เห็นถามมาหลายท่านครับ เลยเอามาลงให้อีกครั้ง
From JM
Description: Chinese version of Nav N Go iGO8 GPS Navigation Software for Windows Mobile based PDA/PNA devices.
Contains native support for Chinese language including Chinese keyboard and Chinese TTS voice package.
The application has been patched and tested to work both on PDA and PNA/PND, as well from any SD Card or Internal Flash storage.
Note, this version was released by Nav N Go as a "Content Test" and may not represent the final version being supplied
for this region and may contain bugs! Use it only at your own risk!
1. Download and unrar the content of the archive to the root of your SD Card/Internal Storage.
2. Launch the application either from the Explorer or create a Program Shortcut (using i.e.Totalcmd CE)
Note: Internal Flash Storage users must edit their SYS.TXT accordingly.
!!!IMPORTANT NOTICE !!!
This version works ONLY with the new Chinese 2008.5 map set (not included)! It WONT WORK with your existing European or American maps. The application uses a different map encoding schemas and that cannot be just simply patched!
http://rapid...O8.part1.rarhttp://rapid...O8.part2.rarhttp://rapid...O8.part3.rarhttp://rapid...O8.part4.rarใช้โปรแกรม Raysource ช่วยโหลดนะครับ โหลด Raysource ที่นี่
http://stati...h-cn/client/เมื่อโหลด Raysource มาแล้วติดตั้งโปรแกรมให้เรียบร้อยครับ เมื่อติดตั้งเสร็จแล้ว Click ที่ Link ด้านล่างนี้
http://www.rayfile.com/zh-cn/files/71b4c7b0-7071-11dd-9583-0014221b798a/
