25 เมษายน 2024, 06:02:53 *
ผู้เขียน หัวข้อ:  ใหม่ Map to Sygic V5 ส่งพิกัดจาก Google map to Sygic ง่ายๆ  (อ่าน 27595 ครั้ง)
« เมื่อ: 26 พฤษภาคม 2014, 05:54:01 »
Maps to Sygic v5
Requirements: Android 2.2 and up
Overview: Maps to Sygic lets you open and navigate to Google Maps search results
The Maps to Sygic app combines the power of Google Maps and Sygic's excellent navigation capabilities.
Maps to Sygic lets you open and navigate to Google Maps search results, favorite places*, and other POIs in Sygic navigation software with a single click.
Note: this is not a standalone navigation app, It's a bridge between Google Maps and Sygic. You must have Internet access and the latest Sygic (Aura v12 and higher) installed on your mobile device in order to use this app.
HOW TO USE
1) Tap on any place mark or search result in the Google Maps app and open place details.
2) Select "Share" and tap on "Maps to Sygic".
3) Before navigation, always check if the location is correctly transferred to Sygic. This app relies on Google Maps and locations may not always perfectly match Sygic's.
4) If the location you have selected is not properly transferred, try zooming in as much as you can in Google Maps and then share the location, or try sharing another location near where you want to go.
*FAVORITE (STARRED) LOCATIONS ARE PARTIALLY SUPPORTED. Locations may not be correctly sent to Sygic and may be off by a few meters (or by hundreds)! Please zoom in as far as you can before sharing starred locations. Search results and other POIs work fine.
IMPORTANT: PLEASE READ
- This app requires the latest Sygic (Aura version 12 and higher) and a fairly new version of Google Maps. Not compatible with older Sygic versions.
- Always check to see if the location is correctly transferred to Sygic.
- Accuracy of locations may be off to a certain degree, especially with favorite (starred) items.
- This is beta-quality software, so you can expect some glitches here and there. Error reports and suggestions are always welcome.
REFUND POLICY
- Please uninstall the app within 15 minutes of the initial download in order to receive a full refund automatically.
- Your satisfaction is important to us. Even if you pass the 15-minute time frame, you're still eligible for a full refund. Please see next section for more details.
LIMITED WARRANTY
- If the app doesn't work for you or you're not fully satisfied in any aspect of the program, you can request a full refund within 30 days of your purchase. Please send us an email containing the order number and a brief explanation.
- This app relies on third-party web services by Google. Although it's very unlikely that cloud services will be unavailable and the app will stop working, if it does, you're eligible for a full refund if you have purchased the app within the last 90 days. Please send us an email containing the order number and a brief explanation of the situation.
- This app produces very accurate results; however, we cannot guarantee accuracy for all conversions. You are responsible for checking if the location has been transferred correctly to Sygic. Simply put, do not hit the road without checking the accuracy of the location first.
PERMISSIONS
- Internet Access: Google Maps doesn't provide coordinate information when you share places between applications. In order to save battery and data, the processing required to extract coordinate information is done in the cloud. The place information is sent to the server, and the app then receives the coordinate data. Remember, neither your location nor any other identifying information is ever sent to the cloud! Currently, less than a few kilobytes is required for each conversion.
- Network Status: Required to check if you are connected to the Internet.
TRADEMARKS
Google Maps and Sygic are trademarks of their respective owners. We are not affiliated with either of these companies.
What's New
- New version 5 consists of minor UI tweaks and bug fixes.
- Added support for sharing locations from Maps With Me.
ลิงค์ครับ  Ok
Mirror
« ตอบ #1 เมื่อ: 26 พฤษภาคม 2014, 05:59:47 »
ภาพประกอบครับ ส่ง poi ไป sygic ได้ง่าย ๆ  ร่าเริง
goppa
ID number: 2606
กระทู้: 52
Send Money to goppa
-ได้ให้: 45
-ได้รับ: 79
« ตอบ #2 เมื่อ: 11 กรกฎาคม 2014, 21:52:32 »
มีใครใช้ไม่ได้กับ Sygic 14.5.1 ไม่ได้บ้างครับ หรือ หากใช้ได้ รบกวนสอบถามผู้รู้ด้วยนะครับ
bestgps
Exp 10-02-2011
ID number: 3660
กระทู้: 182
$5.00 credits
Send Money to bestgps
-ได้ให้: 145
-ได้รับ: 162
« ตอบ #3 เมื่อ: 12 กรกฎาคม 2014, 09:44:21 »
ของผมก็ใช่ไม่ได้เหมือนกัน เลยกลับไปใช้ 14.31แทน
Ramload
life time vip1 year vip-member
ID number: 38800
$2400.00 credits
Send Money to Ramload
« ตอบ #4 เมื่อ: 13 กรกฎาคม 2014, 08:06:51 »
เหมือนกันครับ
jrpk
ID number: 6407
Send Money to jrpk
-ได้ให้: 121
-ได้รับ: 25
« ตอบ #5 เมื่อ: 15 กรกฎาคม 2014, 11:05:00 »
ลองใช้กับ Sygic v.14.4.3 ใช้ไม่ได้เช่นกันครับ เครื่อง Zenfone 5 Ram 2 gb    ถอนหายใจ
ต้องรอ Maps to Sygic รุ่นใหม่ใช่มั้ยครับ
sukizilla
ID number: 23181
Send Money to sukizilla
« ตอบ #6 เมื่อ: 07 สิงหาคม 2014, 18:23:01 »
ใช้ไม่ไดเหมือนกันครับ sygic 14.5.2
noktualek
ID number: 46985
กระทู้: 69
Send Money to noktualek
-ได้รับ: 96
« ตอบ #7 เมื่อ: 07 ตุลาคม 2014, 00:38:08 »
ใข้กับ sygic 14.6.1 ได้ครับ
แต่น่าแปลกลองเอา 14.6.1 ค้นหา "แก่งจูงนาง" ไม่เจอ ทั้งๆ ที่มีในแผนที่ว่าเป็นโรงเรียนอยู่
เลยต้องใช้ google maps หาแทนครับ
 Embarrassed
monster_1009
ID number: 16933
Send Money to monster_1009
-ได้ให้: 45
« ตอบ #8 เมื่อ: 07 ตุลาคม 2014, 09:37:06 »
asus fd6 แรม 2 รอม 16 Sygic v13.4.1 ใช้ได้ครับ   Ok Ok Ok
totob11
ID number: 46170
Send Money to totob11
-ได้รับ: 19
« ตอบ #9 เมื่อ: 30 ธันวาคม 2014, 21:01:26 »
ตอนนี้ผมใช้ Map to sygic ไม่ได้ครับมันขึ้นแบบนี้ครับ
Tanudkit
ID number: 46057
Send Money to Tanudkit
« ตอบ #10 เมื่อ: 03 มกราคม 2015, 20:56:06 »
เหมือนกันครับ  ใช้ไม่ได้ด้วย ไม่รู้ว่าเกิดไรขึ้น Huh?
VR2499
ID number: 47050
Send Money to VR2499
« ตอบ #11 เมื่อ: 15 กุมภาพันธ์ 2015, 07:51:02 »
ใช้ไม่ได้เหมือนกันครับ. ท่านใดทำได้ช่วยสอนวิธีทำด้วยนะครับ. Kiss
NiCkAkE
ID number: 30785
กระทู้: 25
Send Money to NiCkAkE
-ได้รับ: 96
« ตอบ #12 เมื่อ: 09 เมษายน 2015, 13:29:18 »
ต้องซื้อเท่านั้นครับถึงจะใช้งานได้
memooffon
ID number: 52464
กระทู้: 27
Send Money to memooffon
-ได้ให้: 25
-ได้รับ: 43
เครื่อง: Samsung GALAXY Note 8.0
โปรแกรม: iGO Primo,
Garmin StreetPilot
Chirawat Sukruang
« ตอบ #13 เมื่อ: 09 เมษายน 2015, 15:31:27 »
ผมเองก็ต้องซื้อครับ ลองตัวcrkมันใช้ไม่ได้
« ตอบ #14 เมื่อ: 09 เมษายน 2015, 15:52:34 »
ใช้ SendtoGPS แทนครับ
โหลดได้ใน google play
henbea
ID number: 54372
Send Money to henbea
« ตอบ #15 เมื่อ: 20 กันยายน 2016, 22:23:41 »
ผมใช้ app ตัวนี้ ผ่านฉลุยเลย ครับ ของผม โทรศัพท์ a9pro sygic 16.1.8  ตอนแรก ก็ลำบากหาเหมือนกัน จะไม่ใช้ก็เสียดาย ภาพมันสวยดี ต้องหาให้ได้
Send To Navigation
ใช้ google map หา poi ให้ Sygic ใช้นำทาง
fortune 4 12635 กระทู้ล่าสุด 19 กรกฎาคม 2013, 09:25:26
โดย chaiyanp
fortune 32 56834 กระทู้ล่าสุด 11 มกราคม 2018, 12:07:09
โดย cmdsk
Go With Sygic ตัวช่วยส่ง poi จาก Google Maps ให้ Sygic อีกหนึ่งตัวเลือก
PhoenixCNX 2 3687 กระทู้ล่าสุด 28 มกราคม 2016, 23:47:26
โดย somrom
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.13 วินาที กับ 80 คำสั่ง
