25 เมษายน 2024, 12:50:35 *
ผู้เขียน หัวข้อ: [เครื่องมือ] [Android][Maps] Map Coordinate ใช้ระบุตำแหน่ง GPS บน google maps  (อ่าน 2114 ครั้ง)
#--แกมบิท--#
ID number: 60421
กระทู้: 32
Send Money to #--แกมบิท--#
« เมื่อ: 30 กันยายน 2020, 16:34:43 »
Map Coordinates v4.8.32 (Pro)
ไม่ทราบว่าเพื่อนๆใช้แอฟอะไร สามารถร่วมแบ่งปันกันได้ครับ
ปกติผมใช้แอฟนี้ในการค้นหา ระบุ ตำแหน่งบน google maps เพื่อหาพิกัดมาใช้ในแอฟ GPS ครับ
Map Coordinates / Description
A single tap on the map gives you access to world coordinates. In addition Map Coordinates offers a full set of tools like distance measurement current GPS location history / favorite locations share location find location or copy coordinates / address. You can switch between multiple coordinate types like decimal degrees DMS (degrees minutes and seconds) or even special types like what3words MGRS UTM or GEOREF.
The app is designed to easily determine the coordinates and address of a point on the map and share them with friends via SMS email or social apps.
When you need to find a location you can either type / paste the address / coordinates in a search field or enter each coordinate value one by one in it’s own field using the advanced search options. what3words MGRS UTM or GEOREF can be searched for only by using the single search field.
The current GPS location is best received while the mobile device is located outdoors. The GPS satellites are easy to be found when there is no interference like buildings or clouds. Even if the device is located indoor the location can be accurately found through WiFi network but only if the device is connected to that network.
The side drawer menu is used to navigate between different parts of the app like History / Favorites but it is also used to switch the map provider. The available map providers are Google Maps and Open Street Maps each of them having different map types. Under Open Street Maps there is also a compass available all the time.
Settings can also be accessed from the side navigation drawer. There you have the options to switch between existing coordinates types change the visibility of the address bar or you can enable the Distance measure tool and the Elevation tool. Elevation displays the altitude of the selected location on the map.
Notes:
1. GPX and KML file types are supported with certain limits: Only simple waypoints are processed for GPX files and only Placemarks are processed for KML files.
2. UTM MGRS and GEOREF coordinates types are available as paid options
We hope that this app fulfills your needs but if you have any other expectations please don’t hesitate to contact us and we will try to help you out.
ลิงค์หลัก :
สำรอง :
Amazing
ID number: 51113
กระทู้: 23
Send Money to Amazing
-ได้ให้: 13
-ได้รับ: 30
« ตอบ #1 เมื่อ: 02 ตุลาคม 2020, 07:33:03 »
ใช้แอปนี้ประจำเครื่องเลย แต่ยังเป็น v.1 อยู่เลย
#--แกมบิท--#
ID number: 60421
กระทู้: 32
« ตอบ #2 เมื่อ: 03 ตุลาคม 2020, 21:10:00 »
 Grin
ใช่เลยครับ ผมก็ใช้อยู่เป็นประจำเลย เพราะแต่ก่อนแอฟนำทางมันไม่ค่อยมี POI เลยต้องค้นหาพิกัด แล้วปักหมุดเอง หรือไม่ก็มีแต่ไม่ตรงที่ชื่อถูกแต่ปักผิดที่ เลยเอาชัวร์ล็อคพิกัด ไม่หลงแน่นอน
« แก้ไขครั้งสุดท้าย: 03 ตุลาคม 2020, 21:13:51 โดย #--แกมบิท--# » บันทึกการเข้า
โก๊ะ
ชีวิตต้องเดินทาง
Lifetime Member
ID number: 53346
กระทู้: 168
$17000.00 credits
Send Money to โก๊ะ
-ได้ให้: 121
-ได้รับ: 417
« ตอบ #3 เมื่อ: 05 ตุลาคม 2020, 12:52:53 »
ใช่ครับส่งตำแหน่งพิกัดได้ดีและแม่นยำ แต่อย่าลืมเช็คเส้นทางที่ไปยังพิกัดด้วยนะครับ ซึ่งอาจไปในเส้นทางที่ขรุขระ ถนนลูกรัง บางครั้งเราอาจเข้าใจว่าจีพีเอสพาเราหลงทาง
#--แกมบิท--#
ID number: 60421
กระทู้: 32
« ตอบ #4 เมื่อ: 10 ตุลาคม 2020, 22:14:24 »
ขอบคุณครับสำหรับคำเตือน ปกติมักจะใช้ย่านในเมืองก็ไม่ค่อยจะพาไปผิดเท่าไหร่ครับ แต่ถ้าออกนอกเมืองถ้าตาม GPS ได้ไปทางลัดประจำ ทางแคบบ้าง ถนนดินบ้าง เคยเกือบลงคลองก็มีครับ ต้องถอยไปตั้งหลักใหม่ แมพต่างจังหวัดของไทยเราผมว่าไม่ค่อยจะอัพเดท เท่าที่ควร ขนาดในเมืองใหญ่ๆยังช้าเลย สะพานกว่าจะมานี่เกือบปี บางมียังไม่อัพเลย ต้องปรับไปตามสภาพจริงอีกที เวลาขับ
ใหม่ล่าสุด ROUTE66 Maps 9.1 + All Maps Licenses (2010 Q2 maps) For PDA
Route 66
^SuRaYoOt^ 7 23897 กระทู้ล่าสุด 14 พฤษภาคม 2011, 11:15:38
โดย pytour
Google ออกฟีเจอร์ใหม่บน Google Maps, Street Views และ Google Earth
IT & Gadget News!!
^SuRaYoOt^ 4 5539 กระทู้ล่าสุด 08 มิถุนายน 2012, 08:59:10
อัพเดท Google maps ios กันหรือยังครับ
iPhone, iPad
sajj2517 2 1811 กระทู้ล่าสุด 07 พฤษภาคม 2014, 17:26:00
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.033 วินาที กับ 45 คำสั่ง
