20 เมษายน 2024, 01:32:55 *
หน้า: [1] 2   ลงล่าง
ผู้เขียน หัวข้อ:  (Evergrow) China 4.3 "- 5.0" PNA / PND Navigators  (อ่าน 301094 ครั้ง)
-ได้รับ: 72112
« เมื่อ: 01 สิงหาคม 2010, 23:31:39 »
Credit : FuntPND @ 4PNA
I decided to write a little about the navigator of Evergrow Technology.
I was caught in the standard Chinese navigator slim body. On board AtlasIV, 128Mb RAM, 2Gb internal drive, Bluetooth, FM, Win CE 6.0.
Most of icons and style of the native envelope licked the envelope with YF BlackGold. It looks like this:
The surprise was vinda with plenty of MUI, including Russian:
Navigator is similar to the navigator Apical, probably because of the version of WINDOWS. It as well as work on Apical programs, which often do not work on Win CE 6.0.
Native shell is stored in a hidden partition \ datastorage \ shell \. In principle, easily modified, will have time to make page navigation start programs by clicking on the navigation buttons.
From the navigation software running all the same and just as at Apical. Works iGo8, Garmin XT, Ozi Explorer, Visicom (not shown some elements of the interface and keyboard). Navitel not work, but the licensed version for YF starts and displays the ID, which shows the same way and my own shell. Trying to get the Chinese utility to change the Device ID.
Unfortunately Bluetooth can be used only as a hands-free and quality svzyai on the preliminary tests are not very.
It seemed to me my own envelope a little bit slower Apical, but in general devays pretty good.
In these browsers explorer.exe is loaded with the shell, but the desktop and taskbar, I get failed. They are visible only when you exit in Win CE and unloading shells from the settings menu shell. If you kill explorer.exe, then run it again, then I also did not work  Lips Sealed
Firmware CP4_68BT_128_CE with a shell with a button function in Win CE here.
Firmware Version:
NBOOT: 80.33
EBOOT: 80.26
OS: 091208.4.08.51.43.E
ความคิดเห็น Global Mod รอมรุ่นต่าง ๆ สามารถดาวน์โหลดได้จากที่นี่ครับ :http://www.evergrowtek.com/en-us/Download.asp
-ได้รับ: 72112
« ตอบ #1 เมื่อ: 01 สิงหาคม 2010, 23:38:08 »
Additional Account native menu to start the navigation software and a patch that eliminates the installation of the shell is not the Cyrillic code page.
And so did an additional page to start the navigation software. Ie by clicking on the GPS in the main menu will no longer run the program selected in the settings, but will appear a new menu with a choice of programs installed and configured with ready icons for popular navigation software.
View menu:
All this in the appendix. To set this page to unzip the archive to any folder on the card or internal memory and run GPSPage.exe.
Periodically flies charset Cyrillic and Russian MUI in WINDOWS directory; as I understand it, the shell looks that the current language is English (and Russian translation is pretty bad) and install the English MUI and code page.
For regardless of the language selected in the menu value nls-> DefaultACP in the registers was equal to 1251 (ie that in Ozi Explorer and other programm небыло kryakozyabrov) need to run the file CyrCodePage.exe from the archive. It will replace the file SYSLNG.EXE of native shell patched.
With MUI has not yet figured out ...
-ได้รับ: 72112
« ตอบ #2 เมื่อ: 01 สิงหาคม 2010, 23:47:27 »
About USB-Host
like asking. I have - happened. Opened, resistor dopayal 1kOm (see photo).
Received USB-Host. flash usb'shnye - sees. He sees the same bluetooth adapter (usb'shny), but no firewood. Those files that come across on the forum (bthusb.dll) - do not fit (in console debug port when you specify that the driver crashes with an error, it seems from the fifth does not fit). I'll try to compile these logs for the sixth WINDOWS.
It is suspected that the mode USB-Client enough that black fourth contact (ID) in razmeme strap should sit on the ground. Not yet tested it.
WMS who will help.
USB-Host, USB-Client
Checked. That's what happened:
1. Switch from one mode occurs when the device is switched (ie, cable will need to insert a stop).
2. If stuck in the usual line - the device will be as USB-Host
3. If the cord is plugged in which the contact ID is connected to Vcc (I plugged in via 650 ohms) - the device will be a USB-Client
(When disconnecting the cord - transforms into USB-Host, and there remains even if the cord stick back)
-ได้รับ: 72112
« ตอบ #3 เมื่อ: 01 สิงหาคม 2010, 23:56:50 »
Evergrow รุ่นอื่น ๆ
-ได้รับ: 72112
« ตอบ #4 เมื่อ: 02 สิงหาคม 2010, 00:02:06 »
firmware for
NBOOT: 80.33
EBOOT: 70.26
OS: 091208.4.07.51.43.E
MEM: 48.6M / (F) 21.1M / (U) 27.5M
GUID: 0946-00-00-09330000
EVERGLOW 6.0
50.8 MB RAM
ARM1136JF-S AT840 (533MHz)
without friction, with AV-in.
(^_^)
Exp 16-02-2012
ID number: 3073
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #5 เมื่อ: 11 สิงหาคม 2010, 09:02:49 »
รบกวนท่านที-เร็กซ์ทีครับ เครื่องผมเปิดไม่ติดหลังลง Primo เปิดเห็น logo รูปรถแล้วก็ดับไปเลย
รายละเอียด
mainboard ของ L84A
http://www.evergrowtek.com/en-us/Product_data.asp?ID=39
ไม่ทราบว่าต้อง up rom ไหมครับ กดบุ่ม  reset แล้วก็เหมือนเดิมครับ primo ทำเราได้ลงคอ...
ขอบคุงครับ
-ได้รับ: 72112
« ตอบ #6 เมื่อ: 11 สิงหาคม 2010, 12:20:55 »
รายละเอียด
mainboard ของ L84A
ขอบคุงครับ
ตัวนี้ถ้าเป็นแรม 128 ไม่น่าเกี่ยวกับการรันไม่ได้นะครับ
(^_^)
Exp 16-02-2012
ID number: 3073
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #7 เมื่อ: 11 สิงหาคม 2010, 13:05:24 »
ตัวนี้ครับ
แรม 64 ครับผม
และก็ข้างๆ เขียนว่า FD4310
วิธี up rom เหมือนเครื่อง YF ไหมครับ
ช่วยทีครับ
-ได้รับ: 72112
« ตอบ #8 เมื่อ: 11 สิงหาคม 2010, 16:05:08 »
ไม่ทราบได้ครับว่าเป็น EverGrow หรือไม่อย่างไรครับ Up รอมไปอาจเปิดเครื่องไม่ติด เพราะลำพังแค่บอดี้แบบนี้ใช้กันเป็นสิบ ๆ ยี่ห้อ ถ่ายรูปหน้า shell และ info ของเครื่องคุณมาแปะให้ดูดีกว่า เดี๋ยวงานเข้า
(^_^)
Exp 16-02-2012
ID number: 3073
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #9 เมื่อ: 11 สิงหาคม 2010, 17:20:43 »
shell และ info เข้าดูไม่ได้ครับ เห็นแค่ logo รูปรถแข่ง แบบนี้ครับ
แล้วก็ดับไปเลย
mainboard แบบนี้ครับ L84A
รุ่น FD4310 ครับ ส่วน body ก็ตามกระทู้ข้างบนครับ มีปํญหาหลังเปิดพีโม้ ครับ
แนะนำทีครับ
-ได้รับ: 72112
« ตอบ #10 เมื่อ: 12 สิงหาคม 2010, 13:35:42 »
evergrow ตัวที่ผมเคยใช้ไม่ใช่หน้าตา bootscreen แบบนี้ครับ
ถ้าค้างอยู่ที่หน้า boot แล้วไม่ไปใหนต่อ ไม่น่าเกี่ยวกับ Primo แล้วครับ อาจเป็นที่รอมครับ ลองติดต่อผู้ซื้อก่อนนะครับ ว่าช่วยแก้ไขอะไรได้บ้าง
krooyak
ID number: 1744
กระทู้: 144
Send Money to krooyak
-ได้ให้: 152
-ได้รับ: 157
« ตอบ #11 เมื่อ: 13 สิงหาคม 2010, 22:57:14 »
รายละเอียด
mainboard ของ L84A
ขอบคุงครับ
เครื่องผมเป็นเหมือนกันครับ ต้องส่งเคลมครับ
เห็นช่างที่บริษัทเค้าบอกว่า รอมเจ๊งครับ ต้องแฟลชรอมใหม่อ่ะครับ
สงสัย ทำไมช่างเปิดได้ครับ
ใชัโปรแกรมครับสำหรับเปิดเครื่อง อยากศึกษาครับ
phakboong
ID number: 13
กระทู้: 293
$5005.03 credits
Send Money to phakboong
-ได้รับ: 418
« ตอบ #12 เมื่อ: 14 สิงหาคม 2010, 09:15:20 »
น่าจะเป็นพวก โปรแกรม JTAG ครับ ต่อเข้ากับ ROM ตรงๆเลย
(^_^)
Exp 16-02-2012
ID number: 3073
กระทู้: 308
Send Money to (^_^)
-ได้ให้: 46
-ได้รับ: 466
« ตอบ #13 เมื่อ: 15 สิงหาคม 2010, 20:31:05 »
รูป shell แบบนี้เลยครับ
ไม่ทราบว่าหากมีเครื่องเหมือนกันแล้วจะ copy rom อีกเครื่องอย่างไรครับ
ขอบคุณทุกท่านที่ช่วยเหลือครับ ฮือ ๆ
-ได้รับ: 72112
« ตอบ #14 เมื่อ: 15 สิงหาคม 2010, 20:46:01 »
ไม่สามารถทำได้ครับ ลองดูที่นี่ครับ http://www.n...topic=3578.0
เครื่องคุณเป็นบอร์ด PL ไม่ใช่ yf ทำไม่ได้ครับ
SnoopyZ
ID number: 654
กระทู้: 77
$380.07 credits
Send Money to SnoopyZ
-ได้ให้: 162
-ได้รับ: 76
« ตอบ #15 เมื่อ: 19 สิงหาคม 2010, 16:33:32 »
แล้วก็ดับไปเลย
แนะนำทีครับ
boot หน้านี้ ของ MTK หรือปล่าว
เหมือนของผมเลย
P.A.NAVIGATOR
ID number: 8419
กระทู้: 123
$1300.11 credits
Send Money to P.A.NAVIGATOR
-ได้ให้: 202
-ได้รับ: 252
« ตอบ #16 เมื่อ: 08 พฤษภาคม 2011, 20:53:13 »
แล้วก็ดับไปเลย
แนะนำทีครับ
BOOT แบบนี้น่าจะเป็น SiRF บอร์ด YF ครับ
ผมขาย GPS ที่ Boot แบบนี้เลยครับ เป็น SiRF YF ครับว่าแต่ RAM เท่าไหร่ครับ 64 หรือ 128 ครับ พอดีมี 2 แบบครับ
*หากเครื่องเป็น Window CE-5 เป็น MTK ครับ
*หากเครื่องเป็น Window CE-6 เป็น SiRF ครับ
หากอยากได้ ROM ก็ PM มานะครับ จะอัพให้ครับ
ปล.ไม่รับผิดชอบนะครับ หากแฟลชแล้วเจ๊งหรือใช้ไม่ได้ เพียงแค่อยากช่วยเหลือครับ
akasit
ID number: 20565
Send Money to akasit
« ตอบ #17 เมื่อ: 12 กรกฎาคม 2011, 16:17:08 »
ของผมก็ค้างเหมือนกันครับ หน้าจอแบบนี้เลย  ฮือ ๆ
เครื่องเป็น Window CE-5 ไม่รู้ว่าเป็น MTK หรือ SiRF ครับ
อยากได้ ROM ครับ อัพให้ได้ไหมครับพี่ รบกวนขอวิธีทำด้วยนะครับ..ขอบคุณครับ  กำเสี่ย
akasit2008@hotmail.com
« แก้ไขครั้งสุดท้าย: 12 กรกฎาคม 2011, 16:24:04 โดย akasit » บันทึกการเข้า
ID number: 327
« ตอบ #18 เมื่อ: 12 กรกฎาคม 2011, 16:47:31 »
ce5 มีแต่ sirf3 ไม่ก็ mtk ครับ
akasit
ID number: 20565
« ตอบ #19 เมื่อ: 14 กรกฎาคม 2011, 09:24:32 »
แล้วผมจะแก้ไขได้ยังไงครับคุณ Groovygang เครื่องผมเปิดมามันค้าง แต่ถ้าปล่อยทิ้งไว้สักวันก็เปิดได้เหมือนเดิม
พอใช้งานไปสักพักปิดเปิดใหม่ก็ค้างอีก เป็นอาการแบบนี้ไม่รู้จะทำยังไง เครื่องจีนด้วยไม่มีประกัน  ฮือ ๆ
หน้า: [1] 2   ขึ้นบน
แรงที่สุด..GPS รุ่น PG702 จอ HD 7"+SiRF-V+Cpu800+"RAM256"+Rom4GB+Bluetooth+AV-In ^^
P.A.NAVIGATOR
P.A.NAVIGATOR 2 18355 กระทู้ล่าสุด 14 มกราคม 2014, 10:03:05
โดย P.A.NAVIGATOR
ช่วยผมหารอมของ evergrow ด้วยครับ GPS DEDAO 4.3
ห้องรอม
peng 2 2646 กระทู้ล่าสุด 24 กุมภาพันธ์ 2015, 16:40:33
โดย peng
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.259 วินาที กับ 68 คำสั่ง
