24 เมษายน 2024, 16:36:59 *
หน้า: 1 [2] 3   ลงล่าง
ผู้เขียน หัวข้อ:  สุดยอด Launcher บน Android มาแล้วกับ TSF Shell v1.2.0 Update v3.8.9  (อ่าน 47858 ครั้ง)
« เมื่อ: 07 มีนาคม 2012, 04:57:11 »
TSF Shell v1.2.0
Requirements: 2.2 or higher
Operating System: Android
Overview: TSF Shell 3D is an interface with brand new operating system
Enable you to freely personalize various widgets to a full range. Let’s say goodbye to the traditional operation system.
Features:
Enable you to do multipul-operation, including auto-arragement, multipul-choices, add-to-folder, multipul-deleting, to the items by only one move of the finger. You can also check your folders in various ways.
TSF SHELL 3D has one app page and 4 personalized pages for our users. You can switch between pages by one click at the switch button in the lower left corner.
You can freely create one or more quicklinks for apps and drag them to any page. You can also distribute all the app icon (or even change their angles) freely in the personalized page.
The side column provides the most TSF Shell 3D charateristic widgets, including folders, contacts, music player, weather and so on.
The side column can be personalized as well, including changing the order and position of different catagories. You can create quicklinks of your most frequently used apps and contact in the quick launch in the side column.
TSF Shell 3D has a most powerful theme function. Apart from the difference in style, some themes even allow change in the transition animation.
Tips:
1. The folder where the application is less than 7, only to circle the icon into the folder.
2. The folder where the application is more than 7, only to drag the icon ftom the folder.
Currently we are still trying to improve our TSF Shell 3D. We will update our product and new widgets regularly. Please check for updates so that you can the best experience.
We also welcome any comments or suggestions for improvement of our product.
What's in this version:
(v1.2.0)
Improve the speed of TSF Shell and fixed some bugs.
https://mark...om.tsf.shell
ลิงค์ครับ  Smiley
very thank Blackcrowned  สำนึกผิด
ID number: 132
« ตอบ #21 เมื่อ: 15 กรกฎาคม 2013, 22:31:07 »
หาได้ไหมครับ
« ตอบ #22 เมื่อ: 16 กรกฎาคม 2013, 05:07:38 »
หาได้ไหมครับ
โทษทีลืมไปเลย มีครับเดี๋ยวอัพให้ครับ
« ตอบ #23 เมื่อ: 16 กรกฎาคม 2013, 05:24:02 »
Update TSF Shell v1.9.9.5.4
Whats new
Version 1.9.9.5.4
1.Fixed crash problem.
« ตอบ #24 เมื่อ: 07 สิงหาคม 2013, 08:38:04 »
มี Update อีกแล้ว Grin
TSF Shell v1.9.9.6 Patched
What's New  Version 1.9.9.6 (Aug.6,2013)
1.TSF Arch Shortcut Menu
 2.Themes Mix V1.0 ( Batch Icon Change, compatible with all icon packages on Google Play )
 3.New multiple selection
 4.More pendant widgets
 5.More icon menu option
 6.New icon picker interface and operation mode
 7.Memory usage reduced
 8.Known bugs fixed
ลิงค์ครับ  Smiley
ID number: 132
« ตอบ #25 เมื่อ: 07 สิงหาคม 2013, 08:54:45 »
ขอบคุณคุณ surayoot มากๆ ที่ update apps ที่ดีและจำเป็นให้บ่อยๅ
« ตอบ #26 เมื่อ: 01 กันยายน 2013, 20:03:38 »
Update TSF Shell v1.9.9.7
•Theme Mix (Support all theme material)
•Widget Preview (Widget selector with widget preview for devices with Android 4.1+)
•Extra Desktops Quantity(The minimum quantity of the extra desktops was changed to one)
•Repaired problems that some devices runs TSF Shell not smoothly
•Repaired problems that the wallpaper can not be centered or become all black in some devices
•Optimized the starting speed
•Optimized some operational processes
•Known bugs fixed
ลิงค์ครับ  Smiley
« ตอบ #27 เมื่อ: 12 กันยายน 2013, 04:40:45 »
Update TSF Shell v1.9.9.7.3
What's in this version: (Updated : Sep 11, 2013)
•Fixed startup crashing on some devices.
•Version 1.9.9.7.2 (Set.11,2013)
•Transparent Notification Bar (This will only work if your system software/ROM supports it )
•Fixed crash issue with Themes Mix
•Fixed failed Icon Theme setting after applying themes
•Fixed other known bugs
ลิงค์ครับ  Smiley
« ตอบ #28 เมื่อ: 18 กันยายน 2013, 06:09:40 »
Update TSF Shell v1.9.9.7.4
•Multiple backups support
•Known bugs fixed
ลิงค์ครับ  ร่าเริง
« ตอบ #29 เมื่อ: 25 กันยายน 2013, 06:14:36 »
Update TSF Shell v1.9.9.7.5
•XXHDPI ICON / Theme support
•Known bugs fixed
ลิงค์ครับ  เก็กหล่อ
« ตอบ #30 เมื่อ: 13 ธันวาคม 2013, 04:44:30 »
มาอัพเดทกันครับ ห่างไปนานเลย
TSF Shell v2.0
What's in this version: (Updated : Dec 12, 2013)
•3D Cube clock widget added
•3D Calendar widget added
•Brand-new effective interface for desktop element adding
•Brand-new special effect interface (including desktop transition/clicking/swing/scene switching etc)
•20 amazing desktop transition effects added
•Added TSF Shell shortcut (including Apps Drawer "Open" button and more)
•New theme settings interface
•Theme Mixer supports more theme elements
•Two excellent free TSF Shell themes added
•Video Demo:http://youtu.be/vemTo705Vig
ลิงค์ครับ  อาบน้ำอุ่น ๆ
« ตอบ #31 เมื่อ: 17 ธันวาคม 2013, 21:03:46 »
Update TSF Shell v2.0.1
•Known bugs fixed.
ลิงค์ครับ  Ok
« ตอบ #32 เมื่อ: 25 ธันวาคม 2013, 15:31:33 »
Update TSF Shell v2.0.2 Patched
What's New
1.Recommend a nice free theme for Christmas
 2.Fixed the issue of wallpaper not being full screen
 3. Fixed the constant restart issue of TSF Shell on some devices
 4.Known bugs fixed
ลิงค์ครับ  เก็กหล่อ
« ตอบ #33 เมื่อ: 30 ธันวาคม 2013, 04:36:35 »
Update TSF Shell v2.0.3
What's New
1.Support transparent navigation bar on Android Kitkat 4.4 or above
 2.System persistent option
 3.Fixed the constant restart issue of TSF Shell on some devices
 4.Grid Arrangement tool bug fixed
 4.Known bugs fixed
ลิงค์ครับ  เก็กหล่อ
« ตอบ #34 เมื่อ: 01 มกราคม 2014, 04:58:06 »
Update TSF Shell v2.0.4
What's New:
5.Known bugs fixed
ลิงค์ครับ  เก็กหล่อ
« ตอบ #35 เมื่อ: 10 มกราคม 2014, 16:42:01 »
Update TSF Shell v2.0.5
What's New
1.Automatically clean up idle memory to improve launcher performance.
 2.Fixed the overlapping issue of the Navigation Bar and the Dock Bar.
 3.Fixed the non-selectable issue of system widgets on some devices.
 4.Fixed the restoring issue of the system widgets after restarting on some devices.
 5.Fixed most of the TSF Shell crashing issue.
 6.Fixed other known bugs.
« ตอบ #36 เมื่อ: 13 มกราคม 2014, 07:17:25 »
Update TSF Shell v2.0.6
What's New
V2.0.6
 1.Fixed the constant restart issue of TSF Shell in Version 2.0.5
ลิงค์ครับ  เก็กหล่อ
« ตอบ #37 เมื่อ: 21 มกราคม 2014, 14:37:52 »
Update TSF Shell 3D Launcher v2.0.7
What's New
1.Added the transition effect settings for entering/exiting from the App Drawer
 2.Activities shortcut - Select hidden activities from your favorite apps
 3.Fixed arrangement error after uninstalling app in the App Drawer
 4.Fixed icon / folder / widget disappearing issue on some devices
 5.Fixed other known bugs
ลิงค์ครับ  เก็กหล่อ
« ตอบ #38 เมื่อ: 27 ธันวาคม 2014, 06:31:17 »
Update TSF Shell 3D Launcher v3.0
What’s New in v3.0 Apk
Activities shortcut, Select hidden activities from your favorite apps
Fixed arrangement error after uninstalling app in App drawer
Fixed icon, folder, widget disappearing issue on some devices
ลิงค์ครับ  Ok
http://cs539...7iq&dl=1
« ตอบ #39 เมื่อ: 28 ธันวาคม 2014, 05:20:43 »
Update TSF Shell 3D Launcher v3.1.1
What's New
V3.1.1 (2014/12/27)
Fixed crash bugs
V3.1 (2014/12/26)
Everything Has Changed
ลิงค์ครับ  Ok
« ตอบ #40 เมื่อ: 29 ธันวาคม 2014, 05:52:07 »
Update TSF Shell 3D Launcher v3.1.2
What's New
Fixed crash bugs
ลิงค์ครับ  Ok
หน้า: 1 [2] 3   ขึ้นบน
Regina 3D Launcher v0.9.64 Update Pro v1.2.0
^SuRaYoOt^ 7 8428 กระทู้ล่าสุด 14 มกราคม 2012, 02:53:04
MXHome Launcher Update 3.1.5 v3.1.7
^SuRaYoOt^ 5 6229 กระทู้ล่าสุด 11 พฤศจิกายน 2013, 07:04:16
Next Launcher 3D Launcher ตัวงามที่คุณต้องลอง (Update Version 1.15 19/01/2013)
ArtAoey 13 10623 กระทู้ล่าสุด 26 เมษายน 2013, 18:57:48
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.597 วินาที กับ 60 คำสั่ง
