28 เมษายน 2024, 05:58:02 *
ผู้เขียน หัวข้อ:  iGO MotoNav™ for Android™  (อ่าน 23942 ครั้ง)
-ได้รับ: 72125
« เมื่อ: 27 เมษายน 2010, 01:05:23 »
Requirements:Android OS based device with WVGA resolution
Overview: iGO MotoNav™ is a complete door-to-door, turn-by-turn 3D GPS navigation solution for Android™ mobile devices based on Nav N Go’s navigation software engine. It guides you to your destination with the help of outstanding 3D graphics, clear visual cues and precise voice instructions. This release will work virtually with every iGO8R3/R4 compatible content (including maps, buildings, pois, landmarks and elevations)
http://www.motorola.com/Consumers/US-EN/Consumer-Product-and-Services/MOTONAV
Prerequisites:
1. You must have a device supporting 854x480(WVGA) resolution
2. If you have My Way 2009 for Android or Motonav DEMO installed on your device, you must uninstall these and reboot the device prior this installation
Download instructions:
http://rapidshare.com/files/342583577/Motonav_JM-PPCW.rar
<no-pass>
Mirror:
http://www.ex.ua/get/114943275265/1202886
<no-pass>
Installation Instructions:
1. Install the supplied APK on your device
2. Unzip the content of the SDCard.zip to the root of your SD Card.
3. Copy your content (maps, poi, 3D, elevations) to your SD Card's \Motonav\Content directory
4. Insert your SD Card into the device and launch the application from phone menu
NOTE: Because of enormous size of the original package, the content (maps, poi, buildings, elevations and additional voice files) are NOT included! You need to add these by manually copying them to your SD Card's iGO\Content directory. You can find a great collection of compatible content here.
Enjoy,
JM
All Credit to Jetmouse @ p p c Warez. org
unclenart
ID number: 2558
Send Money to unclenart
« ตอบ #1 เมื่อ: 27 เมษายน 2010, 08:53:47 »
ค้นหา poi เป็นภาษาไทยได้ไหมครับ
ขอบคุณมากครับ
be_tii
ID number: 8236
Send Money to be_tii
-ได้ให้: 11
« ตอบ #2 เมื่อ: 11 มิถุนายน 2010, 08:24:49 »
ขอไปลองครับ
amfitamint
ID number: 9342
Send Money to amfitamint
-ได้ให้: 14
« ตอบ #3 เมื่อ: 30 กรกฎาคม 2010, 00:25:32 »
ทำได้ขนาดนั้นเลยหรือครับเลยแล้วwinCEจะทำไงนี้ แต่ผมลองคุยกับทางโรงงานของ จีนทำไทยไม่ได้ แต่คนไทยเก่งกว่าอิอิอิอิ
jnawin
ID number: 10725
Send Money to jnawin
-ได้ให้: 11
« ตอบ #4 เมื่อ: 27 สิงหาคม 2010, 14:21:12 »
สวัสดีครับ ผมนำไปติดตั้งใน GalaxyS ครับ แต่มันค้นหาดาวเทียมไม่เจอสักที ลองค้นหาถึงวิธีการตั้งค่า Port GPS ในเวบแล้วแต่ยังไม่เจอวิธีการแบบละเอียดครับ เครื่องผม Root แล้ว ลง BusyBox แล้ว เปิดเข้าไปแก้ sys.txt ยังไงครับด้วยโปรแกรมอะไร รบกวนสอบถามด้วยครับ แล้วพิกัดของ GPS ที่ควรตั้งค่าที่เหมาะสมคืออะไรครับ ขอบคุณครับ
P-S-N
Donateร้านค้าสมาชิก
ID number: 6455
กระทู้: 179
$180.35 credits
Send Money to P-S-N
-ได้ให้: 112
-ได้รับ: 507
« ตอบ #5 เมื่อ: 29 สิงหาคม 2010, 17:13:51 »
Samsung Galaxy S หน้าจอจะ 800*480 ถ้าเอาตัวนี้ไปใส่จะอาจมีปัญหาครับ หน้าจออาจล้นนะครับ น่าจะไปใช้ตัวนี้ครับ http://www.navthai.com/smf/index.php?topic=3524.0 800*480, 480*800
พูดถึง Samsung Galaxy S ผมมีลูกค้าซื้อเสาอากาศผมไป 3 ท่าน 3 เครื่องอาการเดียวกันหมดเลยภาครับสัญญาน GPS แย่ครับจับสัญญานช้ามากๆ ผมใช้ WellcoM A88 เปิด เครื่องพร้อมกันในรถ เครื่องของผมล็อคสัญญานได้ในไม่เกิน 30 วินาทีส่วน SGS ล็อคไม่ได้เลย อีกท่านนึง Sumsung i8000 ก็เหมือนกันถ้าอยู่ในรถจะจับสัญญานไม่ได้เลยแต่ในขณะที่เครื่อง WellcoM ของผมนั่งอยู่ข้างๆ กันกลับรับสัญญานได้สบายๆ
« แก้ไขครั้งสุดท้าย: 29 สิงหาคม 2010, 22:58:54 โดย P-S-N » บันทึกการเข้า
เสา GPS คลิ๊ก
nirvana1978
ID number: 12366
Send Money to nirvana1978
-ได้ให้: 21
« ตอบ #6 เมื่อ: 08 กันยายน 2010, 16:33:16 »
ขอบคุณมากครับ ผมเอาไปลองกับ Acer Liquid E S100 แล้วใช้ได้เต็มจอครับ  แต่ฟังชั่นมันน้อยไปหน่อยป่ะครับ
sbelectronic
ID number: 4357
Send Money to sbelectronic
« ตอบ #7 เมื่อ: 05 ตุลาคม 2010, 00:49:53 »
 เก็กหล่อ
มีใครเคยลองกับ Samsung Spica บ้างครับ
iGO Amigo (Motonav) for WVGA Thai Edition « 1 2 ... 8 9 »
keang-kt 164 146309 กระทู้ล่าสุด 26 สิงหาคม 2012, 00:50:46
โดย boyz_1412
iGO MotoNav for Android จะมี version HVGA ป่าวครับ
pecpys 1 5375 กระทู้ล่าสุด 15 พฤศจิกายน 2010, 15:33:08
โดย keang-kt
ตามหา map, poi, dem และ building สำหรับ iGO Amigo (Motonav) for WVGA ค่ะ
nokepk 2 5856 กระทู้ล่าสุด 06 พฤษภาคม 2011, 13:14:44
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.085 วินาที กับ 57 คำสั่ง
