24 เมษายน 2024, 19:21:48 *
ผู้เขียน หัวข้อ: Android iGO Primo Data.zip 1920x1080  (อ่าน 48530 ครั้ง)
« เมื่อ: 29 กรกฎาคม 2013, 21:52:32 »
iGO Primo Data.zip 1920x1080 (Samsung S4) หรืออื่น ๆ ที่ใช้หน้าจอขนาดนี้ครับ.
sys.txt
[device]
type="android"
[tmc]
;source="gnse"
;internal_tmc_name="gnse"
;port="/dev/gnstmc,0"
[modules]
;ITMC_STATION_SELECTOR="TMC_STATION_SELECTOR_NULL"
;IFM_STATION_CACHE="DUMMY_TMC_STATION_CACHE"
[gps]
location_net=1
location_gps=1
accuracy_workaround=1
background_navigation=1
driver=engine
;driver=gles
;Automatic mode should work (now also on ICS & JB), but if you want to specify exact values, you can comment next line and uncoment one from next lines.
;If you want to run iGO with automatic resolution detection in fullscreen mode, have a look to "fulscreen" parameter in [android] section...
screen_xy="auto"
;If you want to run iGO in specific resolution, you can enter exact values istead "auto".
;Have a look to next lines for examples. For more examples have a look to readme.txt
;screen_xy="1280_800:1196x670/720x1134" ;for HTC One X
;screen_xy="1920_1080:1920x1080/1080x1920:fullscreen" ;for Samsung S4
[3d]
usepolyfarroads=0
[folders]
linked_root_list="/sdcard2/iGO /sdcard/iGO /sdcard/sd/iGO /sdcard/external_sd/iGO /mnt/sdcard/iGO /mnt/sd/iGO /mnt/iGO /storage/iGO /mnt/sdcard/sd/iGO /mnt/sdcard/external_sd/iGO /mnt/exsdcard/iGO /mnt/sdcard/extStorages/SdCard/iGO /ext_card/iGO /mnt/ext_card/iGO /mnt/extSdCard /mnt/ext_sd"
;has_secondary_root=0
;secondary_app="android_linked_root"
;user_backup_path="android_linked_root"
;If you want to have content in other folder as default you can uncoment & edit next line.
;content="android_linked_root/content"
;If you want to have some content in other folder as default, you can uncoment & edit some next line(s).
;Note: If you want to use relative path, current folder is content/
;buildings="building"
;dem="dem"
;maps="map"
;poi="poi"
;phoneme="phoneme"
;raster="raster"
;tmc="tmc"
[network]
available=1
[tmc-http]
#If you want to use Google Local Search, you also must to enable tmc-http!
enabled=1
start=1
servers.size=1
servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
;dt_dl_0=60.0
[naviextras]
;boot_service_address="http://zippy.naviextras.com/services/index/rest/2/boot"
[other]
demo_enabled=0
[debug]
skip_eula=1
imei=000000000000000
;experimental_features=1
screenshotsavecameraini=0
;Path to save screenshot must exist!!!
screenshotfilename="android_linked_root/debug/img_%02d.jpg"
;show_battery_percent=1
[android]
;If you want run iGO in fullscreen mode and you have screen_xy="auto", you can uncoment next line.
;On rooted ICS tablets you must use also some utility to hide bottom bar. On non-rooted ICS tablets no way to hide bottom bar.
;fullscreen=1
;bt_sco_on=1
;bt_a2dp_on=1
;upside_down_bug=1
;fourway_orientable_device=1
;logcat_file_delay=50
;logcat_file = "/mnt/sdcard/iGO/debug/logcat.log"
;logcat_level = 7
;logcat_oslevel = 7
[sound]
csv_voice_enabled=1
;android_muting_device=1
;disable_volume_changed_action=1
;dev_channels=2
[feature]
back_button=1
;If you want to use skin ported from WindowsCE, you probably need to uncoment next line, default value is ui_android.
;skin="ui_igo9"
extra_settings=1
capture_to_jpeg=1
;show_minimize=1
save_checksum=0
;external_poi_path="android_linked_root/content/userdata/poi"
;show_tmc_eventlist=1
[route]
[poi]
;If you don't want Google Local Search (GLS), uncomment next line to replace GLS button with Search on the map button on Search screen
;featured_provider=0
;                                     S P E E D C A M - C A T : 0
[speedcam_category:0]
activated_spoken_type=speech
activated_speech="Speed Camera"
approach_beep_distances=550
approach_beep_speech="Speed Camera"
overspeed_spoken_type=speech
overspeed_speech="Over Speed"
overspeed_min_speech_repeat_delay=60
skin_off_sound="speedcam_off"
min_frc=-1
use_road_speedlimit=1
;                                     S P E E D C A M - C A T : 1
[speedcam_category:1]
activated_speech="Mobile Speed Camera"
approach_beep_speech="Mobile Speed Camera"
min_frc=-1
;                                     S P E E D C A M - C A T : 2
[speedcam_category:2]
activated_speech="Built-in Speed Camer"
approach_beep_speech="Built-in Speed Camer"
min_frc=5
;                                     S P E E D C A M - C A T : 3
[speedcam_category:3]
activated_speech="Average Speed Camera"
approach_beep_distances=150
approach_beep_speech="Average Speed Camera"
section_beep_distance=250
section_beep_spoken_type=speech
section_beep_speech="Average Speed Camera"
min_frc=-1
;                                     S P E E D C A M - C A T : 4
[speedcam_category:4]
activated_speech="Red Light Camera"
approach_beep_speech="Red Light Camera"
min_frc=5
;                                     S P E E D C A M - C A T : 5
[speedcam_category:5]
activated_speech="Strelka Camera"
approach_beep_speech="Strelka Camera"
min_frc=5
;                                     S P E E D C A M - C A T : 6
[speedcam_category:6]
activated_speech="Railroad Crossing"
approach_beep_speech="Railroad Crossing"
min_frc=5
use_road_speedlimit=0
;                                     S P E E D C A M - C A T : 7
[speedcam_category:7]
activated_speech="Bus Lane Camera"
approach_beep_speech="Bus Lane Camera"
min_frc=-1
;                                     S P E E D C A M - C A T : 8
[speedcam_category:8]
activated_speech="High Accident Zone"
approach_beep_speech="High Accident Zone"
min_frc=-1
;                                     S P E E D C A M - C A T : 9
[speedcam_category:9]
speedcam_snap_distance=50
activated_speech="School Zone"
approach_beep_speech="School Zone"
overspeed_spoken_type=none
min_frc=5
;                                     S P E E D C A M - C A T : 10
[speedcam_category:10]
activated_speech="Town Entry Point"
approach_beep_speech="Town Entry Point"
min_frc=-1
;                                     S P E E D C A M - C A T : 11
[speedcam_category:11]
activated_speech="Red Light and Speed Camera"
approach_beep_speech="Red Light and Speed Camera"
min_frc=5
;                                     S P E E D C A M - C A T : 12
[speedcam_category:12]
activated_speech="Toll Booth"
approach_beep_speech="Toll Booth"
overspeed_min_speech_repeat_delay=25
min_frc=-1
;                                     S P E E D C A M - C A T : 13
[speedcam_category:13]
activated_speech="Hospital, Ambulance"
approach_beep_speech="Hospital, Ambulance"
min_frc=5
;                                     S P E E D C A M - C A T : 14
[speedcam_category:14]
activated_speech="Fire station"
approach_beep_speech="Fire station"
min_frc=5
;                                     S P E E D C A M - C A T : 15
[speedcam_category:15]
activated_speech="Congestion Charge Zone"
approach_beep_speech="Congestion Charge Zone"
min_frc=5
;                                     S P E E D C A M - C A T : 16
[speedcam_category:16]
activated_speech="Give Way"
approach_beep_speech="Give Way"
min_frc=5
;                                     S P E E D C A M - C A T : 17
[speedcam_category:17]
activated_speech="Fixed Mobile Camera"
approach_beep_speech="Fixed Mobile Camera"
min_frc=5
;                                     S P E E D C A M - C A T : 18
[speedcam_category:18]
activated_speech="Speed Breaker"
approach_beep_speech="Speed Breaker"
min_frc=5
;                                     S P E E D C A M - C A T : 19
[speedcam_category:19]
activated_speech="Children"
approach_beep_speech="Children"
min_frc=5
;                                     S P E E D C A M - C A T : 20
[speedcam_category:20]
activated_speech="Dangerous Turn"
approach_beep_speech="Dangerous Turn"
min_frc=5
;                                    S P E E D C A M - C A T : 21
[speedcam_category:21]
activated_speech="Tunnel"
approach_beep_speech="Tunnel"
min_frc=5
;                                     S P E E D C A M - C A T : 22
[speedcam_category:22]
activated_speech="POI"
approach_beep_speech="POI"
min_frc=5
;                                     S P E E D C A M - C A T : 23
[speedcam_category:23]
activated_speech="RPS Post"
approach_beep_speech="RPS Post"
min_frc=5
min_frc=-1
;                                     S P E E D C A M - C A T : 24
[speedcam_category:24]
approach_beep_sound=!proxi
min_frc=-1
;                                     S P E E D C A M - C A T : 25
[speedcam_category:25]
min_frc=-1
;                                     S P E E D C A M - C A T : 26
[speedcam_category:26]
min_frc=-1
;                                     S P E E D C A M - C A T : 27
[speedcam_category:27]
min_frc=-1
;                                     S P E E D C A M - C A T : 28
[speedcam_category:28]
min_frc=-1
;                                     S P E E D C A M - C A T : 29
[speedcam_category:29]
min_frc=-1
;                                     S P E E D C A M - C A T : 30
[speedcam_category:30]
min_frc=-1
;                                     S P E E D C A M - C A T : 31
[speedcam_category:31]
activated_speech="Dangerous Area"
approach_beep_speech="Dangerous Area"
min_frc=-1
[tts]
ttspro_da_voice_enabled=1       ;
automatic_direction_conversion=1
announce_exit_directions=1
always_say_road_names=3
tts_logics=6
skip_road_numbers=1
skip_exit_numbers=2
use_tts_lang=1
announce_street_name=1
accusative_case=0
tts_buffer=32768
tts_gc_size=524288
[tmc-http]
enabled=1
start=1
servers.size=1
;dt_dl_0=60.0
[voice]
correct_speed_unit=1;
announce_speed_unit=1;
[warning]
speedcam_max_lookahead=1000
speedcam_maxdistance_from_road=25
speedcam_enabled=1
speedcam_warning=1
is_spoken=1
warn_distances="130:1000,90:690,70:690,50:690,30:540"
speedcam_continuous_approach_beep_when_tonal=0
download link :
 สำนึกผิด
big-man6644
ID number: 268
Send Money to big-man6644
« ตอบ #1 เมื่อ: 14 กันยายน 2013, 21:13:07 »
ผมอยากทราบวิธีลง igo บน samsung s4 ครับ ผมมือใหม่มา
ชี้เป้าลิ้งค์ให้หน่อยครับ
« ตอบ #2 เมื่อ: 16 กันยายน 2013, 09:51:47 »
ใช้ตัวใหม่ครับ ตามหน้าแรกเลยครับ http://www.n...opic=13095.0
hopperman
ID number: 41313
Send Money to hopperman
« ตอบ #3 เมื่อ: 24 มีนาคม 2014, 18:14:57 »
 ::)เยี่ยมครับ สุดยอดเลยครับ  ขอบคุณครับ
 อยากขอบคุณ กดปุ่ม Thanks สีเขียวก็พอครับ แล้วอ่านกฎกติกาด่วน
earth1819
ID number: 9540
Send Money to earth1819
-ได้ให้: 49
« ตอบ #4 เมื่อ: 17 มิถุนายน 2014, 05:59:24 »
ลองแล้วokเลยใช้กับiq octo ขอบคุณคับ
« แก้ไขครั้งสุดท้าย: 17 มิถุนายน 2014, 16:09:58 โดย earth1819 » บันทึกการเข้า
aonzvoey
ID number: 48628
กระทู้: 27
Send Money to aonzvoey
« ตอบ #5 เมื่อ: 02 กรกฎาคม 2014, 20:59:36 »
ใช้ได้แล้วครับ ขอให้บุญกุศลนี้ นำพาให้ท่านพบแต่สิ่งดีๆ นะครับ เก็กหล่อ
data.zip สำหรับ Primo 2.4 + เสียงเตือน « 1 2 3 »
iGO Man 49 49149 กระทู้ล่าสุด 19 สิงหาคม 2014, 17:00:04
โดย weera302514
keyboard ไทย ขนาด 1920x1080 ต้องทำไง
hanumarn 1 3669 กระทู้ล่าสุด 04 มีนาคม 2014, 20:28:57
โดย fortune
bRanding pRimo 2.4 1920x1080-sUpersize for POI Q1-2016-Here Only
[-HYAKAR-] 2 2845 กระทู้ล่าสุด 27 กุมภาพันธ์ 2017, 11:37:20
โดย panlopnok
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.103 วินาที กับ 52 คำสั่ง
