1. Added switch for interactive traffic information (tmc-http) receive data via Wi-Fi.
2. Slightly modified screen visibility settings POI (available Visibility of "Selected" + manual input method visibility distance).
3. In the screen display multirascheta CO2 replaced by displaying fuel cost (if the price is not filled in the profile of the vehicle, it will display the number of fuel).
4. Change icons pointers circular motion from Andron66.
5. Kml-selection of objects in multiprovaydernyh POI search screen. Activation via sys.txt (off by default):
[Poi]
kml_as_logical_provider = 1
6. Multi-search in one line (another of the innovations of 2.4):
- The inclusion of the search button in the main search menu, right menu in the cockpit, a standard quick menu;
- By default the search is near the current location (or in the selected city);
- Search is made in the following categories:
1) "What's POI". To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "poi".
2) "Group POI". To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "poi_container".
3) "KML-objects POI". To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "kmlpoi".
4) "My objects POI" (user-created objects POI, including favorites). To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "favourites".
5) "History." To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "history". If the category is active, the settings you can enable / disable it.
6) "The Streets." To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "street".
A space can be defined number, ie search bar type "Nov 5" will produce results "Novikova 5," "New 51", etc.
7) "Places." To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "location". This category will be disabled when the category "Streets."
"Local Search" (Google). To activate this option category search_priority (sys.txt, section [address.multi]) must contain the substring "gls".
If a specific category is activated, the settings you can enable / disable it.
Important: if the category of "Local Search" (Google) is not activated (not in search_priority "gls"), then there is a possibility to leave the manual search for this category (the icon that says "g"). Since such a search is mandatory, then to run it is necessary to press the manual search.
When inactive category click on the button in the settings will give the appropriate help (why it is inactive and what to do).
To activate all categories search_priority option would be:
search_priority = "history; favourites; street; location; poi_container; kmlpoi; poi; gls"
By default, this parameter is 2.4 as follows:
search_priority = "favourites; history; street; junction; poi; poi_container"
- Change the search area. If full-time option search_priority (sys.txt, section [address.multi]) contains the string location (ie multi-search communities by default does not), it can be quickly modified by entering key native character of the country and the city on the keyboard (such as the EC or PO EC for Ekaterinburg, Russia), if not contain, then there is a separate screen for entering the country and the city.
In screen rapid change (one line) search area first 5 entries will be accompanied by withdrawal of the screen prompts. In the future, you can call the help screen by pressing the "I".
- Selection by category in the search screen in the list. When choosing the selection of the category "What's POI" - the transition to the screen with the selection by providers POI (in the list of providers kml absent, as "KML-objects POI" is a separate category of multi-search).
- Sort by distance / on the name of items in the list;
- To list items, multi-search you can view on the map or route (as well as other lists).
- To start the multi-search does not prevent entry of key characters on the keyboard can adjust the delay start multi-search you enter keywords.
- Regular keys control the multi-search (those for which it is necessary to pay attention):
[Address.multi]
allow_empty_categories = 1, (1 - a search screen display of all active and included the categories 0 - display in the search screen only those categories that have the search results.
search_priority = "history; favourites; street; location; poi_container; kmlpoi; poi; gls"; (activation of categories and search priority in their respective categories).
