12 พฤษภาคม 2024, 19:07:58 *
หน้า: [1] 2   ลงล่าง
ผู้เขียน หัวข้อ:  diMka WertVRV 1.1.25.5 Skin for iGo8.3x (08.10.09)  (อ่าน 16517 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 09 ตุลาคม 2009, 00:30:22 »
diMka by WertVRV
WertVRV : 1.1.25.5 : 240x320, 320x240, 240x400, 400x240, 400х234, 416х234, 480х272, 480x234, 800х480, 480х800
diMka WertVRV 1.1.25.5  for 8.3.x (8.3.1, 8.3.2, 8.3.4)
1. Changes in the fuel calculator (added choice - intermediate point / finish).
2. Improved the search (filter name) on the history list (now, after exit the list filter is set to zero).
3. Corrected list of possible values of the camera while editing / creating the camera through the menu cursor (delete the value "75" - in the scripts озвучки no such rate) (it will be necessary to reconfigure the values for the so-called "hot" buttons speed).
4. Improved the voice Event Driver Alerts (for "narrow" permits with one column displaying signs voice was the appearance marks the second "invisible" speakers + more in some cases had extra sounds).
5. Improved the display of the sign of the speed limit for the camera like "Tunnel" (not displayed).
6. Fixed shutdown "Avtopererascheta route" after the use of simulation through a brief menu button.
7. Minor corrections in alignment of the text.
Only with ver.8.3.x.(8.3.1, 8.3.2, 8.3.4)
Two variants of compatibility skin with version 8.3.4:
 - We use data.zip from version 8.3.2 (anything in it not changing) and we use skin (anything in it not changing).
Use in sys.txt:
skin="ui_igo8"
 - We use data.zip from version 8.3.4 (anything in it not changing) and we use skin (in skin (in zip-archive) necessarily we rename the folder ui_igo8 to ui_igo8_da).
Use in sys.txt:
skin="ui_igo8_da"
Download -->
Very Thank  : WertVRV , dima8389 , Andron66
« ตอบ #1 เมื่อ: 09 ตุลาคม 2009, 00:35:17 »
ช่วงนี้ไม่น่างานเข้าเลย  แต่ก็ขอ load เก็บไว้ก่อนนะคะ
jammpoo
VIP เมื่อ 30/09/2009
ID number: 765
กระทู้: 85
Send Money to jammpoo
-ได้ให้: 95
-ได้รับ: 75
« ตอบ #2 เมื่อ: 09 ตุลาคม 2009, 00:36:55 »
มีของใหม่เล่นทุกวันเลย   :oงง ไปหมดแล้ว อย่าหยุดนะครับ  ตอนนี้ ในเม็ม รันมั่วไปหมดแล้ว ไม่รู้อันไหนเป็นอันไหน  สงสัยต้อง เอายาสลบส่งไปให้เหล่า นักโม กินกันซัก กำ สอง กำซะแล้ว(สู้กะม้าที่กินไป)  คึกคักจริงๆ
แต่ที่ผมเข้ามาป้วนเปี้ยนทั้งวันก็รอสิ่งนี้แหละครับ อิอิ
« ตอบ #3 เมื่อ: 09 ตุลาคม 2009, 10:53:53 »
ออกใหม่อีกแล้วเหรอครับ
ตามใช้ไม่ทันจริงๆ แล้ว
tee_city
ID number: 673
Send Money to tee_city
« ตอบ #4 เมื่อ: 09 ตุลาคม 2009, 11:14:35 »
ของผมขึ้น   Fatal Error
Fatal error occurred in main thread.
Address : 0x000c840c
Exception : 0x80000002
เข้าไม่ได้ครับ
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
-ได้ให้: 829
-ได้รับ: 10413
« ตอบ #5 เมื่อ: 09 ตุลาคม 2009, 12:31:44 »
เข้าไม่ได้ครับ
- IGO Version ไหนครับ ? ? ?
- ลงกับ IGO ชุดปกติหรือเปล่า ? ? ? (ถ้าจะทดสอบ skin แนะทำให้ลงกับชุดปกติก่อน อย่าเอาไปลงกับชุดที่ปรุ่งเสร็จแล้ว)
- ตรวจสอบในส่วน [interface] ตาม redme หรืัอครับ ? ? ?
ลองทดสอบอีกทีแล้ว skinใช้ได้ครับ ตามรูปกระทู้ที่ 1 ครับ
birdtsl
คนธรรมดา
ID number: 527
กระทู้: 63
Send Money to birdtsl
-ได้ให้: 117
-ได้รับ: 81
« ตอบ #6 เมื่อ: 11 ตุลาคม 2009, 10:56:34 »
ตามกันไม่ทันเลยจริงๆ Grin Grin
sax
ID number: 27
กระทู้: 250
$2461.00 credits
Send Money to sax
-ได้ให้: 590
-ได้รับ: 222
« ตอบ #7 เมื่อ: 11 ตุลาคม 2009, 14:24:13 »
อยากลองใช้แต่ยังโหลดไม่ได้เลย : ฮือ ๆ
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
-ได้ให้: 829
-ได้รับ: 10413
« ตอบ #8 เมื่อ: 11 ตุลาคม 2009, 20:20:38 »
Server มีปัญหาครับกำลังแก้ไข
  << Dowload สำรองไปก่อนนะครับ
HscMan
VIP เมื่อ 20-10-2009 2Y
ID number: 1151
กระทู้: 53
Send Money to HscMan
-ได้ให้: 67
-ได้รับ: 49
« ตอบ #9 เมื่อ: 11 ตุลาคม 2009, 21:34:07 »
เพิ่งโหลดของเก่าไปใช้ได้แค่อาทิตย์กว่าๆ ของใหม่มาอีกแล้วยังไงก็โหลดไปลองดูก่อนครับ
keng291049
ID number: 1473
Send Money to keng291049
« ตอบ #10 เมื่อ: 12 ตุลาคม 2009, 08:58:22 »
อื้อหือ...ตามเก็บแทบไม่ทัน
kanit832
ID number: 354
กระทู้: 52
Send Money to kanit832
-ได้รับ: 48
« ตอบ #11 เมื่อ: 17 ตุลาคม 2009, 13:11:14 »
รบกวนสอบถามท่าจะเอา skin เก่าๆออกจะทำอย่างไรนะครับ
« ตอบ #12 เมื่อ: 17 ตุลาคม 2009, 13:18:04 »
เข้าไปลบไฟล์ skin ที่ไม่ต้องการในโฟล์เดอร์  content/skin
takasungi
VIP เมื่อ 09-10-2009
หลงทางเป็นอาจิณ
ID number: 1006
กระทู้: 26
Send Money to takasungi
-ได้ให้: 28
« ตอบ #13 เมื่อ: 19 ตุลาคม 2009, 01:57:21 »
มาตามเก็บคับ
ID number: 31
« ตอบ #14 เมื่อ: 19 ตุลาคม 2009, 12:00:03 »
ช่วงนี้ปุ่มดาวน์โหลด หายไปไหนแล้วล่ะ .....พ่อแมวเหมียว Smiley
Novox
ID number: 722
กระทู้: 173
$82.07 credits
Send Money to Novox
-ได้ให้: 40
-ได้รับ: 361
« ตอบ #15 เมื่อ: 20 ตุลาคม 2009, 15:07:05 »
ตัวนี้ใช้ 3d car ไม่ได้ใช่ปะครับ
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
-ได้ให้: 829
-ได้รับ: 10413
« ตอบ #16 เมื่อ: 20 ตุลาคม 2009, 16:54:27 »
เท่าที่ลองเล่นดู ไม่ได้ ครับ
Novox
ID number: 722
กระทู้: 173
$82.07 credits
Send Money to Novox
-ได้ให้: 40
-ได้รับ: 361
« ตอบ #17 เมื่อ: 20 ตุลาคม 2009, 16:58:58 »
รับทราบครับ ผมก็งมหาตั้งนาน แล้ว 2D car เปลี่ยนจาก mini cooper เป็นคันอื่นได้มะึคับ
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
-ได้ให้: 829
-ได้รับ: 10413
« ตอบ #18 เมื่อ: 20 ตุลาคม 2009, 17:10:03 »
หน้าจะไม่ได้ครับยังไม่ได้ลองครับ เพราะถ้าได้ มุมบนขวา mini จะมีรูป icon เล็ก ๆ ให้กดเข้า อีก menu ครับ
ถ้าจำไม่ผิดเป็น skin ของ GJ เปลี่ยน 2D ได้ครับ
« ตอบ #19 เมื่อ: 20 ตุลาคม 2009, 18:28:45 »
หน้าจะไม่ได้ครับ
แล้วหลัง เปลี่ยนได้มั้ยครับ    Grin
แซวเล่นเฉยๆ นะคร้าบ พี่ stemcell สุดหล่อ   ^-^
ว่าแต่ว่า ทำไม พักนี้ skin for amigo  เงียบๆ ไป   เดี๋ยวต้องส่ง อีแมว ( email ) ไปกระตุ้นสักหนอ่ย    Grin
หน้า: [1] 2   ขึ้นบน
diMka WertVRV 1.1.34 Skin for igo 8.3.xx (23-02-2010)
₪๐StemCell๐₪ 5 6847 กระทู้ล่าสุด 01 พฤษภาคม 2010, 15:50:59
โดย fairy
Skin diMka by WertVRV _k63_compass
tin_43257 1 3096 กระทู้ล่าสุด 02 เมษายน 2010, 13:29:45
skin for igo8 diMka by WertVRV v 1.1.36_k63_UFO 11/04/2010
tryth 0 2931 กระทู้ล่าสุด 12 เมษายน 2010, 09:31:08
โดย tryth
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.103 วินาที กับ 84 คำสั่ง
