23 พฤษภาคม 2024, 16:12:12 *
ผู้เขียน หัวข้อ:  Skin diMka 1.1.36 (28-03-2010 1:50am) for IGO8.3x  (อ่าน 10080 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 28 มีนาคม 2010, 02:44:43 »
what new , what fixed
1.1.36 for 8.3.h (8.3.1, 8.3.2, 8.3.4)
   1. Automatically save in the history of the current GPS position with the occurrence of certain events (thanks dima8389):
      - An opportunity to record such events: switch to a pedestrian from anywhere in the program, start the program; exit; disappearance of the signal GPS (short-term jumps signal cut off) to turn off the device from different locations (on-screen buttons to exit the menu, auto power off when you reach the finish line , turning off the external power supply) (including hard-off button, though Autosave position in the history when you turn off hard button will not work on all devices in the test, such as HTC HD does not work);
      - Element name contains the name of history, time, date;
      - Icon element of history is the same as an icon "My POI";
      - For each of the events can turn autosave independently of the other (Menu-Settings-Device-Navigation-Back to the car);
      - Autosave will occur if the item differs significantly from the last saved.
   2. Profiles settings visibility POI (icon, visibility, stopping distance) (Menu-Control-POI-profiles):
      - Save the current settings in the profile visibility;
      - Restore settings visibility of previously saved profiles;
      - The name of the saved profile you can edit in the menu;
      - Profiles can be deleted from the menu.
   3. Rectification with warn beep cameras (incorrect work outside the cabin and states saver), transparency in the cockpit screen buttons minimized dynamic list of POI is changed now as buttons for the right menu.
Skin diMka for 480h234, 320x240, 240x320, 240x400, 400x240, 480x272, 400h234, 416h234, 480x800, 800x480 (only for version 8.3.h (8.3.1, 8.3.2, 8.3.4)).
Current version 1.1.36
Do not forget to say thanks:
dima8389 - author of the original skin di / \ / \ ka.
Andron66 - a huge contribution to the graphics (bmp-files) of the skin.
Important: Work with Driver Alerts and Truck Profiles (8.3.4):
Skin (version 1.1.25.2) is compatible with version 8.3.4 exe.
Two variants of the skin (version 1.1.25.4) with version 8.3.4:
1) use data.zip from version 8.3.2 (nothing in it is not changing) and use the skin (nothing in it is not changing)
Do not forget to sys.txt (unless stated in [project] name):
skin = "ui_igo8"
2) use data.zip from version 8.3.4 (nothing in it without changing) and use the skin (in the skin (inside the zip-archive) rename the folder ui_igo8 on ui_igo8_da).
skin = "ui_igo8_da"
Important: User WVGA-device (480h800, 800x480):
Skin (starting with version 1.1.25) supports two modes of operation:
- 240?400, 400h240
- 480h800, 800x480
In both modes, images of buttons, menu items, and other screen elements are the same (in the high quality display).
In the first version of the skin works with the card size 240?400 (400h240), the second - with a card size 480h800 (800x480), respectively, the second option requires more memory.
So which mode to use the skin, it is necessary to identify yourself.
For devices (480h800, 800x480) to specify the permissions in this section sys.txt enough (nothing more (resolution_dir, screen_x, screen_y) regarding the resolution and screen size, in principle, not necessary):
autoconfig = 1
highres = 1, (1 - mode 240?400, 400h240, 0 - mode 480h800, 800x480).
And, if you do not use the above (deprecated) resolution_dir, screen_x, screen_y, then in each of the modes (240?400-400h240 and 480h800-800x480), portrait-landscape switching is possible from the menu (Settings-Device-orientation of the screen).
Full information about previously made changes to the skin here: skin diMkaWertVRV 1.1.11.8
--- Additional features (continued )------------------------------------------ -------------
13. Advanced Power Management (low and critical battery level, voice reach those levels, the values are set in the skin (in sys.txt not need to write) (animation / flashing battery icon in all states of the program at a critical level of charge, can be turned off). You can select sounds. The volume level is autonomous.
- Four options when disconnecting the external power supply (anything visual message, exit the program, turn off the device);
- Two modes of operation (in traffic, parking) with independent delay (speed of movement starting in the understanding of this regime can be set in the preferences):
  <--Download
birdtsl
คนธรรมดา
ID number: 527
กระทู้: 63
Send Money to birdtsl
-ได้ให้: 117
-ได้รับ: 81
« ตอบ #1 เมื่อ: 28 มีนาคม 2010, 22:45:29 »
มาใหม่อีกแล้ว ต้องขอนำไปทดลองสักนิดนะครับ Grin Grin
bestgps
Exp 10-02-2011
ID number: 3660
กระทู้: 182
$5.00 credits
Send Money to bestgps
-ได้ให้: 145
-ได้รับ: 162
« ตอบ #2 เมื่อ: 31 มีนาคม 2010, 07:48:08 »
น่าจะบอกว่ามีอะไรเพิ่มบ้างจาก version ก่อน ผมอ่านภาษาอังกฤษไม่ค่อยเก่ง แปลผิดแปลถูก เดี่ยวจะไปกันใหญ่
แปลไม่เก่งก็ลองไปทดลองเล่นดูได้นะคะ ...รับรองว่าเครื่องไม่เสียหรอกค่ะ  กระหยิ่ม
« แก้ไขครั้งสุดท้าย: 31 มีนาคม 2010, 18:47:19 โดย tin_43257 » บันทึกการเข้า
tryth
ID number: 2815
กระทู้: 788
$2015.34 credits
Send Money to tryth
-ได้ให้: 1303
-ได้รับ: 9028
« ตอบ #3 เมื่อ: 01 เมษายน 2010, 10:54:40 »
ลองให้กูเกิ้ลช่วยแปลให้ได้ใจความดังนี้
1 บันทึกในประวัติโดยอัตโนมัติของตำแหน่ง GPS ปัจจุบันด้วยเกิดเหตุการณ์บาง
      -- โอกาสที่จะบันทึกเหตุการณ์เช่น : เปลี่ยนไปเดินเท้าจากที่ใดก็ได้ในโปรแกรมเริ่มต้นโปรแกรมนั้นออกจาก; การหายไปของ GPS สัญญาณ (กระโดดระยะสั้นสัญญาณตัด) ปิดเครื่องจากสถานที่ต่างกัน (บนหน้าจอ ปุ่ม เพื่อออกจากเมนูไฟฟ้าอัตโนมัติปิดเมื่อถึงเส้นชัยในการปิดแหล่งจ่ายไฟภายนอก ) (รวมปุ่ม hard - off แต่ตำแหน่งการบันทึกอัตโนมัติในประวัติศาสตร์เมื่อคุณปิดปุ่มยากจะไม่ทำงาน ในอุปกรณ์ทั้งหมดใน ทดสอบเช่น HTC HD ไม่ได้)
      -- ชื่อธาตุมีชื่อของประวัติศาสตร์เวลาวันนั้น
      -- องค์ประกอบ Icon ประวัติเหมือนกับไอคอน"POI ของฉัน";
      -- สำหรับแต่ละกิจกรรมที่สามารถเปิดบันทึกอัตโนมัติอิสระอื่น ๆ (Menu - Settings - Device - Navigation - กลับรถ);
      -- การบันทึกอัตโนมัติจะเกิดขึ้นหากรายการที่แตกต่างอย่างมีนัยสำคัญจากบันทึกล่าสุด
   2 การตั้งค่าโปรไฟล์แสดง POI (icon, การแสดง, หยุดระยะทาง) (Menu - Control - POI รูป) :
      -- บันทึกการตั้งค่าปัจจุบันในการแสดงข้อมูลนั้น
      -- การแสดง Restore การตั้งค่าโปรไฟล์บันทึกไว้ก่อนหน้า;
      -- ชื่อของข้อมูลที่บันทึกไว้คุณสามารถแก้ไขในเมนู;
      -- โปรไฟล์สามารถลบได้จากเมนู
   3 เตือนกล้องเตือน (ทำงานไม่ถูกต้องอยู่นอกห้องโดยสารและประหยัดรัฐ) ความโปร่งใสในปุ่มหน้าจอห้องนักบินลดรายการแบบไดนามิกของ POI เปลี่ยนตอนนี้เป็นปุ่มสำหรับเมนูขวา
ผิดถูกยังไงก็พอเป็นแนวทางที่จะทำความเข้าใจบ้างครับ
Mushi
ID number: 6374
Send Money to Mushi
« ตอบ #4 เมื่อ: 05 เมษายน 2010, 10:56:12 »
ติดตั้งยังไงหรอครับ พอแตกไฟล์ออกมา ผมเอา diMkaWertVRV_1136.zip ไปไว้ที่ skin เท่านี้พอไหมครับ แล้วไฟล์อื่น ๆ ต้องใช้ไหมครับ
« ตอบ #5 เมื่อ: 05 เมษายน 2010, 11:19:23 »
ขออนุญาตตอบแทนคุณ stemcell นะคะ
การติดตั้ง skin หลังจากแตก file แล้ว    Roll Eyes Roll Eyes
1. file diMkaWertVRV_1136.zip  ไปไว้ที่ folder skin โดยที่ถ้าใช้ igo8.3.4.xxx ให้ double click ที่ file แล้วเปลี่ยนชื่อ folder ui_igo8 เป็น ui_igo8_da  แต่ถ้าใช้ igo8.3.2.xxx ก็ไม่ต้องเปลี่ยนอะไรค่ะ   และถ้าไม่ต้องการให้หนักเครื่องมากก็ให้ไปลบหน้าจอความละเอียดอื่นๆ ที่ไม่ใช่ของตนเองใน folder ui_igo8 ออกก่อนค่ะ
2. folder font, mapchanger, Speedcamvoicescripts และ utility (ถ้าในโปรแกรมเดิมไม่มี) ให้ใส่ในโปรแกรม igo
3. folder scheme ให้ดูรายละเอียดด้านใน ถ้าของเดิมมีอยู่แล้วก็ไม่ต้องใส่เพิ่มค่ะ
Mushi
ID number: 6374
Send Money to Mushi
« ตอบ #6 เมื่อ: 05 เมษายน 2010, 23:32:29 »
ขออนุญาตถามอีกคำถามครับ ใช้สกินนี้แล้วในแผนที่ รถหายครับ เป็นแค่จุด ผมทำอะไรผิดหรือเปล่าครับ
ผมใช้ 8.3.4 ครับ
« แก้ไขครั้งสุดท้าย: 06 เมษายน 2010, 00:09:13 โดย Mushi » บันทึกการเข้า
« ตอบ #7 เมื่อ: 06 เมษายน 2010, 00:15:25 »
การ reset เครื่องหลังจากเปลี่ยน skin อาจทำให้การตั้งค่าเดิมเปลี่ยนไป  ลองเข้าไปดูที่การตั้งค่า > หน้าจอแผนที่ > ให้ติ๊กเครื่องหมายถูกที่ Cursor car ค่ะ
pongup
ID number: 7428
Send Money to pongup
-ได้ให้: 20
-ได้รับ: 31
« ตอบ #8 เมื่อ: 17 พฤษภาคม 2010, 09:09:09 »
สกินนี้ เปลี่ยนไอคอนรูปรถยนต์ไม่ได้ มีทางแก้ไขไหมครับ
« ตอบ #9 เมื่อ: 17 พฤษภาคม 2010, 12:23:39 »
ลอง ตัวนี้ซิครับ Version ใหม่กว่าด้วย ตาม link ไปได้เลยครับ
http://www.n...397#msg23397
diMka WertVRV 1.1.34 Skin for igo 8.3.xx (23-02-2010)
₪๐StemCell๐₪ 5 6937 กระทู้ล่าสุด 01 พฤษภาคม 2010, 15:50:59
โดย fairy
Skin diMka 1.1.35 (20-03-2010) for IGO8.3x « 1 2 »
₪๐StemCell๐₪ 21 20957 กระทู้ล่าสุด 11 พฤศจิกายน 2010, 21:39:37
โดย tin_43257
skin for igo8 diMka by WertVRV v 1.1.36_k63_UFO 11/04/2010
tryth 0 3014 กระทู้ล่าสุด 12 เมษายน 2010, 09:31:08
โดย tryth
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.064 วินาที กับ 57 คำสั่ง
