21 พฤษภาคม 2024, 01:24:41 *
ผู้เขียน หัวข้อ:  HDR Camera+ v1.60 Update v2.17  (อ่าน 8871 ครั้ง)
« เมื่อ: 02 มิถุนายน 2011, 03:59:17 »
HDR Camera+ v1.60
Requirements: Android v2.2+
Overview: Capture high quality HDR images in full resolution Capture high quality High Dynamic Range images!
Capture high quality High Dynamic Range images:
- Full resolution
- Take HDR image in one tap
- HDR image fused and tone-mapped on device within seconds
- Don't have to be rock-solid while shooting
- Correct handling of moving objects and de-ghosting
- You can control tone-mapping parameters: contrast, micro-contrast, color vividness, exposure
- Save original exposure bracketed images
- Location tagging
- Shutter sound can be muted
Why HDR
Real life scenes often have a wide range of light intensity, which cannot be captured by a camera. In a photo of such a scene the bright areas look washed out and everything in shadows is pictured as a black spot with no details. The HDR technique allows you to capture details in bright and dark areas and have them merged in a single photo.
HDR photography is widely adopted by professional photographers. Wouldn't it be nice to have an HDR in mobile phones?
The problem is that HDR requires taking several differently exposed images in series, which must be precisely aligned and then fused. In order to be usable for real life scenes, the HDR feature should include moving object detection and hand shake compensation to avoid or minimize the ghosting in the final image. That requires a lot of computational resources and makes a challenge even for professional desktop HDR software.
Almalence has brought its expertise in professional HDR software to mobile phones. Our HDR fusion algorithms compensate hand shaking and detect moving objects in the scene, suppressing ghosting artifacts. At the same time, the algorithms are quick enough to provide comfortable processing time on mobile devices.
Recent changes:
- Motorola Droid's fix
- Geotagging
Content rating: Low Maturity
Latest version: 1.60 (for Android version 2.2 and higher)
https://mark...earch_result
ลิงค์ครับ Smiley
HDR Camera+ v1.60
Very thank f000h  สำนึกผิด
« ตอบ #1 เมื่อ: 23 สิงหาคม 2011, 02:57:43 »
Update HDR Camera+ v1.70
What's in this version:
memory optimizations, full resolution should work on all devices now
workaround for some faulty firmwares (exposure step is reported incorrectly, in particular on GT-S5830)
given up unreliable exif rotation tag, image is rotated to portrait/landscape orientation internally
ลิงค์ครับ Smiley
HDR Camera+ v1.70
« ตอบ #2 เมื่อ: 19 กันยายน 2011, 22:06:24 »
Update HDR Camera+ v1.71
full media re-scan avoided
installation/move to sd card is now supported
better shutter mute
ลิงค์ครับ Smiley
HDR Camera+ v1.71
« ตอบ #3 เมื่อ: 07 ตุลาคม 2011, 07:01:20 »
Update HDR Camera+ v1.73
Gallery launch list improved
 Saving directory is changed to DCIM/Camera/ to prevent issues with some gallery apps not showing images
 Full media scan if per-file media scan failed (fix for images not showing up in a gallery)
 Minor stability fixes
 Translated to locales: de, es, fr, it, ja, pt, ru, zh
ลิงค์ครับ Smiley
HDR Camera+ v1.73
« ตอบ #4 เมื่อ: 06 พฤศจิกายน 2011, 23:03:44 »
Update HDR Camera+ v1.75
Custom 'Save To' folder can be selected
Trash icon on preview (to delete image)
Preview is kept for at least 4sec
Bug-fixed localized versions (some preferences were disappearing)
Better geo-tagging
ลิงค์ครับ  Smiley
« ตอบ #5 เมื่อ: 24 ธันวาคม 2011, 04:48:46 »
Update HDR Camera+ v2.10
New HDR tone-mapping adjustments screen
Faster processing on dual-core
better EXIF handling
ลิงค์ครับ  Smiley
MO306
ID number: 22317
Send Money to MO306
-ได้ให้: 43
« ตอบ #6 เมื่อ: 30 มกราคม 2012, 16:21:03 »
filesonic ใช้ไม่ได้แล้วครับ
« ตอบ #7 เมื่อ: 02 กุมภาพันธ์ 2012, 22:27:18 »
Update HDR Camera+ v2.15
by popular demand: re-designed icon
better processing: stability fixes, less noise
external sdcard mount locations added: /emmc /bootsdcard
alternative way of setting exposure for Qualcomm-chpiset phones (Vega Racer, Xperia's etc)
higher-quality jpeg compression
various minor fixes
ลิงค์ครับ  Smiley
« ตอบ #8 เมื่อ: 04 มีนาคม 2012, 22:36:45 »
Update HDR Camera v2.16
various minor fixes
ลิงค์ครับ  Smiley
« ตอบ #9 เมื่อ: 15 มีนาคม 2012, 05:20:03 »
Update HDR Camera+ v2.17
Important bug-fix: internal crash fixed causing intermittent non-processing/non-saving of some photos
ลิงค์ครับ  Smiley
Appถ่ายภาพที่ดีอีกตัวบน android กับ Camera ZOOM FX Update v6.2.2 « 1 2 3 »
^SuRaYoOt^ 41 46750 กระทู้ล่าสุด 13 กันยายน 2016, 19:15:05
มาถ่ายภาพอย่างค่ำคืนกับ Night Camera+ v2.08 Update v2.22
^SuRaYoOt^ 2 4008 กระทู้ล่าสุด 12 ธันวาคม 2014, 05:07:18
มาแล้ว IP-CAMERA สุดยอดกล้องคุณภาพสูง ดูภาพได้บนมือถือ/tablet/PC พังก์ชั่นมาเต็ม
P.A.NAVIGATOR
P.A.NAVIGATOR 10 20353 กระทู้ล่าสุด 15 สิงหาคม 2014, 18:11:17
โดย P.A.NAVIGATOR
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.278 วินาที กับ 48 คำสั่ง
