04 มิถุนายน 2024, 13:09:23 *
หน้า: [1] 2 3   ลงล่าง
ผู้เขียน หัวข้อ: [เครื่องมือ] Beautiful Widgets v3.2 Update v5.7.5  (อ่าน 47337 ครั้ง)
-ได้รับ: 69260
« เมื่อ: 29 ตุลาคม 2010, 06:00:40 »
Beautiful Widgets
Requirements: Android
Overview: Beautiful Widgets is a set of widgets that run on the mobile Android platform.
Features:
- Nice looking clock with 12/24 hours support
- Multiple layouts and skins support
- Weather with realistic icons
- Celcius and fahrenheit temperature
- Automatic language detection
- Geolocation for the weather city, or the ability to enter the city name
- Automatic sunset/sunrise calculation
- High res graphics for WVGA Devices (such as the Motorola Droid or Nexus One)
- 1x1 beautiful Wifi/Bluetooth/Plane mode/Silent/Vibrate widgets to easily enable or disable them
- 1x1 GPS widget that act as shortcut to enable or disable location in the settings.
3.2 - 28th October 2010
- Rewrote the small toggle widgets into one widget, where you can choose the function. Please note that you will need to remove all the old widgets and replace them on the home screen.
- Toggle widgets can be skinned
- Toggle widgets can have their labels hidden
- Added a Mobile data widget toggle. This change the APN in order to deactivate the data (only known method to work)
- Added a 4G toggle widget for HTC Devices *only*
- Added a Weather 1x1 widget
- Fix a few bugs that made the settings confused between the choices of Google or Accuweather for the weather.
- Fix a bug with ANR when the phone is unlocked
- Fix a bug with weather refresh on unlock using Google weather (the accuweather values were used)
- Fix layouts for ldpi devices as well as landscape with the weather widget 1x4
- Workaround for the wrong graphics being used on widgets after an update from the market with new resources in the package
IMPORTANT: REMOVE AND RE-ADD THE WIDGETS IF YOU GET GRAPHIC BUGS, OR CLOCK ISSUE AFTER UPDATE
http://level...gets/weather
ลิงค์ครับ  Roll Eyes
very thank Diversity   สำนึกผิด
-ได้รับ: 69260
« ตอบ #1 เมื่อ: 16 กรกฎาคม 2011, 03:30:31 »
Update Beautiful Widgets v3.6
What's in this version: 3.6
- Added Weather alerts for users in the USA and with Accuweather
- Added forecast for rain, snow and thunderstorm chances using Accuweather
- Plane mode toggle widgets fixed
- Text cut in Super Clock 4x1 layout 2 corrected for little devices like HTC tattoo
- 4x1 Super Clock layouts optimized
- Added log.txt in skins of Super Clock to help designer correct their problems
- Changed data toggle widgets to write apndroid in the apn instead of [disabled]
- Fix a bug where weather was not refreshed when switching from manual location to geolocation using accuweather
- The launcher menu will check if you have a home or super clock widgets installed before offering the possibility to change the skin, so people are not confused when trying to apply a home skin over a super clock widget and vice versa
- Fix the RefreshOnWake not refreshing due to applications removing data connexion on phone sleep. Phone will do a retry when the data connexion will change in a 2 minutes window.
- Fix apply hint town when no town provided instead of forcing mountain view
ลิงค์ครับ  Smiley
noppinij
ID number: 24644
Send Money to noppinij
« ตอบ #2 เมื่อ: 16 กรกฎาคม 2011, 18:09:43 »
ขอบคุณมากๆเลยนะครับ ผมชอบแอพนี่มาก ไม่มีเหมือน โทรศัพมันไร้สีสัน สำนึกผิด
-ได้รับ: 69260
« ตอบ #3 เมื่อ: 03 สิงหาคม 2011, 00:41:29 »
Update Beautiful Widgets v3.65
3.65 - 2nd August 2011
- Added a very simple 2x1 clock widget
- Minor others bugfixes
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #4 เมื่อ: 15 ธันวาคม 2011, 21:33:46 »
Update Beautiful Widgets v3.74
Features:
- Increased timeout with the Android Market due to the overload of their servers
- Increased the timeout to connect to our skin servers as they are a bit overloaded
- Ice Cream Sandwich compatible, new 5x3 widget for Galaxy Note, revamped settings, XHDPI support, featured skins, bugfixes
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #5 เมื่อ: 18 ธันวาคม 2011, 18:57:07 »
Update Beautiful Widgets v3.75
- Add resizeable widgets support for Honeycomb and Ice Cream Sandwich
- Fix notification numbers on Gingerbread
- Fix bug in skin list refreshing on the server
ลิงค์ครับ  Smiley
tanya-04
ID number: 25898
Send Money to tanya-04
-ได้ให้: 111
« ตอบ #6 เมื่อ: 19 ธันวาคม 2011, 18:00:39 »
ขอเพิ่มเวปอื่นอีกสักเวปได้ไหมครับ เวปนี้เวลาโหลดจากมือถือ
โหลดยากจริงๆครับ ขอบคุณครับ Tongue  Tongue  Tongue
tanya Note2
-ได้รับ: 69260
« ตอบ #7 เมื่อ: 19 ธันวาคม 2011, 18:09:23 »
เดี๋ยวเข้าบ้านแล้วจะทำmirror ให้ครับ Tongue
-ได้รับ: 69260
« ตอบ #8 เมื่อ: 19 ธันวาคม 2011, 20:18:18 »
กลับเข้าบ้านแล้วนะครับ ทำ mirror ให้เรียบร้อยแล้ว ครับ  เก็กหล่อ
Mirror Beautiful Widgets v3.75
-ได้รับ: 69260
« ตอบ #9 เมื่อ: 16 มีนาคม 2012, 05:08:12 »
Update อีกแล้ว  Smiley
Beautiful Widgets v4.00 Full
Beautiful set of Widgets containing clock widget, clock and weather widget, weather widgets, date widgets and toggle widgets with skins/themes support!
Selected by Google as an Android Editor's choice and first paid application to reach 1 million of downloads! What a success driven by its community!
See why it is the best Android clock and weather widgets and the only choice for thousands of users! You probably heard of Beautiful Widgets before!
Android Central: "We love Beautiful Widgets"
Android and Me: "Beautiful Widgets is one of the essential must-have Android apps, and has been for quite some time now. If you still haven’t managed to buy the app, there’s no time to waste."
ZDNet: "The strength of Android is the ability to make the interface very personal, and Beautiful Widgets is the daddy of them all."
Now with Honeycomb tablets support (ie the Motorola Xoom, Galaxy Tab)!
- High Definition Super Clock HD widgets available in many sizes and many layouts. High quality rendering and resizable with no loss of quality!
- Display either the weather, battery icon (both with skins) or just a clock on the widget.
- 5 days Weather Forecast based on Google weather or Accuweather, with Geolocation support, automatic sunset/sunrise, also available on a weather only widget.
- Weather alerts (USA only), storm/rain/snow forecasts
- More than 15 nice Weather Animations (rain, storm, etc) for your pleasure when tapping the weather icon from the widgets.
- Moon phases, actual and a calendar for the next 4/5 phases
- Nice toggle widgets for Wifi, Bluetooth, Mobile, Brightness, GPS (shortcut), Silent, Vibrate, Plane Mode, 4G (only for a few HTC devices), Rotate, Pattern (below android 2.2) and a Timed Silence!
- More than 1000+ FREE Skins/Themes to changes the look and feel of you clock, weather icons or toggle buttons ! Impress your friends with your clock widget!
- Weather Live Wallpaper OpenGL accelerated (for supported devices only) which allow to display the weather live from your wallpaper, with many effects, physics and interactions!
- Auto-refresh weather on widgets when your phone is unlocked
- Define applications to launch when tapping the hours, date or forecast details from the widgets so you can access the most important applications very easy from our beautiful widgets.
- Introducing Beautiful Today widget which display the date using the same look as the Super Clock
- Temperature displayed in your notification bar, with access to the weather forecast. Now with the Ice Cream Sandwich look & feel if you are on Android 4.0!
- Many options in order to create your own experience!
Details:
- Super Clock widget with weather, battery or just the clock 4x3 4x2 4x1 2x1
- Weather only widget 4x1 1x1
- Battery widget 1x1
- Date widget 2x1 1x1
- Text Clock simple widget 2x1
- Toggles widgets 1x1
- Home widgets with clock and weather and 300 skins 4x1 2x1
4.00 - 14th March 2012
- Add multi-forecast
- Add skin market (see http://marke...-widgets.com)
- New Permissions are for linking your device to the cloud to device technology
- Add HD preview dialog before downloading skins
- Add an option to hide the background numbers
- New logo
- remove APN Widget for ICS and older. (API Hidden)
- Improve unlock animations
- Improve cache picture
- fix problems on notification icon for gingerbread
- some other fixes
ลิงค์ครับ  Smiley
นักเดินทาง007
ID number: 34454
Send Money to นักเดินทาง007
« ตอบ #10 เมื่อ: 19 มีนาคม 2012, 17:02:13 »
จะลองใช้ดูนะครับ... Roll Eyes
 ลองได้เลย ไม่ต้องบอกครับ
smook
ID number: 33355
Send Money to smook
-ได้ให้: 11
« ตอบ #11 เมื่อ: 10 มิถุนายน 2012, 23:04:44 »
Sony Arc s GB.62 ลงได้ครับ
-ได้รับ: 69260
« ตอบ #12 เมื่อ: 03 สิงหาคม 2012, 04:55:15 »
Update Beautiful Widgets v4.11.2
4.11.2 - 2nd August 2012
- New translations
- Fix some bugs
4.11.0:
- Add anonymous statistics
- Fix bugs on some skins not downloading
- Fix bug on Toggle for JellyBean
- Fix some crashes
4.0: Multiple weather forecast, web skin market with C2DM technology, web skin mixer and few others new features.
Visit http://marke...-widgets.com for the Desktop Skin Market!
*NEW PERMISSIONS ARE REQUIRED FOR THE WEB SKIN MARKET, C2DM AND NEW UPDATE PROCESS*
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #13 เมื่อ: 06 กันยายน 2012, 04:47:01 »
Update Beautiful Widgets v4.12
4.12 - 3rd of september 2012
- Remove Google Weather API
4.11.0:
- Fix some crashes
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #14 เมื่อ: 20 กุมภาพันธ์ 2013, 22:01:14 »
Update Beautiful Widgets v5.1.0
5.1
20/02/2013
- New weather provider WeatherUnderground
- New Forecast Fragment Lifestyles
- New widgets for tablets
- New beta channel
- New layouts for WeatherWidgets 4x1
Improve :
- The geolocation can be removed
- Add a setting to disable the weather animations
- Hide Home Fragment, and put Tutorial when there is no widgets
- New translations
- Physical menu button opens the Sliding menu in the Forecast Screen
Fix a lot of bugs
ลิงค์ครับ  เก็กหล่อ
-ได้รับ: 69260
« ตอบ #15 เมื่อ: 10 เมษายน 2013, 06:18:05 »
Update Beautiful Widgets v5.2.0
 - 5.2 (09/04/2013)
New Features
 * Addition of the daylight in ForecastScreen (available the 2nd day after the update)
 Improvements
 * Better click management on Tablet widgets
 * Remove unneeded weather calls
 * New Themes Download Service
 * WidgetConf screen simplification
 * ClockWidget 4x1 new layout and new settings
 * Forecast hours available in ClockWidget 4x4
 * Use local time by default in widgets
 Many bug fixes (see in-app changelog)
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #16 เมื่อ: 26 เมษายน 2013, 18:51:19 »
Update Beautiful Widgets v5.2.1
5.2.1 (25/04/2013)
 * Fix summer time error
 - 5.2 (09/04/2013)
 New Features
 Improvements
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #17 เมื่อ: 25 พฤษภาคม 2013, 07:02:02 »
Update Beautiful Widgets v5.2.3 b6
Bug fixes
HotFix : Crashes when screen is on
Google map crashes
ลิงค์ครับ  Smiley
-ได้รับ: 69260
« ตอบ #18 เมื่อ: 03 มิถุนายน 2013, 05:50:54 »
Update Beautiful Widgets v5.2.3 b7
Bug fixes
Google map crashes
ลิงค์ครับ  สะใจจริง ๆ
-ได้รับ: 69260
« ตอบ #19 เมื่อ: 26 มิถุนายน 2013, 21:28:49 »
Update Beautiful Widgets v5.2.3 b12
Recent changes:
New Features
 - Show a new dialog to join the BW Google+ community
 Improvements
 - Connexion when retrieving weather infos
 - Theme footprint on widgets
 - Geolocation city name should be more accurate
 - Refresh battery state on widgets when user is present
 Bug fixes
 - Crashes with Google Map
ลิงค์ครับ  เก็กหล่อ
หน้า: [1] 2 3   ขึ้นบน
800 Beautiful Wallpapers Pack!
^SuRaYoOt^ 0 3579 กระทู้ล่าสุด 28 มกราคม 2011, 01:00:26
Beautiful Nature Screensaver << ธรรมชาติสวยๆ เอาไว้พักสายตา พักใจบ้าง >>
Other Software (PC)
qaser443 0 6552 กระทู้ล่าสุด 22 มิถุนายน 2011, 12:09:28
โดย qaser443
Search Beautiful Girls from your town for night
Garmin Discussion
patkam 0 145 กระทู้ล่าสุด 20 พฤษภาคม 2024, 15:24:47
โดย patkam
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.509 วินาที กับ 64 คำสั่ง
