VITO AstroNavigator II - A GPS application that displays a star map of celestial bodies that are currently above you, the card will vary depending on the time and direction of your movement. The program supports the latest GPS receivers with the digital compass and rotates the screen according to your movements, so, star map shows the exact location of the stars above you.
Features:
- Star map VITO AstroNavigator II contains over 9000 stars visible to the naked eye, as well as constellations and planets of the solar system, including the Sun, the Moon;
- Allows you to easily find celestial bodies. You can quickly pick a necessary planet, constellation or star by sliding the list with a finger;
- You can move the finger at the map and look at the star, planet or constellation. Selecting one of the heavenly bodies, you can find additional information by simply clicking on it;
- You can choose what celestial bodies you want to see;
- Images of stars, planets, constellations and grating on the map can be made visible or invisible, depending on what you want to consider;
- The world map shows the stars more accurately according to the chosen location;
- Does not require large amounts of memory.
Launched for Tibo and the emulator.
v2.02 (not able to run GPS)
Download
