SU File Manager & Terminal v3.71
Requirements: Android 1.5+
Overview: Root Explorer with SU, Terminal, Search, mount, CHMOD, Symlink, view/edit/save, Run Scripts, Email, Home/Favs, Downloader, Multi-Select, Create/Extract Zip, PC Browser
if you cant copy/paste you dont have busybox or its not installed right.
If the toolbar is cut off the DPI is not set standard, its the ROM not the app.
?ROOT Access & BB REQ?
What's in this version:
Recent updates are bug fixes, as well as support for Gingerbread. Also added checker for BusyBox in case your device does not have it installed.
Better GingerBread Support
http://www.a...col.x.su.fbsลิงค์ครับ
