19 พฤษภาคม 2024, 14:00:55 *
ผู้เขียน หัวข้อ:  Resco File Explorer v.8.05 Beta  (อ่าน 2984 ครั้ง)
suthi
VIP เมื่อ 22-01-10
LT Members
ID number: 954
กระทู้: 258
$0.06 credits
Send Money to suthi
-ได้ให้: 180
-ได้รับ: 462
« เมื่อ: 03 กรกฎาคม 2010, 15:16:13 »
Requirements: WM2003-6.5
Overview: Resco Explorer - Totally Touchable File Manager
Resco File Explorer v.8.05 Beta ENG
http://depos...es/egbor5btv
Mirrors:
http://shari...ile/10575431
http://uploa...les/5d2emf19
Description
Full touch optimization
Quick and easy to use. Navigate through your files easily using your finger. Toolbar optimized for using your thumb for quick access.
Thumbnails View Mode
The new view mode displays previews of images. It becomes handy (improves the navigation) while seeking in folders with many image files.
The new Explorer can utilize tools and strengths of Resco Photo Manager. If users have both of these programs installed on a device, they will sense that the thumbnail loading is faster as well as the fact that it supports all the photo manager image types.
Upload to Social Network
The program is now able to upload image files to the most popular social networks including the largest web image database: Facebook, Flickr, Twitter, Picasa, MySpace and Photobucket.
Today Plugin
Today plug-in gets new shape and becomes totally customizable — add or remove phone tools, applications or documents. The eventual size of the plug-in, therefore, depends only on your choices.
Why is it useful to install the Resco Today Plugin ?
* Check your battery status and the free storage/memory directly on the Today screen.
* Launch your favorite applications and documents with a single tap.
* Browse the storage card with a single tap.
* Manage running applications with Task Manager
* Get the detailed storage properties.
* Use arrows for smart movement
* Additional skins ...
Task Manager
Avoid the complex process of managing tasks and apps in your PPC. Use the elegant, smooth and touch friendly interface of new Task manager. Easy to use, always at your service right on the home screen with catching graphics — that is the new Task manager from Resco.
Letter bar navigation
The side letter navigation bar lets you access your files faster
Features the letter preview of the files you would like to access with the specific files showing up instantly
Virtual Folders for all documents
All file types associated with what you are looking for can be found in these folders without the need to look for them in all your folders on the device or your storage card.
Instead they are all displayed in these virtual folders from where they can be retrieved easily anytime you need them.
Includes:
* Documents
* Encrypted Files
* Images
* Music
* Videos
You also have the option to create your own virtual folder with the file extensions which you plan to use frequently
Very useful when looking for files of the same type
The Quick Search Function
Using the keyboard, instantly search for files you need by typing in the starting letters of the file
The File Manager
The File Manager is the HEART of the Explorer.
It is stable and efficient and it provides the most comfortable way for file operations such as copying, moving, deleting, renaming, etc., including speed measuring.
It is great when you need to quickly search for files or file content. It speeds-up your work by using the Favorites folders. The system info keeps you informed about your system resources usage at all times.
With File Types Highlighting you will never oversee important file type.
Customizable keyboard shortcuts ensure you can run favorite features by pressing a single button.
Customizable startup folder ensures you will immediately start in a folder you really want to.
Recycle Bin
Resco Explorer now moves deleted files into a virtual folder "Recycle Bin" instead of immediate deletion.
If the file was deleted accidentally, it is now possible to restore it safely from the Recycle Bin folder.
Recycle Bin takes at most 10% of each storage. It is possible to choose the bigger or smaller space
for recycled files or disable the Recycle Bin completely.
Strong File Encryption
You can use the Enhanced Cryptographic Provider with strong algorithms such as RC2-128, DES-56, 3DES TWO KEY-112, 3DES-168.
We did our best to make the en/decryption process familiar looking and easy to use.
Additionally, you can also install a Windows 95/98/ME/2000/XP/Vista shell extension to use the encryption/decryption process on desktop PCs.
Archive files (ZIP, RAR)
ZIP Compression can be used to increase the storage space of any storage device.
Use of this handy tool is the simplest and cheapest way to save significant amounts of storage space.
The used ZIP algorithm is PC compatible, so you can extract archives created on a desktop PC and vice-versa.
Decompression of RAR archives included.
The built-in Viewer
The built-in Viewer can be used to view files in TXT, BIN or HEX format, as well as JPEG, GIF, BMP and PNG graphic formats.
The built-in viewer implements a very comfortable text search function.
Viewing files has never been so easy.
You can use the built-in viewer also to view encrypted files (decryption in memory)
The Network Browser
The Network Browser let's you discover and take advantage of the wired-up world directly from your device.
Simply map the shared network folders and work with them as easily as with the local ones.
Various settings allow you to set your network drive in the exact way as you desire.
The Registry Editor
The Registry Editor is for power users only.
It allows you to export, import, view or modify the registry keys.
The interface is very simple and very powerful at the same time.
The FTP Explorer
FTP Explorer gives the possibility to browse the FTP server's content directly in your Resco Explorer window. It adds the root below the "My Device" and the user is able to copy/move/delete/rename files the same way as if they were the local files.
What is new:
* Quick-search supports wildcards (*pattern?.exe)
* Bluetooth transfer 4 times faster on Microsoft Bluetooth stack
* Bluetooth - discovery window shows the paired devices (Microsoft Bluetooth stack only)
* Progress window is showing the remaining time
* Report view supports both directions scrolling (for more or longer columns)
* HW keyboard commands supported (Del, Tab, Ctrl+XY)
* Properties window - file name and location is scrollable and supports context menu
* Paste shortcut for more files
* Today plugin - option "Stay On Top"
* REG file import: silent import + key deletion ([-HKEY_...]) + comments
* FTP bug on UNIX servers (file names with uppercase extensions) fixed
* FTP activate cellular connection correctly
* Window size fixed
* Error message for invalid executables
นำมาจากเวบ Mobilsm
Resco Explorer CE : File Manager
ที-เร็กซ์ 17 11727 กระทู้ล่าสุด 16 ธันวาคม 2009, 20:31:24
โดย Guuzaa
ใหม่ ES File Explorer v1.6.0.3 โปรแกรมจัดการไฟล์สุดแหล่ม Update v3.0.9.1
^SuRaYoOt^ 17 17751 กระทู้ล่าสุด 10 มกราคม 2014, 14:00:30
File Explorer 0.170 โปรแกรม Explorer ที่ดูแล้วน่าใช้มากเข้าถึงข้อมูลง่ายเพราะทำหมวดหมู่ไว้ให้เลย
astkul 0 3345 กระทู้ล่าสุด 03 มิถุนายน 2012, 07:09:12
โดย astkul
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.039 วินาที กับ 33 คำสั่ง
