดตัวอักษรบอกระยะทางป้ายเตือน เพิ่มคีย์บอร์สกินกลางคืน) ที่กระทู้แรกครับ
eco_rider
ID number: 10423
Send Money to eco_rider
-ได้ให้: 43
-ได้รับ: 21
« ตอบ #4 เมื่อ: 23 พฤศจิกายน 2010, 10:47:41 »
ลิ้งค์แบบแก้ไขเข้าไม่ได้ครับ ทั้ง IE & FireFox แต่ลิ้งค์ตัวเต็มเข้าได้ครับ รบกวนช่วยดูให้ด้วยนะครับ ขอบคุณครับ
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #5 เมื่อ: 23 พฤศจิกายน 2010, 11:30:07 »
ลิ้งค์สกินแบบแก้ไข ที่กระทู้แรกครับ
sahawat
ID number: 11483
กระทู้: 37
Send Money to sahawat
-ได้ให้: 58
« ตอบ #6 เมื่อ: 05 มิถุนายน 2011, 11:27:21 »
สวัดดีครับ
ผมโหลดของตัวนี้ครับ กำเสี่ย
http://www.t...ceb407f87da8
โหลดไม่ได้ครับมันบอกว่า  ไฟล์นี้ถูกลบไปแล้ว
 ฮือ ๆ
✄PiGGer✄
ชีวิต..ฉัน..เป็น..ของฉัน
s8lt memberDonate
ID number: 3608
กระทู้: 1047
Send Money to ✄PiGGer✄
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #7 เมื่อ: 05 มิถุนายน 2011, 11:50:15 »
สวัดดีครับ
 ฮือ ๆ
คงต้องรอท่าน tryth มาจัดทำ Mirror ให้ครับ แต่ถ้าไม่ใช้ตัว MoD ของท่าน Tryth ก็เลือกโหลดจากต้นฉบับก็ได้ครับ แล้วไปแต่งเสียงเตือนเพิ่มเติมเอง  Roll Eyes
http://ul.to...FullPack.zip
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #8 เมื่อ: 05 มิถุนายน 2011, 18:54:23 »
สวัดดีครับ
 ฮือ ๆ
ขออภัยผมไม่ได้เก็บสำรองไฟล์ไว้เลยครับ ตอนนี้ไปเล่น พี่โม่ 1.2 แล้วครับ
« ตอบ #9 เมื่อ: 05 มิถุนายน 2011, 22:12:10 »
ไม่แน่ใจว่าจะใช่ skin ที่คุณต้องการหรือเปล่า  ขออนุญาตคุณ tryth upload link ใหม่ให้นะคะ  ส่วน password ยังคงเดิมค่ะ  Smiley
http://www.z...e.com/zcbomT
sahawat
ID number: 11483
กระทู้: 37
-ได้ให้: 58
« ตอบ #10 เมื่อ: 07 มิถุนายน 2011, 15:53:36 »
สวัดดีครับ
 [+++]ขอบคุณครับพี่แต่ผมดหลดแล้วไม่ได้ครับพอกดเซฟมันหายไปเลยกับมาหน้าไห้เรากดโหลดใหม่ ฮือ ๆ
« ตอบ #11 เมื่อ: 07 มิถุนายน 2011, 16:29:42 »
ลอง load link จากข้อความด้านบนดูนะคะ
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #12 เมื่อ: 07 มิถุนายน 2011, 16:30:44 »
สวัดดีครับ
เอาเวอร์ชั่น 2.26 ไหม ถ้าเอาผมมีสำรองอยู่ครับ
ดาวน์โหลด
[Primo] ประมวณภาพสวย ๆ ต้อนรับการมาของ iGO Primo
narong9000 5 6822 กระทู้ล่าสุด 29 พฤษภาคม 2010, 20:53:24
โดย suthep.das
กลับหน้าจอ Primo? (อยากทราบวิธีหมุนหน้าจอให้ Primo ใน HTC Diamond)
ponsaku 9 20153 กระทู้ล่าสุด 17 กันยายน 2010, 07:41:43
โดย pdadd
IGO primo มีคำถามแต่ถามที่ห้อง primo ไม่ได้
magnic 10 8783 กระทู้ล่าสุด 14 สิงหาคม 2010, 12:39:45
โดย equinox
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.071 วินาที กับ 59 คำสั่ง
