18 พฤษภาคม 2024, 16:54:34 *
ผู้เขียน หัวข้อ:  Skin DIMKA - TOMSOFT (pro PRIMO 1.2) Version 1.3.2 (b) [14 05 2011]  (อ่าน 4659 ครั้ง)
coUp..uP
ID number: 27695
« เมื่อ: 12 พฤษภาคม 2011, 12:53:59 »
Dimka - TomSoft (for direct 1.2)
Dimka - TomSoft (for 800x480, 480x272, 480x234, 320x240)
Update 14-05-2011
Dimka - TomSoft 1.3.2 (b)
- TMC repair / SplitScreen button.
- Adaptation of TTS
- Add a choice of action "Current street" - Dialogue "Where am I" or "Report of the TTS crew arrives"
Add a choice of actions to "actual street is the old function, but that there has been until now, respectively. I threw it out because it was in the original
set to LongClick on maneuvers, and there we have a PB or delete routes. So I went back this feature, but click on the current street.
But I'm really improved the ability to set what will be the reaction to the short handles on the street. In settings as seen in the picture, you can choose to click on the short
"Where am I" or "Report path destination. For it was not so easy, so long also automatically handles the street:)
eg
If I set in the "Report goal line" and a short handle on the actual street, TTS voice tells how far the objectives and long click will activate the dialogue, "Where am I".
If I set in the "Where Am I" (ie as before), so long, just click the "Report path destination, so for any of these two functions is lost.
LANG E - should be updated.
Dictioany.voice - should be updated. (Section Languages​​)
Mirror Download 1.3.2(b)
Current Version 1.3.2 (a)
แปลโดย Google
   + TomSoft Multifinkční bar (A, B, C)
    A = data sheet and the target point + indicator ON / OFF radar
    B = data sheet and transit point + indicator ON / OFF radar
    C = list of other information like GPS coordinates, compass indicator and ON / OFF radar
    + Ability to remove waypoints (Long click on maneuvers)
    + Ability to make screen shot screen (short handles on-site under the maneuvers)
    + Larger Font data for navigation
    + Green - yellow arrows for maneuvers
    + Lakva Planning - Planning improved screen (big thanks Lakva)
    + Lakva TMC - TMC pointer display and signal strength (many thanks Lakva)
    TomSoft + Added setting options for some
    + Ability to add additional buttons (BT Phone, Lakva Planning) and the fast menu in the cockpit
    + Automatic shorter than the route ... "Setting"
    Start the BT + + phone from the cockpit (the possibility SYS.TXT)
    + Added more data to be displayed in TomSoft bar with optional parts
    + Added option to reset the TC
    + Show TMC or NV Map
    + More options in the transparency settings
    + Ability to run WiFi from the main menu
    + Size adjustment "Preview křižiovatky"
    + Ability to set the optional display of buttons in the main menu
    + More details
    + More details
สนใจตามไปดูเพิ่มเติมได้ที่ web เจ้าของ skin Tomsoftware.net
Mirror Download
Very Thanks : tomsoftware.net for News and Skin
ร้านของผม
coUp..uP
ID number: 27695
« ตอบ #1 เมื่อ: 13 พฤษภาคม 2011, 00:46:06 »
ภาพที่แสดงนี้มีการ Mod แล้วไม่ใช้ skin ตัว Org.
ลองเอามาโม mini JVC ใน version นี้ มีการกำหนดการแสดงผล JVC อีกแบบ ไม่เหมือนกับ 1.3.1
ดังนั้นต้องแก้ไขค่าบางค่าแตกต่างจาก Version เดิมดังนี้ครับ
แก้ไขไฟล์ ui_igo9\common\ui\navigatemap.ui
จุดที่ 1
<layer ui_NavigateMapJunctionView z=20 visible=(%navigation.want_junctionview && %navigation.has_junctionview && !%lua.JunctionViewHiddenByUser) onshow=sc_JunctionViewOnshow onhide=sc_JunctionViewOnhide>
<DIV class=cockpit>
<SPRITE sprJunctionView class="junctionview"  left=0% top=30.5% w=39.8% h=39.8% alpha=27 OVERMAPLAYER onclick=sc_HideJunctionView>
  </DIV>
จุดที่2
<layer ui_NavigateMapJunctionViewSS z=20 visible=(ui_PropLayerSS.showjunction)>
<DIV class=cockpit>
<SPRITE sprJunctionViewSS left=0% top=30.5% w=39.8% h=39.8% alpha=27 align="left" onclick=sc_HideJunctionViewSS>
</DIV>
</layer>
ร้านของผม
coUp..uP
ID number: 27695
« ตอบ #2 เมื่อ: 14 พฤษภาคม 2011, 13:43:02 »
- Adaptation of TTS
eg
ออกแล้ว ตามไปดูได้ที่ web เจ้าของ skin ครับ  หรือ ที่กระทู้แรกหน้าแรก
ร้านของผม
Skin diMka for PC version 400x240, 800x480(only for version 8.0)
ที-เร็กซ์ 0 5783 กระทู้ล่าสุด 22 กันยายน 2009, 10:00:40
Skin diMka version 1.1.25.2 (only for version 8.3.h (8.3.1, 8.3.2, 8.3.4)
₪๐StemCell๐₪ 1 5507 กระทู้ล่าสุด 22 กันยายน 2009, 23:14:44
โดย Novox
Skin Dimka TomSoft 1.1.34 (a) For IGO
tin_43257 9 9190 กระทู้ล่าสุด 16 เมษายน 2010, 21:48:27
โดย tin_43257
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.039 วินาที กับ 39 คำสั่ง
