12 พฤษภาคม 2024, 07:25:58 *
ผู้เขียน หัวข้อ:  Skin diMka 1.1.35 (20-03-2010) for IGO8.3x  (อ่าน 20836 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 21 มีนาคม 2010, 01:15:40 »
1.1.36 ออกแล้วครับ http://www.n...498#msg22498
Skin diMka for 480h234, 320x240, 240x320, 240x400, 400x240, 480x272, 400h234, 416h234, 480x800, 800x480 (only for version 8.3.h (8.3.1, 8.3.2, 8.3.4)).
Current version 1.1.35
Do not forget to say thanks:
dima8389 - author of the original skin di / \ / \ ka.
Andron66 - a huge contribution to the graphics (bmp-files) of the skin.
What new.
1.1.35 for 8.3.h (8.3.1, 8.3.2, 8.3.4)
   1. Changes from dima8389: when "pedestrian" (long press of the screen "Quick Menu" button on the change of vehicle or in the planning of the map screen to the same button) can be written in the history of the element with the name "current situation" (a simplified version of the function Return to the car ");
   2. Added ability to configure the long press the Menu button cab immediately launch an external program (the first in the list of external programs);
   3. Added ability to display the dynamically updated list of POI, around the provision GPS (thanks for the picture Andron66).
      Features and working principle:
      - You can enable / disable option;
      - List available under this option is enabled after determining the position of GPS; the appearance of shields disappear, while working with the map (clicking, moving) disappears, you can view the job options and a simulation without signal GPS (in the simulation POI search will take place around the last saved position GPS) ;
      - Possible adjustment range search;
      - Can configure the buttons display a list of Governors (less, next page, previous page) (when the control button long press turns on the list item list);
      - After searching through a list of approximately 10 seconds of an automatic transition to the first page;
      - Can set the maximum number of rows to display a list of the cabin (the current number of rows dynamically changed during the movement depending on the availability of on-screen elements such as a sign prohibiting the cabin lamps, traffic signs on the fringes (map above), control buttons, lists, etc.) ;
      - The list could include: All POI / Just visible on the map;
      - Possible to configure the filter name POI (for example, the word "drugstore" in the list will get POI (from all or only visible on the map), containing the name of the word "drugstore");
      - Possible setting distance to maneuver in the presence of active route for the automatic folding / unfolding of the list;
      - If the specified settings (distance, filter, etc.) list is empty, the button appears on the screen (gray icon POI), clicking on that - go to the settings;
      - For quick access to additional settings available long press on the button "Hide", a long press on the button minimized (collapsed) list;
      - Aka the appearance of a nonempty list of events POI while driving (the sound can be selected in the options menu);
      - List of POI is available in the screen saver (you can choose to display only the cab / only for the screen saver / for both modes) (for savers maximum number of rows list is not regulated in options and restricted size of free area) (in the intro with the appearance of billboards list disappears, with appearance of the camera list disappears (except 480_234, 480_272));
   4. Rectification observed in 1.1.34.
<--Download
<--Download สำรอง
Important: Work with Driver Alerts and Truck Profiles (8.3.4):
Skin (version 1.1.25.2) is compatible with version 8.3.4 exe.
Two variants of the skin (version 1.1.25.4) with version 8.3.4:
1) use data.zip from version 8.3.2 (nothing in it is not changing) and use the skin (nothing in it is not changing)
Do not forget to sys.txt (unless stated in [project] name):
skin = "ui_igo8"
2) use data.zip from version 8.3.4 (nothing in it without changing) and use the skin (in the skin (inside the zip-archive) rename the folder ui_igo8 on ui_igo8_da).
skin = "ui_igo8_da"
Important: User WVGA-device (480h800, 800x480):
Skin (starting with version 1.1.25) supports two modes of operation:
- 240х400, 400h240
- 480h800, 800x480
In both modes, images of buttons, menu items, and other screen elements are the same (in the high quality display).
In the first version of the skin works with the card size 240х400 (400h240), the second - with a card size 480h800 (800x480), respectively, the second option requires more memory.
So which mode to use the skin, it is necessary to identify yourself.
For devices (480h800, 800x480) to specify the permissions in this section sys.txt enough (nothing more (resolution_dir, screen_x, screen_y) regarding the resolution and screen size, in principle, not necessary):
autoconfig = 1
highres = 1, (1 - mode 240х400, 400h240, 0 - mode 480h800, 800x480).
And, if you do not use the above (deprecated) resolution_dir, screen_x, screen_y, then in each of the modes (240х400-400h240 and 480h800-800x480), portrait-landscape switching is possible from the menu (Settings-Device-orientation of the screen).
« แก้ไขครั้งสุดท้าย: 28 มีนาคม 2010, 03:11:59 โดย ₪☺StemCell☺₪ » บันทึกการเข้า
boonapple
ID number: 1996
Send Money to boonapple
« ตอบ #21 เมื่อ: 11 พฤศจิกายน 2010, 14:46:38 »
Folder ที่ชื่อ SpeedcamVoiceScripts จะต้องนำไปไว้ที่ไหนครับ
ใน folder iGO8 หรือใน Content ครับ
« ตอบ #22 เมื่อ: 11 พฤศจิกายน 2010, 21:39:37 »
ใน folder content ค่ะ
diMka WertVRV 1.1.34 Skin for igo 8.3.xx (23-02-2010)
₪๐StemCell๐₪ 5 6842 กระทู้ล่าสุด 01 พฤษภาคม 2010, 15:50:59
โดย fairy
Skin diMka 1.1.36 (28-03-2010 1:50am) for IGO8.3x
₪๐StemCell๐₪ 9 9984 กระทู้ล่าสุด 17 พฤษภาคม 2010, 12:23:39
โดย equinox
skin for igo8 diMka by WertVRV v 1.1.36_k63_UFO 11/04/2010
tryth 0 2926 กระทู้ล่าสุด 12 เมษายน 2010, 09:31:08
โดย tryth
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.03 วินาที กับ 44 คำสั่ง
