อันนี้ที่รัสเซียเค้าทำกันนะครับ ลองดูครับ น่าจะทำให้ใช้กับภาษาไทยได้
Credit : yurat2008I propose an alternative option to install the keypad on the Palestinian Authority (installed without replacing native) than reduces the chances of slain PNA
Tested on 55 holukse
Installation accepted that the card is called SDMMC, if you need something for another in all the script files (extension *. mscr) SDMMC to change your name
1. Go control panel - User (Owner)
Voodim in the field Name: yurat (if this is not done within 14 days keyboard stop working and start asking for money)
Continue for 10 seconds zaganyaem navigator into hibernation (button on / vykll) - to save the registry include and do reset
2. Downloading
Here is. Unpack and throw the root of the card. Should be a folder in Resco her files and another folder
3. Downloading
Here is
and set to navigator in SDMMC / Program fieles Who on the map Program Files should be no pre-create it.
4.
Downloading it. Extract and replace the contents of SDMMC / Program fieles
5. Run SDMMC / Resco / Rkbd.exe (add a shortcut to Startup)
All
Looking..
Also resolved the issue with the Ukrainian layout, automatic loading and registration of alternative klavy
