Current version PC1.1.4---Installation Instructions-------------------------------------------------- -----
Skin made on the basis of the package 8_PC_Fixed_v.3a daumrimas. The toolkit was laid here iGO8 (post # 2481903)
Since the package 8_PC_Fixed_v.3a in the default skin in the MENU is not possible to select an alternative skin, do the following:
1. Suppose the skin as always in the folder content \ skin (in the absence of a) in format zip.
2. to save \ system.ini:
section [interface]:
theme = "Default"
me
theme = "diMka by WertVRV v PC 1.1.4"
where diMka by WertVRV v PC 1.1.4 - the name of the skin as it is spelled out in info.ini (in skin)
Back switch to another (including credit default) skin can be from MENU skin.
The same entry can be done in sys_pc.txt, but then change the skin from the menu does not turn out.
Important:
To use the skin in the resolution 800x480 be replaced data.zip in the package with the following:
Note:1. Do not set a goal to fix data.zip in those files that are replaced by skin. (Ie the use of credit default skin possible inaccuracies in the mapping of text, etc.).
2. In data.zip little changed poi.icons (brought into conformity with the standards: the first line - an icon POI in 2D when you delete the second line - an icon POI in 2D when approaching and in 3D, the third - POI icon in the menu when using higher resolutions ( 800_480 example)). Icons data.zip only standard (one can change by itself).
---Opportunity Description-------------------------------------------------- -----
Some features are taken from the skin to 8.3.h. This skin can be read (and see screenshots) here: skin for 8.3.h.
Summary of changes in the default skin and taken from the skin for 8.3 features:
1. General view of (elements of the cab, maps, menus) skin in the style diMka.
2. Construction of the route from history.
3. Construction of the route from favorites (Favorite).
4. Construction of the route from the list of POI.
5. Record tracks (management tracks).
6. Trip computer (tripcomputer).
7. Blocking roads.
8. Custom Field "Next street.
9. Saver.
10. Mode review (overview mode).
11. Multiraschet. (But colorful routes in 8.0 there).
12. Quick menu with customizable buttons.
13. Additional visual warning of excess speed (animation icon excess + change text color in the intro).
Warning (visual and voice) to control the speed cameras and traffic does not work.
Note: The PC version does not work long taps (so disabled for all the buttons).
Credit :
WertVRV @ 4PDA.ru
