Nav N Go iGO8 v8.3.2.97313 (jul3 2009):windows mobile 6.5, this will run on all (240_240, 240_320, 240_400, 320_240, 320_320, 400_234, 400_240, 480_234, 480_272, 480_640, 480_800, 800_480 resolutions:
PICTURES IN POST TWO FOR PROOF WVGA HTC HD2 800x480
this download includes a complete prefigured setup to get IGO8 fully working on the htc hd2, by this i mean fully working in full wvga 800x480 or 480x800, all gfx tweaks are maxed for best possible image quality. it is fully tested by me and fully 100% working, on the htc hd2 it takes less than 5seconds to boot up the application and another 1~3seconds indoors to connect, ITS REALLY THAT QUICK!!
ive uploaded two versions, 1) fully prefigured english uk, (incl full uk map + full uk speed camera + full uk poi + 5 uk voices + full uk lang + full 3d building)
installation :- just downloaded zip file and extract the content to ur pc, copy both "iGO8" + "2577" folders to the ROOT folder of ur SD card, once complete an autorun app will popup asking to install IGO8, just accept all and it will install as needed, NOW UR READY TO RUN.....;), no messing with sys files or anything like this, to change portrait / landscape just change it in the settings menu and restart the app
2) fully prefigured application (needs map + speed camera + poi + voices + lang + 3d building)
installation :- just extract the downloaded zip file, extract the content to ur pc, add the maps,voices,poi's,3dbuildings,langs and speed cameras of ur liking to the content folder in IGO8 folder, then copy both "iGO8" + "2577" folders to the ROOT folder of ur SD card, once complete an autorun app will popup asking to install IGO8, just accept all and it will install as needed, NOW UR READY TO RUN.....;) no messing with sys files or anything like this, to change portrait / landscape just change it in the settings menu and restart the app
http://www.navngo.com/pages/global/eng/igo_8_description
to download click the version u require below, both include sys.txt prefigured for htc hd2 so if u plan to run on another device other than this please create ur own sys file or request and ill make you one, then follow install guide listed above depending on which i chose:
download 1 FULLY complete includes everything needed for ukhttp://rapid...ul3.zip.htmldownload 2 includes app basics, needs (map+speed camera+poi+voices+lang+3d building) http://rapid...sic.zip.htmlCredit : DAMIEN666
