29 เมษายน 2024, 18:15:16 *
ผู้เขียน หัวข้อ:  'MapSelect': a new program to select maps in your Garmin or storage card  (อ่าน 2550 ครั้ง)
nitase
ID number: 1512
กระทู้: 30
Send Money to nitase
-ได้ให้: 111
-ได้รับ: 35
« เมื่อ: 03 สิงหาคม 2010, 17:17:12 »
Summary
'MapSelect' is nice program that allows you to use multiple maps on your Garmin device or on your storage card.
The number of valid maps is determined by your Garmin, so you can't use more maps simultaneously, but it allows you to easily select from a number of maps on your device or storage card.
Description
One problem with Garmin devices is that very few filenames are accepted as valid map names. Normally MapSource creates a map called 'gmapsupp.img'. Also unlocked maps are also mainly offered under the same name.
A good example: on a Nüvi device with storage card of 4G, only one map will be found: 'gmapsupp.img'! Internally also the mapsnames gmapprim.img and gmapprom1.img are allowed.
I wanted more maps available on my Garmin, but also an easy way to select them. So, I wrote a PC program that makes it easy to select from up to ten maps on a Garmin device and storage card.
The trick now is to give your maps names that are a bit different such as gmapsupa.img, gmapsupb.img etc. Then the program 'MapSelect' allows you to rename them to maps that Garmin sees as valid.
As a bonus, the program can edit the map name embedded in the file!
The rar file contains the program plus a document with detailed description how to use it....
http://rapid...ect.rar.html
http://www.m...KJ3NV63NGood luck to all and comments are highly appreciated!
QS
Last edited by wwoef; 07-18-2010 at 09:50 AM. Reason: Current s/w version is 1.00.0006
blakcat
ID number: 403
กระทู้: 100
$20.27 credits
Send Money to blakcat
-ได้ให้: 228
-ได้รับ: 76
« ตอบ #1 เมื่อ: 04 สิงหาคม 2010, 18:17:54 »
รบกวนครับผม ทำไมผมโหลดไม่ได้ หรือลิงค์โหลดมีปัญหา  ขอบคุณครับ
offshore
VIP เมื่อ 21-10-2009 2Y
ID number: 1621
กระทู้: 61
$160.00 credits
Send Money to offshore
-ได้ให้: 355
-ได้รับ: 59
« ตอบ #2 เมื่อ: 04 สิงหาคม 2010, 22:06:18 »
ลองดูครับ
http://www.m.../?d=KJ3NV63N
« แก้ไขครั้งสุดท้าย: 05 สิงหาคม 2010, 06:49:03 โดย offshore » บันทึกการเข้า
ปรับ balance Storage and Program Memory พอเปิดขึ้นมาใหม่ มันก็ยังอยูีที่เดิม
Billy J. 2 2808 กระทู้ล่าสุด 30 พฤศจิกายน 2010, 13:59:46
โดย Billy J.
มันบอกว่า "please insert mobile xt data card and then restart the program"
Garmin Discussion
Dechie 1 2137 กระทู้ล่าสุด 11 มิถุนายน 2011, 21:41:27
Garmin StreetPilot C320 ใส่ card ความจุสูงสุดกี่จิกะไบต์ครับ
Garmin Discussion
cbinno 0 1592 กระทู้ล่าสุด 22 กรกฎาคม 2012, 17:16:40
โดย cbinno
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.034 วินาที กับ 41 คำสั่ง
