23 พฤษภาคม 2024, 23:12:06 *
ผู้เขียน หัวข้อ:  PRIMO Bidru51 EUR V1.0  (อ่าน 2755 ครั้ง)
« เมื่อ: 21 มิถุนายน 2010, 06:48:45 »
Thanks: gamethai  showpic
PRIMO Bidru51 EUR V1.0 19/06/2010
supported_resolutions = 480_272
V1.0 + EUR
- Modification of each fund info (size and Appearance) (Bidru51)
- Added button on the navigation screen of the "with or without share" (Bidru51)
- Announcement by clicking on the audio button toll (Bidru51)
- Set the Transparency unified most info (Bidru51)
- Added average speed on the course (Bidru51)
- Turning on / off "settings in the time trial before the next maneuver (with offset second maneuver info) (Bidru51)
- Activation "on / off" in the display settings of the average speed
- Changing color info button info. (Bidru51)
- Change colors to suit exceeded the speed (Bidru51)
- Offset on the right half of visual alerts radar (Bidru51)
- Change color of heading out of the roundabouts (Bidru51)
- Establishment of radar images of the standard EUR + (Sbertaud Bidru51 with images)
- Setting up the button to download the DragMode Add / edit an ((Sbertaud) icons by Modified bidru51)
- Replacing the MENU button label by speed. (Sbertaud)
- Long press the MENU button (so mails speed) leaves Primo (Sbertaud)
- Creating a settings menu in the settings for the skin. (Sbertaud)
- With direct parameters of the skin with long press of the Fast Menu button. (Sbertaud)
- In the quick menu, long press the volume button in the Controls reference volume. (Sbertaud)
- The traffic alerts are notes TTS. I gave them as WAV Primo for the skin. Except note that the sounds are eaten .. finally! (Sbertaud)
- To adjust the volume of the sound settings Using camera alerts in the alerts volume control. (Sbertaud)
- Expansion of the hard-news button News (Sbertaud)
- The activation of the radar lies in the parameters of the skin / radar (Sbertaud)
- Parameters = 1 and note extra_settings experimental_features = 1 are in the sys.txt Necessary. They are enabled by default. (Sbertaud)
- Added panel to turn ban, ban Meaning ... (Sbertaud)
- Added Mapchanger (Button in the DragMode) (Sbertaud)
ลิงค์ครับ  กำเสี่ย กำเสี่ย
very thank kimyaci
แก้ไขภาพนิดนึงครับ ลงผิดอัน ขอบคุณ keang-kt  สำนึกผิด
« แก้ไขครั้งสุดท้าย: 21 มิถุนายน 2010, 10:05:12 โดย surayoot » บันทึกการเข้า
« ตอบ #1 เมื่อ: 21 มิถุนายน 2010, 09:44:12 »
น่าจะเป็นรูปนี้นะครับ  ;)
PRIMO Bidru51 EUR V1.1
tin_43257 0 2204 กระทู้ล่าสุด 27 มิถุนายน 2010, 03:26:41
โดย tin_43257
PRIMO Bidru51 EUR V1.2
^SuRaYoOt^ 0 2062 กระทู้ล่าสุด 28 มิถุนายน 2010, 14:45:46
PRIMO Bidru51 EUR V2.2 + 2.3 + 2.4 +2.5 อัพเดท
^SuRaYoOt^ 3 4881 กระทู้ล่าสุด 29 สิงหาคม 2010, 02:12:08
โดย tin_43257
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.055 วินาที กับ 38 คำสั่ง
