04 มิถุนายน 2024, 09:29:55 *
ผู้เขียน หัวข้อ:  วิธีการสร้าง 3D Car สำหรับ iGO, AmiGo (in development)  (อ่าน 3754 ครั้ง)
-ได้รับ: 72137
« เมื่อ: 26 กันยายน 2009, 04:42:26 »
Methods of conversion and a collection of models
หา 3D Car ต้นแบบได้จากที่นี่
Click here
อันนี้เป็นวิธี Convert เป็น .obj หรือ .3ds แปลจากภาษารัสเซียนะครับ อาจอ่ายยากนิด
thexhsmk2
Constantine Predachenko Konvertatsiya modeley SKP in 3DS format
437 days ago  Quote Report spam
Probably everyone who works in Google ScetchUp had to deal with as a problem.
I have laid out their decisions.
There are several ways to solve the problem, each with its own advantages and disadvantages.
1. The first method is exporting models in the format KMZ (Google Earth). Here we must be careful - KMZ exists in two formats. First - Google Erath 4, second - Google Earth. That second to us and need. Filed. Now you need to install the free 3D Editor - Blender. specifically required version 2.42a (242.3). There, in the File menu, there are paragraphs Import. Open your kmz file and save in 3ds.
2. Second sposb also begins with the format KMZ. Then rename the file in ZIP and rozarhiviruem. We are looking for a file with DAE. Then put the FBX converter. Then convert the DAE file into FBX and then FBX to 3DS.
3. The third method is the simplest. Looking for Google ScetchUp Pro. To Register (patches, produces serial or honestly pay money - your choice). There, in the menu file is Eksport in 3ds.
Now about the advantages and disadvantages.
The first method requires only free software. This is the first plus. Secondly - the model has a minimum of parts (components, nets, meshes - who both like). Is present some smoothing of sharp corners - about 20 degrees.
Less for the first - forget about the texture, not always korektno converts model - some of the polygons are lost, sometimes the material does not meet the desired polygon. Also, for some reason older versions Blendera not understand KMZ (Although a married right script and the search ...)
The second way I have not worked. FBX file is sometimes empty.
The third way is the easiest. The model is converted without loss. There are several options save (affect the hierarchy of parts and others). Also get texture (there are note - if you have several models with similar materials to keep them in different folders else new texture is often overwrites the old - or materials rename.)
Less for a third way - a lot of components. The overall angularity of the model. And in my opinion - the high cost Pro version porgramy ...
But 3 running at 100% - I use them.
Now, where to look --
Google ScetchUp -- http://www.g...p/downloads/ This is your choice, and Axle language
Google ScethUp Pro -- http://www.g...ad/gsup.htmlА general registration form then fill
FBX converter - http://usa.a...index?siteID =... Here converter, plug-ins, SDK ...
Blender - http://downl...ender2.46/bl...
Well this is the official version. If necessary, find old - looking in search engines. Good luck!
Cool screensavers and simple 3D graphics here
http://thexh.../image/index
Truth or revealed to us in very simple words, or not open at all.
Метки: Graphics
Google Sketchup Pro v7.0.10247
สุดท้ายใช้โปรแกรมชื่อ 3D Converter v4.404 แปลงเป็น iGO8 3D อีกครั้ง.
 Tongue  Cool
AMIGO พาหลงทางครับ « 1 2 »
iGO Discussion
teen2000 26 18345 กระทู้ล่าสุด 08 พฤศจิกายน 2009, 19:29:08
โดย amtep
ใส่ poi ใน Amigo ยังไง?
iGO Discussion
Gabriel_One 3 5810 กระทู้ล่าสุด 22 กันยายน 2009, 21:54:45
ที-เร็กซ์ 1 7227 กระทู้ล่าสุด 30 มีนาคม 2010, 22:08:35
โดย ₪๐StemCell๐₪
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.049 วินาที กับ 39 คำสั่ง
