Thanks: gamethai showpicUpdate skin GJ6.18
240х320, 320х240, 240х400, 400х240, 400х234, 416х234, 480х234, 480х272, 800х480, 480х800
Differences from previous version:
1. Fixed button for info about the route in the map planning.
2. Added a command prompt in the menu "to skip the next paragraph.
3. Removed autom. call window "Edit Route" by adding a second prom. point.
4. With disregard for the maneuver (the window with buttons "maneuver", "Street", kilometers) long press of one of these buttons will return to the list of maneuvers route. Briefly - as it was - will return to the cabin.
5. Added support for automatic transition to the "plane" (if enabled in options) after leaving the tunnel. This option is not checked - could not find such spans, so that - should be checked. In addition, it is not clear, as will be after the loss of signal in the tunnel.
ลิงค์ครับ
Thanks to Gurjon & DVS1 & Arkoko
