29 เมษายน 2024, 10:46:20 *
ผู้เขียน หัวข้อ:  น่าสนใจครับ.. เลยเอามาฝาก  (อ่าน 5118 ครั้ง)
« เมื่อ: 06 เมษายน 2010, 22:05:45 »
คำถาม :
Hi,
Can you help me with unlock Windows in this Chinese GPS.
http://cgi.ebay.ie/5-0-5-Touch-Screen-GPS-FM-MP3-4-FREE-USA-EURO-MAP-2GB_W0QQitemZ300414130175QQcmdZViewItemQQptZGPS_Devices?hash=item45f213d7ff
I have 2GB SD card with Igo8 - working fine, but I want try something else i.e. Garmin.
Real photos:
คำตอบ :
In Poland that's Lark Freebird 50.1.
Unlock and some info withaut this gps.
http://www.m...&start=0
If you have a moment of time and can afford to comp used up to perform this operation, you are a person that is not possible to stretch the fraudsters and naciagaczom the allegro, who will be the same thing from you since 10-100zl. In addition, you will learn a few other interesting things they say you do not.
Here we go.
Lak with WinCE 5.0 50.1
How to unlock?
Method I:
1.) The first thing you should do is download a file from the address below and paste in our navigation, that is, connect the PC via ActiveSync.
We find the path \ SDMLC \ and it wzucamy your downloaded file.
http://www.s...tformway.exe
2.) We go to the navigation menu and then Settings and change the path for the navigation program.
then pkazujemy path to the file previously downloaded.
We accept and we have already unlocked navigation.
However, note. This method is quick and easy wmiare, but unfortunately there are problems with the navigation block to the state fabrycznego.Zalecam 2 way.
Method II:
Download the script and wypakowywujemy ResidentFlash to navigate to and then enter the navigation menu and then Settings and change the path for the navigation program, which shows the path to the file from the package.
The script works as follows:
When we inserted the card into the device when you press the Navigation, fires We Desktop. But when the card is not in the slot, run the software factory, which MapaMap.
Lark 50.1 works on the following port:
Port: 1
Transmission: 4800 or 38400
A copy of ActiveSync and CeRegEdit is available at:
http://chomi.../legalne_gps
A few additional comments.
How to change wallpaper?
We go to the desktop device / Control Panel / Display and select your file from the wallpaper.
A pleasant surprise for us is support for other formats than BMP files.
Hidden partition.
Connecting the navigation into the PC and uniting ourselves with her via MyMobiler'a. Then you activate your user address bar, like the screenshot View / Address Bar. Enter the Residentflash then we add the number 2 at the end and click ENTER.
Hidden partition contains the Main Menu navigation, which we get from the manufacturer.
A copy of the hidden partition:
http://rapid...sh2.rar.html
http://www.m.../?d=QQI0S3Y9
http://www.f...ntFlash2_rar
http://www.b...ile/16470813
FM Transmitter from navigation?
Possible. Re-enter the hidden partition then you can locate ResidentFlash2 FM.exe. Let us note, and then click Edit / Copy. Now exit and enter the SDMLC and climate Edit / Paste Shourtcut what it means to do a shortcut to this application.
NOTE:
To transmitter function correctly hook up the USB cable, it is precisely because he serves as antenna
Reset?
Reset is, but for less inquisitive malozauwazalny, tymbardziej when no operating instructions read: D
Reset is the SD card slot, a small hole.
MENU buttons hidden factory.
You need to replace original file in a hidden partition on the ten.Oczywiscie ResidentFlash2 remember the backup.
http://www.p...00032sc2p96u
Think of the post:
http://www.m...15014#115014
Screenshots:
New possibilities factory MPlayer.
Please extract the downloaded file and replace the existing partition of ResidentFlash2.
Parcel (wma + wav, mp3 + wav, wma + mp3)
Odtwaza also * lrc files or karaoke.
http://rapid...lay.zip.html
http://hotfi...lay.zip.html
http://www.m.../?d=BMSAT37L
http://www.b...ile/16593449
Lak with WinCE 6.0 50.1
How to unlock?
Below is a script to unlock as well as copies of the register and the hidden partition
Copy ResidentFlash2: http://freak...6.0.rar.html
A copy of the registry CeRegEdit: http://www.2...WinCE60.html
Copy ActivSync: http://www.2...WinCE60.html
Unlock Script Morth'a: http://www.2...t_WinCE.html
Thanks to all who contributed to the improvement of that navigation.
Uwaga.Nie mix of the Lark of the files that are running Windows CE 5 CE 6 files and vice versa.
Cards supported by the device:
- Kingston:
- SD 256 MB
- 1GB SD
- 2GB SD
- 8GB SDHC
- Transcend:
- 4GB SD
- KODAK:
- 64 MB SD
- EMTEC:
- 1GB MicroSD with adapter
Topics for desperadoes:
Hard Reset the Larku 50.1? Possible! http://www.m...&start=0
Changing the Startup Logo to another: http://www.m....php?t=18250
Pozdro: satan9
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.051 วินาที กับ 34 คำสั่ง
