Thanks: gamethai showpicPrimo is the only.
The files will be recorded as follows;
Primo / captures
Primo / utility
Primo / content / lang / Lang_French.zip
Primo/content/content/Skin/sk_Primo_Sbertaud13_480_272_EUR + _D.zip (save their resolution here)
Compatibility: igo Primo 1.1 supported Resolution: 480x272
New in this version v2.3 + EUR
- Skin to version 1.1 for only Primo igo Green
- Display Menu FM transmitter
- Added menu Berylus TMC
- Standard Menus "Navigation" and "Panorama Automatic" it indicates that we are in the top menu "System"
- Change the statement to the script output (sbexitprimo) that removes and copy.db IMGR.PRL
Should it be added (edit)
[Sbexitprimo]
1 = " DataFlash first, SDMMC Primo"
Replacing Data with the name of your flash drive is installed where PRIMO (So for example, Storage Card or My Flash Disk or SD CARD SDMMC or ....)
Replacing the primary name of the folder or by Primo is installed (example: MobileNavigator or igo9)
Sys.txt
Substituting SDMMC by the name of your drive folder where your content PRIMO (So for example, Storage Card or My Flash Disk or SD CARD SDMMC or ....)
Replacing by the primary name of the file or folder is installed, your Content (example: MobileNavigator or igo9)
[Warning]
speedcam_max_lookahead = 1000
Download sys.txt
- WINCE4.2. Must add an additional line in the mapchanger fonctionne.Il (3 = " DataFlash primo") to instruction in the sys.txt
[Mapswitch]
1 = "map_ta DataFlash primo, 1,"
2 = "map_nt DataFlash primo, 1,"
For the 1 = and 2 =
Replacing Data with the name of your flash drive where your file is installed CONTENT (So for example, Storage Card or My Flash Disk or SD CARD SDMMC or ....)
Replacing by the primary name of the file or folder you installed CONTENT (example: MobileNavigator or igo9)
For the 3 =
ลิงค์ครับ
Very thank kimyaci
![กำเสี่ย](http://www.navthai.com/smf/Smileys/SEO/f6eb47d3.gif)
![Share this topic on Ask Share this topic on Ask](http://www.navthai.com/smf/Themes/default/images/share/ask.png)
![Share this topic on Digg Share this topic on Digg](http://www.navthai.com/smf/Themes/default/images/share/digg.png)
![Share this topic on Facebook Share this topic on Facebook](http://www.navthai.com/smf/Themes/default/images/share/facebook.png)
![Share this topic on Google Share this topic on Google](http://www.navthai.com/smf/Themes/default/images/share/google.png)
![Share this topic on Google buzz Share this topic on Google buzz](http://www.navthai.com/smf/Themes/default/images/share/gbuzz.png)
![Share this topic on Live Share this topic on Live](http://www.navthai.com/smf/Themes/default/images/share/live.png)
![Share this topic on MySpace Share this topic on MySpace](http://www.navthai.com/smf/Themes/default/images/share/myspace.png)
![Share this topic on Twitter Share this topic on Twitter](http://www.navthai.com/smf/Themes/default/images/share/twitter.png)
![Share this topic on Yahoo Share this topic on Yahoo](http://www.navthai.com/smf/Themes/default/images/share/yahoo.png)
