29 เมษายน 2024, 11:36:50 *
ผู้เขียน หัวข้อ: [เครื่องมือ] แอ๊ปสำหรับวิศกรหรือผู้ที่สนใจด้านเครื่องกล Mechanical Engineering Toolbox  (อ่าน 2264 ครั้ง)
royrover
ID number: 48388
กระทู้: 63
Send Money to royrover
-ได้ให้: 451
-ได้รับ: 272
เครื่อง: Mi9T
โปรแกรม: Street Pilot 2.37
iGO Primo_Israel_9.6.29.483387
« เมื่อ: 14 มีนาคม 2015, 09:44:00 »
http://www.m...oxpronew.apk
Mechanical Engineering Toolbox Pro
This app is for the mechanical engineers, naval architects, civil engineers, HVAC engineers, electrical engineers and for all engineers that use some common unit conversions and math.
It is selected among the Top Ten Productivity Applications for Engineers by the www.engineerjobs.com.
http://www.e...ngineers.htm
For now the program has the following modules:
** Under Mechanical Engineering:
- Unit Conversion in 74 unit types, more than 1000 units
- ISO Fits and Tolerances Calculation according to ISO 286-2
- Hardness Conversion between 22 hardness types according to ASTM E140
- Pipe Sizes
- Dimensional Tolerances according to DIN ISO 2768
- Surface Roughness Tables
- Steel Bolt Specifications
- Bolt Torque Calculator
- Bolt Sizing Calculator
- ISO Metric Thread Dimensions
- Vibration Limits according to ISO 10816 and ISO 7919 and Lloyds Register
- Pressure Vessel Calculation according to ASME Sec. 8
- Ideal Gas Law Calculator
- Reynolds Number in Ducts
- Physical Constants Table
- Pump Power Calculator
- Net Positive Suction Head Calculator
- Material Properties of More than 70 Materials
- Table of Elements
- Steel Cross Reference Table
- SAE/AISI Steel Designations
- Effects of Alloying Elements
- Steel Mechanical Properties
- Steel Search By Composition (For now about 100 most common used steels. To be extended)
- Friction Coefficient Between Materials
- Elastomer Compatibility Table
- Rubber Shrinkage Rates
- Structural Beam Section Properties
- Beam Load Calculator
- Torque-Power Conversion
- Angular and Tangential Velocity
- Bore Shaft Taper Calculator
- Shaft Size Calculator
- Torsion of Circular Shafts Calculator
- Press Fitting of Shafts
- Water Lubricated Bearing Clearance Calculator
- Journal Bearing Clearance Calculator
- Roller Bearing Selection Guide
- Buckling Calculator
- Hydraulic Cylinder Calculator
- Pipe Friction Loss Calculator
- Rigid Rotor Balance Tolerances
- Shaft Key and Keyway Dimensions
- Tap and Drill Charts for Metric, Imperial and Pipe (NPS, NPT) threads
- Flange Dimensions (DIN 2501 and ANSI B16.5)
- UNC - UNF - UNEF Thread Designations
- Surface Roughness Parameters
- Pressure Booster Pump Flow Rate Calculator
- Pressure Booster Pump Pressure Calculator
- Pressure Booster Expansion Tank Capacity Calculator
- Geometric Tolerance Symbols
- O-ring Groove Dimensions
- O-ring Stretch Calculator
- Elastomer Temp. Ranges
- Pipe Diameter - Flow Rate - Velocity Calculator
- Pressure - Area - Force Calculator
- Air Receiver Calculator
- Pulley Diameter-Speed Calculator
- Gear, No. of Teeth and Speed Calculator
** Under Naval Architecture:
- Propeller Shaft Diameter Calculator
- Propeller Material Properties
- Rudder Shaft Diameter Calculator
- Rudder Torque Calculator
- Rudder Area Calculator
- RAL Color Codes
- Ship free Floating Body Motion Definitions
** Under Electrical:
- Electrical Power Calculator
- Galvanic Series
- Wire Gauge Specifications
- Electrical IP and Insulation Classes
- Resistor Color Codes
- DC Voltage, Resistance, Current, Power Calculator
- Series or Parallel Resistor, Conductor, Inductor Calculator
** Under HVAC:
- Air Flow Rate Calculator
- Air Change per Hour Table
- Air Carrying Velocity Table
- Hood Design Calculator
- Engine Room Ventilation Calculator according to EN ISO 8861
- Air Psychrometrics (SI and Imperial) Calculator
- Heat Loss by Conduction Calculator
** Under Mathematics:
- Interpolation
- Extrapolation
- Linear Curve Fitting
- 2 Equations - 2 Unknowns Solver
- Area Formulas
- Volume Formulas
- Greek Symbols
- Inch to mm and mm to Inch Conversion Table
- Number Base Calculator
- Algebraic Formulas - Derivatives - Integrals
- Trigonometric Formulas
Keywords: mechanical, engineering, toolbox, naval, architect, architecture, hvac, electrical, math, mathematics, engineer, calculation, calculator, civil, unit, conversion, converter, ISO, ANSI, DIN, ASME, SAE, standards
home33
ID number: 19993
กระทู้: 83
$1050.00 credits
Send Money to home33
-ได้ให้: 625
-ได้รับ: 83
« ตอบ #1 เมื่อ: 14 มีนาคม 2015, 10:49:02 »
เยี่ยมเลย ผมต้องใช้เป็นประจำอยู่แล้ว ที่นี้ก็รวมในที่เดียวกัน บนเครื่องมือตัวเดียว Grin
Samsung 2443 integrated mechanical and electrical path diagram
ที-เร็กซ์ 1 2667 กระทู้ล่าสุด 02 พฤศจิกายน 2009, 22:36:41
โดย มด [tewbc]
App เด็ดที่ต้องมี กับ All-In-One Toolbox(29 Tools) PRO v2.9 Update v7.2.3.1 « 1 2 3 »
^SuRaYoOt^ 58 60302 กระทู้ล่าสุด 27 มีนาคม 2017, 19:03:52
GPS Status & Toolbox
'EqUiNoX, 3 5416 กระทู้ล่าสุด 06 มกราคม 2015, 21:27:44
โดย 'EqUiNoX,
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.041 วินาที กับ 40 คำสั่ง
