1. Added "Recalculate info" - display information after the
recalculation. If after recalculation distance or time changed,
then on the top of screen will be shown strip with information how much
they has been changed.
2. Added "Follow arrive time" - control time of arrival. When you
create a route, calculated time of arrival will be saved (It can be seen in the trip
computer) and it does not change, but all the time will be compared to the
current "arrive time", and if you are behind schedule on the button in the cockpit with the
"time arrival" red dot will be shown, and if ahead of schedule
the dot turns to green. Time can be updated only if you create a new
route, change the method of the route or tap on "arrive time" in the
trip computer.
3. Added selection of the function of the "3D/2D" button.
4. Remove long tap from “Skip Navigation Menu” , but added more buttons.
5. Technical repairs.
Using skins:
- Downloaded the skin, day and night, as they are in the zip, place in a folder Primo / content / skin (if necessary - to create a folder and if the downloaded skin in RAR-archive - unzip and took out a ZIP-archive)
- Run the program, select the skin (set-display [More> Settings> Display])
- If necessary to restart the program
- If the skin is not listed, the possibilities are: no skin in the folder, the skin is not in ZIP-archive or the skin package is unpacked, the skin is not suitable for your permission or your version of Primo.
ที่มา ขอขอบคุณ kimyaci แห่ง
www.igo8navigation.com
