1. Using registry notifications instead of polling for updating notifications (bubbles, date, time, etc.). Notifications (and reloadIcon) should now appear immediately. Battery foot print should also be smaller.
2. Icon, text, circles, offset sizes, etc. are scaled automatically if the application is launched in a different resolution than the one in settings.xml (LastConfiguredAt).
3. Bubbles are alpha blended.
4. Position, size, text, etc. of bubbles are configurable.
5. Added background image support for static bars (bottom bar and top bar). Gradient background can now be used even when a wallpaper is set. The background (gradient or image) of static bars can be alpha blended to the wallpaper.
6. ShrinkToFit option of static bars now shrinks the text height in addition to the icon width.
7. Added font settings dialog.
8. Renamed "GPRS State" icon to "Cell Network State".
9. Added "Missed Calls & Signal Strength & Operator Name" icon.
10. Added "Unplayed Voice Mails" icon.
11. Added "Irda State" icon.
12. Added "Phone Profile" icon.
13. No sound or vibration on launch if current profile is silent.
14. When battery is charging a dot is shown before the battery percentage to indicate charging.
15. If operator name is empty show NA for signal.
16. Changed the field "type" in the icon settings dialog from dropdown to droplist.
17. Fonts in the fonts subdirectory are automatically added/removed.
18. Load strExec and strParameters (in addition to nScreen, nIcon, strName, and strImage) from HKLM\Software\iPhoneToday\Icon...\ when HKLM\Software\iPhoneToday\reloadIcon is set.
19. Added a separate text quality option for text inside icons.
20. Added new pressed icons.
21. Added minimize OnLaunchIcon option (you have to manually edit settings.xml).
22. Added UpdateWhenInactive option (you have to manually edit settings.xml) to always update notifications even when window is inactive. The default value is 0 to save battery.
คำแปลจากภาษา ภาษาอังกฤษ เป็นภาษา ภาษาไทย จากอากู๋
1 แจ้งการใช้รีจิสทรีแทนการ สำรวจการปรับปรุงการแจ้งเตือน (ฟองวันเวลา ฯลฯ ) แจ้ง (และ reloadIcon) ควรจะปรากฏขึ้นทันที แบตเตอรี่พิมพ์เท้าควรมี ขนาดเล็ก
2 ไอคอนข้อความวงกลม offset ขนาด ฯลฯ จะปรับขนาดโดยอัตโนมัติหากโปรแกรมจะเริ่มต้นในความละเอียดที่แตกต่างกันกว่า หนึ่งใน settings.xml (LastConfiguredAt)
3 Bubbles เป็น alpha ผสม
4 ตำแหน่ง, ขนาด, ข้อความและอื่น ๆ ของฟองที่กำหนด
5 พื้นหลังการเพิ่มภาพสำหรับ แถบคง (แถบด้านล่างและด้านบนแถบ) พื้นหลังไล่ขณะนี้คุณ สามารถใช้แม้ว่าจะมีการตั้งวอลล์เปเปอร์ พื้นหลัง (ไล่ระดับสีหรือภาพ) ของแถบคงสามารถ alpha ผสมกับวอลล์เปเปอร์
6 ตัวเลือก ShrinkToFit บาร์คง now shrinks ความสูงตัวอักษรนอกจากความกว้างของไอคอน
7 เพิ่มการตั้งค่า font โต้ตอบ
8 เปลี่ยนชื่อไอคอน GPRS รัฐ"เป็น"เครือข่ายเซลล์ State"
9 เพิ่ม"โทรพลาดและความแรง ของสัญญาณและ Operator ชื่อ icon"
10 เพิ่ม"Unplayed อีเมล Voice icon"
11 เพิ่ม"IrDA State icon"
12 เพิ่ม"โทรศัพท์ Profile icon"
13 ไม่มีเสียงหรือการสั่น สะเทือนที่เปิดถ้าข้อมูลปัจจุบันเงียบ
14 เมื่อแบตเตอรี่ชาร์จจุด ปรากฏก่อนร้อยละแบตเตอรี่เพื่อแสดงการชาร์จ
15 หากชื่อผู้ประกอบการสามารถ NA แสดง empty สัญญาณ
16 เปลี่ยนข้อมูลชนิด"ในการ ตั้งค่า icon โต้ตอบจาก dropdown เพื่อ droplist
17 Fonts ในไดเรกทอรีแบบอักษรโดยอัตโนมัติมีการเพิ่มลบ /
18 strExec Load และ strParameters (นอกจาก nScreen, นิคอน, strName และ strImage) จาก HKLM \ Software \ iPhoneToday \ Icon ... \ เมื่อ reloadIcon HKLM \ Software \ \ iPhoneToday ตั้ง
19 เพิ่มข้อความตัวเลือกแยก คุณภาพสำหรับข้อความในไอคอน
20 เพิ่มไอคอนกดใหม่
21 ลดเพิ่มตัวเลือก OnLaunchIcon (คุณต้องแก้ไขด้วยตนเอง settings.xml)
22 เพิ่มตัวเลือก UpdateWhenInactive (คุณต้องแก้ไขด้วยตนเอง settings.xml) เสมอ update แจ้งแม้หน้าต่างไม่ได้ใช้งาน ค่าเริ่มต้นคือ 0 to save แบตเตอรี่
